Whining trans under load
cmvan
cmvan is offline
PostPosted: Thu Nov 29, 2012 11:25 am    Post subject: Whining trans under load Reply with quote
Pulled my trans to check out the ring gear because of whining under acceleration. (needed a clutch too). Here is what I found.
also found these metal parts
I am far from an expert on ring and pinion wear, but the ring gear looks worn to me and am guessing that the metal parts are from a broken circlip somewhere deep inside.
The trans came from an 85 weekender w/ 100,000 miles on it.
Any one have a clue?
81 westy
88 westy ahu e-tdi
11 tdi jsw
Gauche1968
Gauche1968 is offline
PostPosted: Thu Nov 29, 2012 12:01 pm    Post subject: Reply with quote
I can't comment on what you found, but I had a trans whining under load once. Readjusting the shift linkage took care of it.
1984 Vanagon GL
1984 Vanagon Westy
gears
gears is offline
PostPosted: Thu Nov 29, 2012 12:10 pm    Post subject: Reply with quote
That's a piece of the main circlip holding the mainshaft snugly in its ball bearing. This is from a heat build-up area in your transaxle, adjacent to 4th gear. I think you're more aware than the average guy, and have caught a developing problem in time. I'd suggest a rebuild now before major parts are ruined. The R&P are probably still OK.
aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
WWG1WGA
presslab
presslab is offline
PostPosted: Thu Nov 29, 2012 12:18 pm    Post subject: Reply with quote
Hard to tell, but that ring gear looks ok to me. The metal shavings look somewhat normal.
You know your answer though, that broken circlip is no bueno. You're also on borrowed time with the 3/4 slider hub. It needs to be torn down and rebuilt; I had mine done at Rancho this last time and it's working great.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
IdahoDoug
IdahoDoug is offline
PostPosted: Thu Nov 29, 2012 6:43 pm    Post subject: Reply with quote
Yep, Gears is dead on, and I wouldn't bet against him being dead on right down to that main gear circlip. Though I'm curious where you found the chunks - they must have come out the drain, eh? I think you caught this before it got ugly.
So, same noise in all gears?
DougM
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
cmvan
cmvan is offline
PostPosted: Fri Nov 30, 2012 10:49 am    Post subject: Reply with quote
Yep same noise in all gears. Noise gets louder as load increases. Those chunks were stuck to the magnet... wonder where the rest of the cerclip is? Hopefully they did not damage any thing else. I am buying a used trans axel to replace this one. And will tare this one down my self, we will see if I ever get it back together.
81 westy
88 westy ahu e-tdi
11 tdi jsw
Franklinstower
Franklinstower is offline
PostPosted: Fri Nov 30, 2012 11:28 am    Post subject: Reply with quote
I just got the same whine. I pulled my trans to check out a spare I had. The spare whined in 1st and 2nd. So I put the original trans back in. It immediately started whining in all gears.....I don't understand it. I haven't pulled it back out yet but will soon. I have a 3rd trans to try. Just found at the pick n pull. 89k original 1986 model - I am sure it has the weak 3/4 slider though.
Anyway I look at it, one of my three will need a full rebuild.
'89 Westy - EJ25/22 Frank 4.44 5mt
cmvan
cmvan is offline
PostPosted: Mon Dec 03, 2012 3:42 pm    Post subject: Reply with quote
well I did not do so well on my used trans purchase. Any one know if there is anything that can be done about this?
81 westy
88 westy ahu e-tdi
11 tdi jsw
goffoz
goffoz is offline
PostPosted: Mon Dec 03, 2012 9:29 pm    Post subject: Reply with quote
Shocked Laughing Sorry...really Embarassed
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Dec 03, 2012 9:45 pm    Post subject: Reply with quote
Yeah not as bad as it looks.
You need to take apart.
Bead blast.
Then assemble and blue to see the mesh.
Face it, you are in for a rebuild.....
