srfndoc Samba Member
Maxim Samba Member
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Nov 14, 2012 7:27 pm Post subject: |
Holy smokes! That's the Bentley service manual reference photography bus! _________________
EverettB wrote: |
FU#5 |
novetti Samba Member
Posted: Mon Nov 19, 2012 9:32 pm Post subject: |
Very nice work.
The sale price reflects that. |
Clara Samba Member
Posted: Tue Nov 20, 2012 11:33 pm Post subject: |
hitest wrote: |
Holy smokes! That's the Bentley service manual reference photography bus! |
now you are just asking for a list of incorrectness, things that would not be in the Bentley.
carb.... |
madcitymcflyer Samba Member
Joined: February 18, 2005 Posts: 134 Location: Madison, WI
Posted: Wed Nov 21, 2012 4:12 am Post subject: |
You can add to the 'stickler's list':
No speed limiter (governor) on carb;
Deluxe horn button instead of standard black one;
Missing pedal (belly)pan;
Shiny painted heat exchangers (only came primed);
Over finished underside sheet metal;
Fuel tank is painted black (they came in a shade of gunmetal gray).
Radial tires look nice; 'originals' would be 6.95 or 7.00 x 14's bias ply
Continentals from the factory;
Radio is a dealer-installed option only
Still, if Bentley ever publishes a web version, use it as is for the photo bus. And make sure the mechanic wears his clean shop coat! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Nov 21, 2012 6:04 am Post subject: |
madcitymcflyer wrote: |
want more?
-lock plates on front axle beam not installed in the correct orientation (driver's side)
-disc brakes on front (and associated mechanicals involved with that)
-front trailing arms not painted
-wrong style horn
-looks like a distributor for a dual port engine
-not so sure about those copper brake lines
-no insulating wrap on heater tubes
-wrong style sealing grommets for hose junction between fan shroud and rear tin
-etc
there looks to be a lot of missing parts. perhaps, and i don't know why this would be the case but it happens, these pics were taken before final assembly was completed? it's pretty clean though. i'd much rather see a bus like this where it is very clean all over and under, rather than some of these nice looking/"restored" busses that when you look underneath you can tell that nothing was attended to underneath. |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Wed Nov 21, 2012 7:21 am Post subject: |
agree^^^
very nice and clean bus. It doesn't worth what they ask for, though. Crazy price... _________________ 1967 Split SO-42 Dormobile |
Lou V. Samba Member
Joined: October 29, 2003 Posts: 1018 Location: Placerville,CA
Posted: Wed Nov 21, 2012 8:46 am Post subject: |
Has the wrong deck lid aswell it should be church key type.
But a very nice bus. |
