Desertbusman Samba Member
Posted: Tue Dec 04, 2012 12:31 pm Post subject: |
Have someone apply pedal pressure while you crack the rear line at the M/C and see what kind of squirt you get, pressure and volume. Don't hold me responsible for the mess or damage from fluid spraying everywhere You could also do it to the M/C front line connection for comparison.
And obviously you would have adjusted up the rear shoes? _________________ 71 Superbug
71 Westy
Last edited by Desertbusman on Tue Dec 04, 2012 12:34 pm; edited 1 time in total |
SGKent Samba Member
Posted: Tue Dec 04, 2012 12:33 pm Post subject: |
I too am leaning towards a bad new master. I once had 10 in a row from a well known supplier on a Fiats. They also supplied for VW back then. I was ready to pull my hair out. I went to another brand on the" oh what the heck have I to lose" and it worked. I put one of the bad ones back in and it failed. I put the good one in and it worked. I guess someone had a bad day at the factory the day they were made.
Are the fronts releasing properly? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Tue Dec 04, 2012 12:57 pm Post subject: |
I sure wonder about the missing fluid from the reservoir. Is the owner
really that ignorant?
He's a really nice guy but pretty new to buses and he probably never checks things like reservoirs. I just happened to notice when he dropped it off that the brakes felt funny.
The symptoms are the same with the new and the old MC. I have adjusted the rear shoes. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Dec 04, 2012 1:22 pm Post subject: |
Were the shoes arched to the drums when you did it or are there so few miles on the shoes that contact area is still very minimal? _________________ 71 Superbug
71 Westy |
Posted: Tue Dec 04, 2012 2:02 pm Post subject: |
Desertbusman wrote: |
Were the shoes arched to the drums when you did it or are there so few miles on the shoes that contact area is still very minimal? |
I'm pretty sure I replaced the shoes and the brake fluid about 15 months ago and that would be around 1500 miles. The shoes weren't real loose but I did tighten them up the other day. Of course I will readjust them when I get the drums back on. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Tue Dec 04, 2012 5:32 pm Post subject: Brake pressure regulator |
Mike (DBM) has posted this a couple of times if it helps
Posted: Tue Dec 04, 2012 5:52 pm Post subject: |
aeromech wrote: |
The shoes weren't real loose but I did tighten them up the other day. |
But the real question is are the shoes getting full area contact? I put on a set of new shoes and a couple thousand miles later the wear pattern showed the contact surface was only about 50% of the full friction surface. It was the mid area and towards both ends it wasn't making contact. Crappy shoes that once they would have more wear would have been 100% contact. But I replaced them. We used to acurately arc the shoes to the exact measurement of the drums. But a lot of good old things we don't do anymore.
Bottom line is that stopping power is related to friction material contact area. And shoes properly seated, full contacting, and adjusted need very little quantity of fluid to actuate them. _________________ 71 Superbug
71 Westy |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Dec 04, 2012 5:53 pm Post subject: |
did you shove the shoes fore and aft to see if the pistons were stuck?
how about a sticky/rusted pad? i have seen brake pads get hung up if the rust is bad in the slider area, and actually bend the pad.
if you posed it, i'm sorry. 'nother long day... _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Dec 04, 2012 6:13 pm Post subject: |
Well guys, once again I've taken something simple and gone for the most difficult fix first. It was a bad rear wheel cylinder. Today I rebuilt both of them and found one with considerable pitting. Luckily I had a good used spare. So once rebuilt and bled and adjusted I spun up the rears and hit the brakes. They worked great. Then I had my buddy spin up the fronts and they worked good too although the front left had some resistance so maybe the caliper is getting bad. Then I drove it and the brakes work great. I'm sure the owner will be very happy when he feels the difference.
I'd like to thank everyone for their input especially those who pointed me towards the real problem. It took some beating to get it in my head but the big thing is that I finally looked at them and I eventually won the battle. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Tue Dec 04, 2012 6:22 pm Post subject: |
aeromech wrote: |
... I'd like to thank everyone for their input especially those who pointed me towards the real problem. It took some beating to get it in my head but the big thing is that I finally looked at them and I eventually won the battle. |
Surround and conquer.
Malama Pono
Aloha
tp |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Dec 04, 2012 6:26 pm Post subject: |
High five!, sometimes the little things you least suspect are the biggest offenders, symptoms added to my mental rolodex of suspects for symptoms, thanks _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Dec 04, 2012 6:40 pm Post subject: |
Symptoms, yes. I never would have thought of a wheel cylinder. Usually a bad one presents itself with a large puddle at the base of the tire and streaks down the inside. In this case it proved to be elusive. I believe from now on I will strongly consider rebuilding wheel cylinders when I do brake jobs. I get the kits for less than $5 and try to keep a few in stock. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Dec 04, 2012 7:23 pm Post subject: |
aeromech wrote: |
I get the kits for less than $5 and try to keep a few in stock. |
glad you found it. where do you buy your kits? years ago, i came across a bunch of ATE rebuild kits, but i am pretty low _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Dec 04, 2012 7:27 pm Post subject: |
Try Autohausaz. They have great prices on all kinds of VW stuff. Shipping is free over $50 and no sales tax. In the past I've gotten delivery the next day but lately it's been taking longer and I don't know why. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Dec 04, 2012 7:40 pm Post subject: |
that's a great place for what it is. Real limited selection of parts but they seem to have the basic parts we need. It's best to know what brand and P/No of what parts you want first before you go there and their prices usually are lower than anywhere else. They used to have a will call but it's cheaper to wait a day instead of spending the time and gas.
glad you got the brakes straightened out. _________________ 71 Superbug
71 Westy |
Posted: Tue Dec 04, 2012 7:54 pm Post subject: |
I've found great prices there. Usually they give you several choices of quality including OEM parts. The free shipping is a smoking deal for heavy parts. I bought 4 gallons of Honda approved power steering fluid once for $42. Before that I was paying $5 per pint at Autozone. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Tue Dec 04, 2012 8:59 pm Post subject: wheel cylinders |
Gary, Glad this worked out without anymore head scratching.
I went thru this same crap in the summer with my bus when all i wanted to do was change the trailing arm bushings and reset the ride height.
After putting it all back together and flushing the brakes, which I do every year by the way and going thru an extra pint of B.Fluid and finding the Rt
rear not bleeding very well I ordered 2 rear hoses and still had the pedal problem
Took the cylinder off and found one of the cups was torn and appeared to have melted. 'I am' and will be Apprehensive about the pressure regulator
but, have never seen one fail on a bus as long as the sytem is in good order.
And yepp...I too buy alot of parts from AutoHaus az. and have for many years. Cheers _________________ V.W.owner since 1967 |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Wed Dec 05, 2012 4:05 am Post subject: |
Bravo Gary!!!!!! Yeah I've always gotten good parts from Autohauz for my Passat, haven't tried any of the vintage VW stuff. Glad you got the problem fixed. Your topics always wind up being a positive learning experience for all of us here on Samba _________________ '66 Beetle
2011 Hyundai Elantra Touring |
SGKent Samba Member
Posted: Wed Dec 05, 2012 7:00 am Post subject: |
awesome work Gary! _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Dec 05, 2012 5:31 pm Post subject: |
aeromech wrote: |
Well guys, once again I've taken something simple and gone for the most difficult fix first. ... I eventually won the battle. |
Aloha
tp |
