geodude Samba Member
Posted: Sun Dec 02, 2012 8:21 pm Post subject: Cheap and easy backup light upgrade |
Thought I would share my recent upgrade to my backup lights since I didn't see anything like it when I searched. This is an easy upgrade and cheap. As anyone who has opened up their tail lights knows there is no reflector for the back up lights. The housing is just black plastic, except for a galvanized steel plate on the top. That struck me as stupid; most of the light of the bulb would be absorbed by the housing and only a bit goes out the back. So this is what I did.
1. Found something reflective that wasn't conductive on one side. In my case I used that really shiny bubble insulation (I had some laying around so really cheap). To make it non-conductive on one side I ripped one facing off (seen rolled up).
2. Cut the sheet to an appropriate size. The housing isn't totally rectangular so I made it wide enough to fit in the space near the bulb. I trimmed the length so I could bend it to cover the bottom of the housing and up the back to the galvanized sheet at the top. I didn't cover the top as I figure that is were most of the heat would end up.
3. Cut a hole in the back centered on the sheet so the bulb could go through.
4. Slipped the sheet over the bulb bent it to covert the bottom of the housing and reassembled the tail light.
Here is a comparison shot showing one side "upgraded". It is significantly brighter. Not sure why it rotated when I posted this pic, but the bottom one is the upgraded light. Total time to do this upgrade about 30 minutes.
I wouldn't recommend using the same reflector material for lights that stay on continuously, it may melt. But for something that stays on for only a minute or so I thought it would be fine. _________________ 1988 GL Camper
1991 Multivan — the basket case |
purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Sun Dec 02, 2012 8:26 pm Post subject: |
HVAC foil tape works better |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Sun Dec 02, 2012 8:47 pm Post subject: |
purplepeopleeater wrote: |
3M 3311 _________________ Westy HID Projector Retrofit |
Posted: Sun Dec 02, 2012 8:55 pm Post subject: |
The stuff was free and sitting there But good ideas, maybe I'll do the side of the housings with the tape. _________________ 1988 GL Camper
seanjenn Samba Member
Posted: Mon Dec 03, 2012 10:12 am Post subject: |
I was just geting ready to ask about that.
How about putting that tape behind all of the bulbs? _________________ 1987 GL Sunroof
2.1 4 spd |
bluebus86 Banned
Posted: Fri Dec 02, 2016 9:15 pm Post subject: |
seanjenn wrote: |
How about putting that tape behind all of the bulbs? |
Yes put metalized tape in all the rear light housings, do all of the housing (except of course the lense!!!) I used the metalized duct type tape (aluminim tape) used tweezers to get it inside the lense housing on the sidewalls and on the lamp holder part, keeping clear of the electrical connectors. the improvement in brightness is huge!!! the inside is black in stock form, the aluminjzed tape does wonders for brightness, it even makes the red reflector that has no bulb in it a better reflector (this unused reflector supposedly is for a fog light option)
I went one further and added a bulb and connectors in the unused fog lamp socket and hooked it up to run with the tail lamp.
so get some metalized tape and go for it, it is sight to be seen better with _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Fri Dec 02, 2016 9:53 pm Post subject: Re: Cheap and easy backup light upgrade |
The HVAC stuff I have is true aluminum. It's much thicker than tinfoil. You peel of the protective paper and there'a adhesive on the back. I'd call it a tape-ized metal. Its easy to find on Amazon, search Aluminum Tape. http://a.co/fjvQrh9 _________________
....KTMs, GasGas, SPOT mtb |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Fri Dec 02, 2016 10:02 pm Post subject: Re: Cheap and easy backup light upgrade |
Thanks for bumping this bluebus86.
Hard to believe there's nothing reflective in the housing. Such a simple fix. |
Posted: Fri Dec 02, 2016 11:43 pm Post subject: Re: Cheap and easy backup light upgrade |
I would guess that there are some LED bulbs out there that have a directional output that would make having any reflector unnecessary. |
jimf909 Samba Member
Posted: Sat Dec 03, 2016 12:22 am Post subject: Re: Cheap and easy backup light upgrade |
^^^ I'm leery of LED lamps used in fresnel fixtures designed for specific incandescent lamps. The LED may be brighter in a narrow angle but it's much less visible slightly off center because the light source is not positioned correctly for the fresnel lens. Most noticeable to me are motorcycles with LED lamps in old-school fixtures and how much less effective they are than with the incandescent lamps they were designed for. And both are much less effective compared to purpose-built LED tail lights. _________________ - Jim
Abscate wrote: |
bluebus86 Banned
Posted: Sat Dec 03, 2016 9:47 am Post subject: Re: Cheap and easy backup light upgrade |
Sodo wrote: |
The HVAC stuff I have is true aluminum. It's much thicker than tinfoil. You peel of the protective paper and there'a adhesive on the back. I'd call it a tape-ized metal. Its easy to find on Amazon, search Aluminum Tape. http://a.co/fjvQrh9 |
Thats the stuff!!!!!, peel and stick aluminium tape can be had at many hardware stores. I even lined the front turn signals with it, trick is you cut it to small sizes and use treezers to feed it in thru tbe light bulb hole. be sure to wash and dry the hosuing first to assure best adhesion. the tape also brightens up the lamp fixtures when the lights are off, makes them better reflectors for say when the van is parked at night and other cars hit it with a headlight. visability is where it is at.
my lights are now so bright I have to wear shades. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Dec 03, 2016 11:46 am Post subject: Re: Cheap and easy backup light upgrade |
Wildthings wrote: |
The GoWesty kit has directional and stalk mounted LED's. It is an improvement over the stock bulbs, but your going to pay for it if you've seen the price of the kit.
Adding the foil or metal tape works too. The foil vs. tape is that the aluminum foil does have a shinier reflective surface than the tape you just can't attach it as easily as the tape. _________________ This free advice is worth exactly what you paid for it.
bluebus86 Banned
Posted: Sat Dec 03, 2016 12:01 pm Post subject: Re: Cheap and easy backup light upgrade |
Wildthings wrote: |
the tape greatly increases relectivity even when the lamps are off. they will be much brighter with the tape when a headlamps is shined on them, great for increased visability when parked and lamps are off. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Dec 03, 2016 12:03 pm Post subject: Re: Cheap and easy backup light upgrade |
jimf909 wrote: |
^^^ I'm leery of LED lamps used in fresnel fixtures designed for specific incandescent lamps. The LED may be brighter in a narrow angle but it's much less visible slightly off center because the light source is not positioned correctly for the fresnel lens. Most noticeable to me are motorcycles with LED lamps in old-school fixtures and how much less effective they are than with the incandescent lamps they were designed for. And both are much less effective compared to purpose-built LED tail lights. |
Using the GoWesty kit I have not noticed the off center problem. I think they did their research fairly well on the kit and it is reflected in the price no pun intended.
The GoWesty LED kit is directional as I said, but that is only for some of the bulbs and those bulbs have lenses on them which could very well be giving a wide pattern.
The other bulbs in the kit are on a stalk of led's so it is trying to give 360° output.
You can see the bulbs on the website:
http://www.gowesty.com/product-details.php?v=&id=23624
For the best of it this LED kit and adding the metal tape would be even more effective. _________________ This free advice is worth exactly what you paid for it.
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Dec 03, 2016 12:16 pm Post subject: Re: Cheap and easy backup light upgrade |
That's a terrific idea - love it. Cheap fix of the week and it's a safety improvement which is my favorite place to spend money and time. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
