NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Sun Nov 25, 2012 8:25 am Post subject: |
Your not supposed to flat tow with a locked column. I bought a bug that was jack knifed from it. When I picked it up the rope was still tied locking the steering wheel.
The key to flat towing is having the tow vehicles ball low enough. You can't be picking up or lifting the VW. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Nov 25, 2012 1:09 pm Post subject: |
The biggest issues with using a tow bar on a stock VW usually come from the tow vehicle.
The longer distance you have between the rear axle of the tow vehicle and the ball, the worse things get.
If you have a long distance there (like many motor homes and some long bed pick ups) when you turn right, the ball actually moves left before it begins to move right.
So the poor VW first starts to turn left and then is suddenly pulled to the right.
This can start an oscillation in the steering of the VW with the steering wheel knocking lock to lock in each direction, or it gets stuck in one direction at full lock and just skids along until you stop.
But if you know what the situation is, you can simply plan for it by slowing down and giving the steering of the VW time to react.
As for apron damage, most times that is the result of poor ball height.
Of course if you are trying to tow into a steep driveway with a dip, thats simply the fault of the operator. You have to know what your limitations are, and trying to drag the poor car through something like that is like trying to back up. it just ain't gonna work.
But if you select your tow vehicle and your ball height correctly and have a decent tow bar, you should be able to tow for hundreds of thousands of miles with out damage or difficulty. _________________ Mother Nature is a Mean Evil Bitch! |
sts9292 Samba Member
Posted: Tue Nov 27, 2012 11:51 am Post subject: |
On the subject of tow bars .... My 76 is to low to tow. Does anyone know an alternative tow bar that I can use in a lowered Type 1. My searches have not produced anthing I really could use it. |
marklee Samba Member
Joined: March 24, 2009 Posts: 821 Location: Flintshire, North Wales
Posted: Tue Nov 27, 2012 11:59 am Post subject: |
sts9292 wrote: |
why not make something that bolts to the bumper mountings, will mean removing the bumper to tow but thats not a hard job _________________ CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver |
Posted: Tue Nov 27, 2012 12:17 pm Post subject: |
Your car may still be too low to try this. But, an adjustable height ball on your hitch helps. You usually end up on the lowest setting and the tow bar is only like an inch of the ground. Not very safe. Really only good for emergencys or dragging them home a short distance. On a low car you either need a jack or park on blocks of wood to get the bar mounted onto the beam. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
Posted: Wed Nov 28, 2012 5:16 am Post subject: |
Even if you jack up the car to install the bar when you lower the jack the tow bar almost touches the road! I like the idea of using the bumper mounts, but I still can not believe that nobody has come up with a good design. mmmmm ... $$$$ ? |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Nov 28, 2012 10:15 am Post subject: |
sts9292 wrote: |
Back in the mid-sixties that is the way we towed our Porsche 356 race cars back and forth from Minneapolis to Road America.
(we were too poor to afford trailers).
The bar pivoted at the mounting bracket so the hitch could move up and down as needed. |
