What would you use to paint suspension parts? |
Roll on Truck bed Liner |
0% |
[ 0 ] |
Spray on Truck Bed Liner |
0% |
[ 0 ] |
VHT Epoxy Paint |
50% |
[ 1 ] |
Rubberized Undercoating |
50% |
[ 1 ] |
Total Votes : 2 |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5389 Location: Holland, MI
Posted: Wed May 14, 2014 4:18 pm Post subject: What do you guys used to paint suspension parts? |
I am looking for something durable to paint suspension parts with. I was thinking of truck bed liner for the front and rear trailing arms. As for the front beam I was thinking of something a little more smooth and glossy. VHT makes a black epoxy rattle can that is supposed to hold up well to the environment. I also thought of rubberized undercoating, but being rubbery, it would probably scrape off easy, don't you think?
Any suggestions you guys have are welcome.
Thanks! _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
PhillipM Samba Member
Posted: Wed May 14, 2014 4:26 pm Post subject: |
Jotun Jotamastic 87. 2k epoxy |
cgummerson11 Samba Member
Joined: May 31, 2013 Posts: 101 Location: Huntington Beach
Posted: Wed May 14, 2014 5:07 pm Post subject: |
I use rust reformer, matte black. Works great and dries almost instantly. Plus touch ups are simple and blend right in. I have nerf bars, that have gotten eaten up and I think I will rhino line those. After a couple trips, the paint is gone, but for the cage and suspension, brakes, etc the rust reformer works good. |
Jcr. Kat Samba Member
Joined: November 09, 2012 Posts: 180 Location: san diego ca.
Posted: Wed May 14, 2014 8:49 pm Post subject: |
Steel it or por-15 in black |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20365 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed May 14, 2014 9:15 pm Post subject: |
Rustoleum Semi-Gloss Black... In rattle can.... Easy to touch up if it gets scratched or nicked...
AggieZig Samba Member
Joined: March 10, 2013 Posts: 188 Location: Los Angeles, CA
wyattsdad Samba Member
Joined: March 14, 2014 Posts: 79 Location: Coventry CT
Posted: Thu May 15, 2014 2:57 am Post subject: |
walmart 99 cent or $129 rattle cans |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2616 Location: West Coast (Michigan's)
Posted: Thu May 15, 2014 4:46 am Post subject: |
Por-15 for chassis parts.
rustoleum rusty metal primer and paint for everything that can be unbolted and touched up.
There was a test done years back with all the fancy and not so fancy paints on sheets of metal. The guy just basically abused them over time and gave the results. He even left one in his pool.
Turned out that the most important part had nothing to do with the brand but rather the preparation of the metal before painting.
I was impressed with Rustoleums' performance compared to it's price. I think if you really use what ever it is hard enough, you will end up needing to repaint every couple years no matter what anyway. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8688 Location: Sunset, Louisiana
Posted: Thu May 15, 2014 6:03 am Post subject: |
Like Dale said, Rustoleum rattle cans. Easy to touch up. I used gloss black on this one.
Only drawback is it can be slow to harden. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
flashho Samba Member
Joined: August 11, 2012 Posts: 240 Location: Mulege, Baja
Posted: Thu May 15, 2014 6:18 am Post subject: |
Ditto for Rustoleum, but I brush it only to get a good coating everywhere. |
HERC Samba Member
Posted: Thu May 15, 2014 6:58 am Post subject: |
rustoleum engine enamel.
chemical resistant, 650 degrees and is some of the nicest laying paint i've used out of a rattle can _________________ Herc |
Posted: Thu May 15, 2014 8:44 am Post subject: |
Yes Por-15 is also made for chassis parts in case you didn't know, alot of budget racers use it. Rust prevention on chassis parts. |
Q-Dog Samba Member
Posted: Fri May 16, 2014 4:20 am Post subject: |
flashho wrote: |
Oops. Forgot to mention. I brushed on Rustoleum anywhere on the pan where carpet goes. Rattle cans everywhere else. _________________ Brian
'69 Dune Buggy
'70 Beetle |
Posted: Fri May 16, 2014 5:31 am Post subject: |
Vanapplebomb wrote: |
Do any stores shelve por15, or is it an order online only kind of deal?
