Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Wed Nov 21, 2012 7:11 am Post subject: Pedal Cluster Lube? |
This last summer the clutch pedal in my 68 was feeling dry and unsmooth. So I took the cluster out and completely dissassembled and cleaned it. When I reassembled, I lubed it up good with Bosch distributor grease. It felt great! But about a month ago, it started feeling dry again, like before.
So ... what is the recommended lube for the pedal cluster?
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4887 Location: Southern AB
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 631 Location: Boston Metro West
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76706 Location: Sneaking up behind you
Posted: Wed Nov 21, 2012 7:33 am Post subject: Re: Pedal Cluster Lube? |
Max Welton wrote: |
Max |
That's what I used 5 years ago and it's still nice and smooooooth. _________________ Glenn
Member #1009
#BlueSquare |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22328 Location: Kimball, Mi
fishslapper Samba Member
Joined: September 07, 2012 Posts: 137 Location: ottawa ontario
Posted: Wed Nov 21, 2012 10:42 am Post subject: |
I would like to second the praises of Super Lube !!!
Awesome stuff and it wont stain your carpet and get all over the place .
I have been putting it all over my car with great results. _________________ 1968 L50f regatta blue notchback
The 7 "p"'s !!
Prior proper planning prevents piss poor performance. !! |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Wed Nov 21, 2012 3:00 pm Post subject: |
mines all crusty feeling as battery acid got into it.
but in the past I used normal grease ie. bearing grease.
I figure moly grease could be better? |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21462 Location: Oklahoma City
Posted: Wed Nov 21, 2012 5:40 pm Post subject: |
Super lube is about all I use in non wheel bearing greases anymore. Superb stuff. Ray |
D/A/N Samba Member
Posted: Thu Nov 22, 2012 9:58 pm Post subject: |
vlad01 wrote: |
Ouch! How'd you get battery acid in your pedal assembly? |
vlad01 Samba Member
Posted: Fri Nov 23, 2012 5:29 am Post subject: |
D/A/N wrote: |
vlad01 wrote: |
leaked, then wicked up the carpet all the way to the front got into the pedals.
This is the only reason I have one Gerson pan half waiting. the other side is perfect, still all factory original paint and all. |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7526 Location: Santa Cruz
Posted: Mon Nov 26, 2012 1:05 am Post subject: |
I like to add a zerk to them... _________________ Bus Motor Build
What’s That Noise?!? |
Frodge Samba Member
Posted: Thu Aug 09, 2018 2:25 pm Post subject: Re: Pedal Cluster Lube? |
Where do you line the pedal? |
