Posted: Tue Nov 27, 2012 2:34 pm Post subject: Valve cover gasket, brand and source |
I just pulled my valve covers to adjust the valves and since summer ~4000 miles the gaskets have shrunk enough to pull away from the ends of the covers and are beginning to weep. Years ago I used to almost never change a gasket when I checked the valves, and would reuse the same gaskets over and over for years. Today, even reusing them one time is rare because of the poor quality of the gaskets I have bought.
Anyone know a source of high quality valve cover gaskets? |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Nov 27, 2012 2:51 pm Post subject: Re: Valve cover gasket, brand and source |
Wildthings wrote: |
... Anyone know a source of high quality valve cover gaskets? |
With your knowledge and experience I assume you are using cork gaskets. I used the composite gaskets once and had the experience of them expanding in the middle and leaking great quantities of oil. Cork gaskets with Hylomar on the cover side and grease on the head side have been without a problem, but they do compress with age from the tension from the bales.
Aloha
tp |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9142 Location: Syracuse, NY
Posted: Tue Nov 27, 2012 3:06 pm Post subject: |
I just plan on replacing them every time I take one off. Plan on it costing you about $4 every time you adjust your valves. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
RocketSurgeon Samba Member
Joined: May 26, 2005 Posts: 442 Location: Roseville, CA
Posted: Tue Nov 27, 2012 9:15 pm Post subject: |
Do you run these? What's your feedback? $17 isn't TOO outrageous to gamble on. _________________ 69 Westy |
SGKent Samba Member
Posted: Tue Nov 27, 2012 9:16 pm Post subject: |
elring but you have to find some that are new and not hardened by age. I found this out the hard way when I got some old stock. When new they are softer and seal better. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Hoody Samba Member
Posted: Tue Nov 27, 2012 10:31 pm Post subject: |
x2 on Elring. I would get them from Jake. He is crazy about quality control and will not sell old ones. Len Hoffman told me when I asked what he did....He told me to use an old set of heads to actually glue the gaskets to the covers versus Hylomar. Once the glue set up on the gaskets mounted to the old heads. You then put the covers on the new heads. Hope this helps. |
The claim"FITS ALL VW 4-CYL AIR-COOLED ENGINES" comes up short when you have a T4. |
Posted: Tue Nov 27, 2012 10:33 pm Post subject: |
Posted: Tue Nov 27, 2012 10:38 pm Post subject: |
Wildthings wrote: |
Look under Porsche _________________ 69 Westy |
Posted: Tue Nov 27, 2012 10:48 pm Post subject: |
RocketSurgeon wrote: |
Wildthings wrote: |
Look under Porsche |
Cool, thanks |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Tue Nov 27, 2012 10:56 pm Post subject: VC Gaskets |
I have valve cover gaskets that are 30 yr's + still in their wrappers and find
they have No shrinkage Period.
and yes, if you leave them in the elements they will become harder and start to shrink but, they are still better quality than the newer Reintz that come in
the gasket set.
You can put the cork gaskets in Hot water and they will come back to form
but, again the width of the gasket is Not the same as the older one's.
you now have to bend the center tab quite alot to keep th gasket in place
even if you use some type of sealer.
Keep the gaskets and seals in a sealed container and out of the elements. _________________ V.W.owner since 1967 |
Posted: Tue Nov 27, 2012 11:02 pm Post subject: Re: VC Gaskets |
I wonder if new oils are part of the problem with shrinkage? Twenty plus years ago I would run 30wt during the summer and 10w30 in the winter. Today it is more apt to be a 5w40 synthetic year around. Maybe the thinner oil or it being synthetic negatively affects the gasket? |
curtis4085 Samba Member
Posted: Wed Nov 28, 2012 3:46 am Post subject: |
I use VR Gaskets and have done both - glue on cover side and oil head side and the usual - just oil on head side. The glued one I have taken on and off atleast a dozen times now and know leaks. The just oiled ones had to be replaced every time.
Just my experience. _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Wed Nov 28, 2012 5:55 am Post subject: |
honestly I ahve never bought a T4 valve cover gasket, aside from a full engine gasket set. 30k + on my bus, regular valve adjustments and all, I oil each side during R&R, so either I am lucky or the gaskets in those sets are quite nice, cork of course. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Mon Apr 29, 2013 5:08 pm Post subject: |
yep those are cork..
I buy Victor Rienz cork _________________ Special Thanks to:
Ian Samba Moderator
Posted: Mon Apr 29, 2013 5:17 pm Post subject: |
I started using SABO brand gaskets, and they are way way better than the other ones. I think the other ones are too skinny or something. These ones fit snug between the valve cover and the gasket holder tab. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
refsta Samba Member
Joined: April 23, 2014 Posts: 4 Location: Land of Goshen
Posted: Tue May 27, 2014 7:41 am Post subject: |
Wildthings wrote: |
Wildthings wrote: |
Cool, thanks |
I was wondering if anyone has actually installed these silicon gaskets from realgaskets.com and how they are working out. I'm considering getting a set for my T4. _________________ Cheers!
~Ref
Now - 1974 Westy
Then - 1978 Westy |
forkzilla Samba Member
Joined: November 20, 2009 Posts: 190 Location: North Central Ohio
Posted: Tue May 27, 2014 8:52 am Post subject: |
I have a set on the lycoming engine in my airplane and they stay very dry. Just make sure they are installed dry as any lubricant or sealer tends to make them squirt out slightly. |