How does por15 hold up compared to bed liner? |
Por 15 can be had at auto paint suppliers like Finish Masters (in Grand Rapids) or Wyricks(in Holland) although I think you're better off buying what you need online because most store do not carry much or all of their products.
There are several different Por15 formulas, most people just get the standard chassis black. But before you do that you gotta sand blast and then spray their Metal Ready product on the bare metal to etch and convert. I've tried with and without and there is a big difference in adhesion. The best part about Por15 is you brush it on thinking it's going to look wavy but after it cures (5hrs) it's glossy and smooth. I wish I had taken pictures now because just last weekend I did the bottom side of my gas tank.
I'm not sure how Por 15 holds up to foot traffic but I can say the parts on my rail I coated 7 years ago which have basically sat in a damp pole barn have not shown signs of deterioration at all. I think it also helps to spray a top coat on. Por 15 needs to be etched before you can top coat because it's so glossy.
I really hate things that are a hassle but I'm still using it. I keep a can in my fridge in the garage all the time. You have to be careful with it. I'm sure most people who didn't know to put two layers of plastic under the lid before resealing it have found it impossible to open the can. I did. It cures by moisture not evaporation so you got to keep it sealed as much as possible. _________________ Brian H.
Island Bumpkin Samba Member
Joined: April 22, 2013 Posts: 332 Location: Whidbey Island, Washington
Posted: Fri May 16, 2014 8:41 am Post subject: |
And it's not UV stable. Needs topcoating if it's going to be exposed to the sun.
I use Duplicolor high build enamel. It's listed as a gloss black, but it's not a super high gloss black. It's tough as nails and self leveling, but tends to run if you do too heavy a coat. I usually use a Rustoleum rust preventive primer underneath. Dries super fast.
Like Orangecrusher said, prep is everything. I'm lucky in that I have a sandblaster that is large enough that I was able to put the entire front beam (sans spindles) in and blast it. If it's a part that I'm really worried about the paint chipping off (trailing arms), I'll use a self etching primer so that the primer has both a mechanical bond (sandblasted metal) and a chemical bond (acid etch primer). _________________ Vehicles:
1971 Baja Bug, 1600dp, summer/winter/summer project
Follow my progress!
http://www.thesamba.com/vw/forum/viewtopic.php?t=556996
1988 F250 SC/LB 7.3 IDI/ZF5/Dana 50 front, Sterling 10.25 rear. 4" lift -Daily-
1976 F250 Reg cab/LB Stock 300/NP435/NP205 -Long Term Project-
Axitech wrote: |
My rail is basically my "I can't take civilized life anymore this month, so I'm going camping" vehicle |
Posted: Fri May 16, 2014 8:54 am Post subject: |
Now if I was more equipped for spraying smaller parts on a regular basis with a HVLP, I'd use the Martin Senour Premium Commercial Coating.
Primer:
http://www.napaonline.com/Catalog/CatalogItemDetai...0006419782
Paint:
http://www.napaonline.com/Catalog/CatalogItemDetai...0006419809
Hardener
http://www.napaonline.com/Catalog/CatalogItemDetai...0006419755
I used this system to paint the inside of my bug. There's a whole array of colors you can get (20-25, IIRC), and you can get the black paint and the primer in 1 and 5 gallon buckets. The paint is only available through NAPA.. Now this stuff is tough. Hard to scratch it, and the black is super glossy. If you can't get the info from your local NAPA, I can snag the info sheets and scan em in for ya.
I'll get some pics later. School firewall blocks photo sharing sites...
-Jameson _________________ Vehicles:
Follow my progress!
Axitech wrote: |
Posted: Fri May 16, 2014 9:08 am Post subject: |
Island Bumpkin wrote: |
If it's a part that I'm really worried about the paint chipping off (trailing arms), I'll use a self etching primer so that the primer has both a mechanical bond (sandblasted metal) and a chemical bond (acid etch primer). |
I just got into using the self-etching primers. I used one under the Rustoleum bed liner spray can I'm testing. It's funny, I expected to see something going on when I sprayed that primer on, but it just looks like any other primer. I do wonder if it's better to go with a medium coat with the first coat so that you get plenty of the etching chemicals or light like I do with other primers?
By the way the bed liner seems to be working good. I sprung a little leak on my gas tank vent tube that dribbled along the edge of the tank and when I wiped it up it didn't smoodge like I expected it to. _________________ Brian H.
