hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sun Nov 11, 2012 2:40 am Post subject: Building doors, want to know assembly order |
Anyone know what to put in first? it's a 73 super
_________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
waco69bug Samba Member
Joined: December 01, 2007 Posts: 318 Location: Sparks, NV
Posted: Sun Nov 11, 2012 9:16 am Post subject: |
This might help - http://www.thesamba.com/vw/forum/viewtopic.php?t=335018 _________________ 1969 Beetle (Just finished a complete pan off restoration, SWEET! Runs like I imagine a new Beetle would!)
1971 Beetle - 1776CC, dual carbs
1971 Super Convertible - my wife's car
1969 Bus - Work in progress, fun to drive, just needs the odd tweak.
1957 Rag top - Just got her Nov. 13. |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Sun Nov 11, 2012 11:21 am Post subject: |
As for the scrapers/trim:
With the window glass disconnected and sitting in the bottom of the door shell, install outside scraper (snaps in).
install (5) (felt channel) retaining clips,
install wing-vent assy.
install inside scraper (snaps in),
install felt channel,
hook up window glass and adjust.
As a note, when you are installing the snap-in scrapers, use bar soap or candle wax to wax up the snap-in clips and the holes they snap into. Then use some kind of flat backer to push on the scrapers evenly when pushing the clips into the holes. This way you will not kink the fragile trim.
work slowly, make sure everything is accurate and "dead nuts". good luck. |
Posted: Tue Nov 13, 2012 11:06 am Post subject: |
Thanx, will keep posting as i build, got to get some parts first. _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
