Viewing feedback for: jpwerks Email: [email protected] Last Visited: April 08, 2024 |
Westyseeker Samba Member
Joined: August 22, 2010 Posts: 15 Location: Saugerties,New York
Posted: Wed Nov 07, 2012 7:32 pm Post subject: John - [email protected] |
Great description and communication. Fast shipping. Item was just as good as new and got to save a few bucks for one of my many other projects.
Thanks again. _________________ 85 Wolfsburg Westy
87 Wolfsburg Tin top
87 Wolfsburg Westy
88 Wolfsburg Tin top |
westyman71 Samba Member
Posted: Wed Feb 06, 2013 5:22 am Post subject: |
I just bought 2 of the long oil drain plugs from John.
I could not be happier. Solved my problem of the infamous "drip" from my drain plug, as the longer threads sealed it up, as the stock plug did not.
He even included 3 copper washers for each plug for free.
John replied quickly to my inquiry. Shipping was same day as order. Item was at my house 2 days later. Cant beat that with a stick, can ya?
John has got his act together.
Chuck
Independence, KY |
sdirghalli Samba Member
Joined: September 19, 2008 Posts: 16 Location: Long Beach, CA
Posted: Thu Feb 07, 2013 10:57 am Post subject: Excellent seller |
Just bought two headrests from John...really easy to deal with and SUPER FAST shipping!
Would happily deal with him again. |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4026 Location: Redwood City, California
Posted: Sat Jun 08, 2013 9:13 pm Post subject: |
I also bought an extended drain plug for my WBX . It just feels better when you tighten it up ,it takes a lot more torgue .
I now need to get one ,for my Westy . I have done business with Paul and his Father before and have always been satisfied .
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
VANGAUX Samba Member
Joined: May 25, 2008 Posts: 56 Location: Harrisonburg, VA
Posted: Thu Aug 22, 2013 10:59 am Post subject: Extended drain plug |
Wow! Ordered one drain plug, it shipped the same day and arrived on the opposite coast 2 days afterwards.
Exactly as pictured with 3 washers. Should be an excellent addition to my van.
Great communication, shipping, and product.
Harold |
dieseltdi Samba Member
Joined: September 07, 2006 Posts: 538 Location: Grapevine, Texas
Posted: Sat Sep 21, 2013 6:54 am Post subject: |
Great transaction. Helped me out of a tight spot with some diesel injector heat shields that I desperately needed but couldn't find locally. Thanks. Hayden |
fleet_maintenance Samba Member
Joined: November 01, 2013 Posts: 323 Location: Upstate NY
Posted: Wed Sep 17, 2014 6:29 pm Post subject: |
XL Drain plug
Ordered...shipped....arrived two days later.
I'm hoping this cures the drip.
Easy (and inexpensive) transaction. Thanks! |
ecopreneur Samba Member
Posted: Sun Oct 05, 2014 5:36 pm Post subject: |
My dreaded drain plug was stripped and found a solution on a forum about using a longer drain plug to grab more threads. Found John sold them so I called him since my Vanagon was setting in the driveway blocking our other cars and I had already drained the oil. John was very pleasant and said he could send it express so it would arrive quickly which it did. Great solution to the problem. No leak when the oil was added. |
java71 Samba Member
Posted: Tue Mar 17, 2015 6:01 am Post subject: crank front/fan hub |
Needed a fan hub for my Type 4 engine build....John had what I needed and shipped it very quickly. I'm very pleased with the part and service! |
hrtm Samba Member
Joined: August 21, 2015 Posts: 149 Location: Albuquerque, NM
Posted: Sun Mar 27, 2016 6:49 pm Post subject: Re: John - [email protected] |
No complaints whatsoever with John or how he does business. As far as delivering product in a timely and accurate manner I have no issue.
However, just a caveat that the longer drain plug solution may not work for everyone. - it worked for me only on 1 oil change. I would recommend finding a way to measure the depth of your engine case before considering the taller drain plug. In my case I actually only ended up engaging maybe 1 or 1 1/2 more threads with the longer plug. It was enough to get about 20nm of torque (Bentley calls for 25nm) but I could tell it was on the verge of slipping again. 'Twas enough to last that particular oil change, but sure enough - next time around the new longer bolt spun off those last threads with less than 10nm of torque. Ended up installing a helicoil and using the stock drain plug again. Again, no complaints w/ John specifically as it was only an $11 gamble and it did deliver at least once, but I'm compelled to caution against a broad-brush reliance on a longer drain plug being THE solution. Take the time to measure your case depth and go with a helicoil or timesert as needed! _________________ '84 Vanagon Westfalia
'69 Beetle |
kalispell365 Samba Member
Posted: Wed May 18, 2016 5:13 pm Post subject: Re: John - [email protected] |
John sold me a header and collector for my Subaru conversion, arrived safe and was exactly as described.
I would do business with him again anytime, THANK YOU! _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
MDeath Samba Member
Joined: September 14, 2004 Posts: 50 Location: Albany, NY
Posted: Mon Aug 21, 2017 5:28 pm Post subject: Re: John - [email protected] |
Great seller, very accommodating. Sold me a timing belt cover, very quickly and great price. Thanks John - hope to do business again!
gomezpal _________________ Old Dubs, Old Harleys, Tom's Mom. |
Mark W. Roush Samba Member
Joined: April 22, 2014 Posts: 3 Location: Santa Fe, NM
Posted: Wed Dec 27, 2017 7:16 pm Post subject: Re: John - [email protected] |
I've purchased several items from John in a couple of different batches this year and for all interested I would say WOW how nice! All the parts were in Great shape and some even looked new. I sometimes worry about parts being hurt in shipping but the way John packs them... Don't Worry! Thank you John... I'll be back! |
16CVs Samba Member
Posted: Sat Jan 27, 2018 9:30 am Post subject: Re: John - [email protected] |
Another great Transaction from John at JP. I purchaed a Syncro muffler bracket and had them cover my Dash Cluster in Leather, a Vein purchase just like my SYNCRO stamped sliding door cover but cool none the less.
Great Communication and great follow through. You can count on these guys to do what they are supposed to.
jlrftype7 Samba Member
Posted: Fri Nov 02, 2018 5:01 pm Post subject: Re: John - [email protected] |
I ordered a fuel pump mounting bracket from John. It showed up on time and ‘looks the business’ as my British friends say. Will make a great replacement for the single hose clamp that some PO of my Vanagon used instead of the correct bracket like John sells. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Campinator Samba Member
Joined: December 30, 2015 Posts: 1 Location: Long Island, NY
Posted: Tue Oct 15, 2019 11:39 am Post subject: Re: John - [email protected] |
Amazing service! John shipped the engine tin I ordered the same day, it arrived a week later (coast to coast). Squeaky clean, looks like new, perfectly packaged! Highly recommend! |
Bambus Samba Member
Posted: Fri Apr 15, 2022 9:49 am Post subject: Re: John - [email protected] |
Another happy customer of jpwerks. Did a Samba search for 1.9 WBX thermostat housing Monday morning, it shipped same day, pulled it out of the mailbox Thursday.
Housing was nicely bead-blasted so very clean, ready to install.
Top recommendation! :clap |
