Help ID Throttle Bodies?
risk
risk is offline
PostPosted: Wed Nov 28, 2012 7:52 am    Post subject: Help ID Throttle Bodies? Reply with quote
Scored these off Ebay, was hoping someone on here could tell me who made them?
44mm bores, IDF pattern, hard anodized.
mark tucker
mark tucker is offline
PostPosted: Wed Nov 28, 2012 7:55 am    Post subject: Reply with quote
not sure, but there look like they should be cleaned,repaired if needed and put into usage...fast!!!
risk
risk is offline
PostPosted: Wed Nov 28, 2012 8:14 am    Post subject: Reply with quote
I was already playing around with putting them on the 67. Trying to figure out what intake manifolds I need, since I don't run superflow style heads... They seem to fit OK just sitting on the superflow manifolds in the pic, which are pretty short. I run a 36hp style shroud so I have plenty of room.
Boolean
Boolean is offline
PostPosted: Wed Nov 28, 2012 9:35 am    Post subject: Reply with quote
Dunno. No numbers/letters at all? Don't forget to use velocity stacks inside those plenums...
I strive for perfection. Excellence will not be tolerated!
Build thread here:
http://www.thesamba.com/vw/forum/viewtopic.php?t=529379
risk
risk is offline
PostPosted: Wed Nov 28, 2012 9:48 am    Post subject: Reply with quote
No numbers, markings etc... Very well built though.
NJ John
NJ John is offline
PostPosted: Wed Nov 28, 2012 9:50 am    Post subject: Reply with quote
They look like modified mechanical TB's. ??
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
risk
risk is offline
PostPosted: Wed Nov 28, 2012 10:00 am    Post subject: Reply with quote
Maybe, but the anodizing goes down in the injector holes some. I suppose they could have been modified for the injectors, then anodized.
Anyone have any recommendations on some intakes that will bring them inboard some?
Boolean
Boolean is offline
PostPosted: Wed Nov 28, 2012 10:26 am    Post subject: Reply with quote
Some parts look like a local supplier, but it's unlikely to see them in USA.
I say use them! (With velocity stacks - they're wort 100 horses on a turbocharged 2 litre engine)
Build thread here:
mark tucker
PostPosted: Wed Nov 28, 2012 8:40 pm    Post subject: Reply with quote
I wouldnt wory about the superflow intakes,they will work fine,dont change them. Shocked yup you gessed it, get a set of superflow heads!!or cb comp eleminators. Cool
risk
risk is offline
PostPosted: Thu Nov 29, 2012 8:47 am    Post subject: Reply with quote
I guess my picture was decieving Mark... it's not a race car by any means. Shroud and tins are off because I'm building a turbo header and I need to pull the motor to fix an oil leak.
I'm thinking about a pair of type 3 intakes but will have to ditch my denso coil on plug setup.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Thu Nov 29, 2012 9:41 am    Post subject: Reply with quote
Man, something like that is exactly what I need for the 2366 T4 engine. Wanna make a quick 200%? Laughing
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
mark tucker
PostPosted: Thu Nov 29, 2012 10:46 am    Post subject: Reply with quote
what does racecar have to do with it??
mark tucker
PostPosted: Thu Nov 29, 2012 10:47 am    Post subject: Reply with quote
if I had the $$ for a compleat set of the cb dominators they would be on my street bug.
risk
risk is offline
PostPosted: Thu Nov 29, 2012 11:53 am    Post subject: Reply with quote
This thread is starting to bring the suck.
Anyone know who might have made these?
supersuk
supersuk is offline
PostPosted: Thu Nov 29, 2012 11:58 am    Post subject: Reply with quote
I noticed that the injectors spray onto the throttle plate...not a very good design. Not familiar with those though.
68 Fastback Build: http://www.thesamba.com/vw/forum/viewtopic.php?p=5396323#5396323
View user's profile Send private message Send e-mail AIM Address MSN Messenger Gallery Classifieds Feedback
risk
risk is offline
PostPosted: Thu Nov 29, 2012 12:02 pm    Post subject: Reply with quote
I think thats why they have the holes in the throttle blades. Probably didn't idle very well.
supersuk
supersuk is offline
PostPosted: Thu Nov 29, 2012 1:18 pm    Post subject: Reply with quote
Holes in the throttle plate will give you a pretty high idle with no way to get it down...how big are the holes?
risk
risk is offline
PostPosted: Thu Nov 29, 2012 1:21 pm    Post subject: Reply with quote
About 3/32"
mark tucker
PostPosted: Thu Nov 29, 2012 1:46 pm    Post subject: Reply with quote
then put the injectors in the intakes&either plug the bodys or fogger them. they could of been for a constaint spray like a tb setup, not a timed spray.but who knows.they might just be upside down!!
Bill271
Bill271 is offline
PostPosted: Thu Nov 29, 2012 5:23 pm    Post subject: Reply with quote
Those are prob Hilborn or Kinsler possibly auto craft
