koho60 Samba Member
Joined: February 21, 2003 Posts: 133 Location: Southern Utah
Posted: Sat May 07, 2022 7:47 pm Post subject: Stock vs Weber |
I think my stock carbs 34PDSIT 2/3 are shot! What is a good replacement? _________________ Do you walk to school or do you take your lunch? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat May 07, 2022 8:36 pm Post subject: Re: Stock vs Weber |
Small webers with quality linkage _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Samba Member
Posted: Sat May 07, 2022 10:42 pm Post subject: Re: Stock vs Weber |
down the rabbit hole we go _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Mober Samba Member
Posted: Sat May 07, 2022 11:01 pm Post subject: Re: Stock vs Weber |
SGKent wrote: |
down the rabbit hole we go |
Ha just repost what you told me this week about rebuilt vs new |
Abscate Samba Member
Posted: Sun May 08, 2022 1:12 am Post subject: Re: Stock vs Weber |
koho60 wrote: |
I think my stock carbs 34PDSIT 2/3 are shot! What is a good replacement? |
Rebuilt PDSIT by an experienced carb builder _________________ .ssS! |
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2539 Location: Plattsburgh, New York
Posted: Sun May 08, 2022 5:54 am Post subject: Re: Stock vs Weber |
I would consider having your carbs rebuilt by Tim at Volkzbitz. I used to hate those carbs when I got my bus in the early 90’s. They were already worn out and I didn’t understand them. I put them in a box until a few years ago when I sent them to Tim. They looked fantastic when they came back and cost less than a budget set of dual carbs. Turn around time was quicker than expected. Tim asked if I wanted the metal parts replated and I decided to just let Tim do his thing. It was awhile before I put them on as I still was unsure about my ability to set them up.
Last summer, I finished up a full engine rebuild and decided that it was time to give them a try. Surprisingly, they were not that hard to set up. I only did the initial zeroing of the carbs, eyeballed the linkage and did minimal adjustments once I started them up. I really like them. In late December, I did a 600 mile round trip to northern Maine and the cold weather performance was a pleasant surprise. They work well with my 2l engine and the original 003 automatic transmission. The stock air cleaner is much quieter than the air filters on aftermarket carbs and allows me to use the original preheat and plumbing for the oil breather and charcoal canister. I really enjoy no longer having fuel and crankcase smells. I know I would get more power with bigger carbs, but I have plenty of power for reliable highway driving on fairly close to stock engine. The stock linkage is also very straightforward and well made compared to the typical aftermarket linkage found on carb kits.
I have also run 34 ICT’s and a single progressive. Both were quite workable, but lacked the drivability of the originals. I wouldn’t really recommend the PDSIT’s for a performance engine build…it also depends on how you use your bus. One of the reasons that I suggest that you consider them is that they are already on your bus. More than likely you have all or most of the original parts, which puts you ahead of buying them in a box of missing hard to find parts. Just something to consider.
