tencentlife Samba Member
Posted: Fri Apr 10, 2015 9:03 am Post subject: |
IdahoDoug wrote: |
Its down to the case, pistons/cams still in, oil pan on... |
I'll bet you can pick it up if you take that oil pan off.
I ship longblocks including f/w, pulley, w/p, and intake manifold at 260# in a crate that weighs about 40#. And that's deliberately overspec 10-20# to avoid paying overages. So 150# for a shortblock sans f/w sounds right to me.
Not every piece of LTL freight gets weighed every time but it's not unusual for a shipper to weigh it and fudge it higher so they can hit you with an overage. Overage charges are many times higher than it would have cost to write the BOL with the higher weight at the beginning, so if you ship a lot, as I do, it's better to pad up the weight a bit as a matter of routine. On LTL, charges are based much more on volume that weight, so changing the weight of a crate of fixed dimensions (volume) doesn't change the rate charged at all within a pretty liberal range, but if your submitted weight is under the actual weigh-in, or the fudged weigh-in, it can cost you.
These days it's unwise to choose a shipper in advance, because there are online brokerages where you can submit a request to many shippers and receive ranked bids in seconds from an automated bidding system. I've used www.freightcenters.com for 8 years now and have been very pleased with the service. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Fri Apr 10, 2015 7:15 am Post subject: |
morymob wrote: |
Is this without f-wheel?? |
yes, without flywheel or flexplate its about 148 lbs. |
morymob Samba Member
Posted: Fri Apr 10, 2015 4:36 am Post subject: |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Thu Apr 09, 2015 9:10 pm Post subject: |
Thanks! I bow in your general direction because that must mean you have the muscle to move the thing around and get an approximate weight!! That is my problem - too many years of sports, and bike crashes mean I have an uneasy truce with my back. It will do pretty much whatever I ask athletically, but I have learned what not to ask of it in return for its tolerance of my lifestyle. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Thu Apr 09, 2015 8:39 pm Post subject: |
I could check for you tomorrow, Doug.
I have a few engines broken down right now. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Thu Apr 09, 2015 8:03 pm Post subject: |
How about any body know weight of just the block sans heads? Its down to the case, pistons/cams still in, oil pan on, but no intake manifold, no heads, no exhaust, mustache bar off (making custom hitch), and pulley still on. Trying to decide if my steel shelving can handle it as it would save valuable floor space. Tx. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Wed Dec 19, 2012 2:19 am Post subject: |
I have been using Uship to send CHC camper roof kits with great results. Very easy to deal with and very good prices. |
SL12572 Samba Member
Joined: April 13, 2011 Posts: 270 Location: Washington
Posted: Tue Dec 18, 2012 6:22 pm Post subject: |
I'm not sure if they are located in your area, but I've been very happy with Old Dominion freight. They actually give you a call in advance to let you know when they will arrive and actually care when loading parts. |
Fritz Samba Member
Joined: July 24, 2009 Posts: 68 Location: The Big Mitten
Posted: Tue Dec 18, 2012 6:16 pm Post subject: Shipping Companies |
Any suggestions on who to use to ship a Vanagon engine? |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
jsmitch11 Samba Member
Joined: July 02, 2011 Posts: 337 Location: Seattle, WA
Posted: Wed Nov 21, 2012 10:49 pm Post subject: |
thummmper wrote: |
has anyone weighed the 4 speed trans--late vanagon? at least 100lbs, right?
I have a conversion power kit weight for my upgrade, but not for the 2.1/ taxle kit. I suspect my new equipment outweighs the volksy kit by 200.. |
If I remember right the syncro transmission was a little over 90 and the 2wd was less. I have lugged both around and they are less then 100 _________________ 1984 Vanagon Westfalia Syncro Hightop
1986 Vanagon Syncro(RIP)
1989 Vanagon Wolfsburg Whitestar Edition(RIP)
My Van syncro conversion/restoration
http://www.thesamba.com/vw/forum/viewtopic.php?t=535730&highlight=black+diamond |
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Wed Nov 21, 2012 10:39 pm Post subject: |
northernopposition Samba Member
Joined: February 14, 2007 Posts: 59 Location: fairbanks, alaska
Posted: Sat Nov 17, 2012 10:38 pm Post subject: |
Perfect. Thank you. |
insyncro Banned
Posted: Sat Nov 17, 2012 10:07 pm Post subject: |
475lbs palletized, in my experience. |
Posted: Sat Nov 17, 2012 9:47 pm Post subject: Engine Weight |
Easy question for someone out there: Approximately how much does a complete (sans muffler?) 2.1 weigh? Contemplating shipping instead of a long drive to pick up.
Thanks. |
