bugpartslou Samba Member
Posted: Mon Dec 10, 2012 8:20 pm Post subject: Need Help Identifying This Muffler |
Not a 36, as far as I can tell, looks factory, one heater box connector is shorter than the other and has not been cut, no flange for the heater box clamps, it's the same width as a 36 or 40, what is it for?
stale air Samba Member
Joined: August 23, 2007 Posts: 5148 Location: Senoia Ga, formally NorCal
Posted: Mon Dec 10, 2012 8:36 pm Post subject: |
Looks like an early duel tip "non flared" 36hp mufffler. _________________ WANTED: Henry Veale Santa Rosa plate frames
Posted: Mon Dec 10, 2012 8:40 pm Post subject: |
thought it was 36 also, but the heater box connecting pipes don't reach the heater boxes on a 36 (tried it on a 36 with stock heater boxes that I just finished building). Cylinder head width is correct. The 36 mufflers I have seen seem to have much longer heater box connector pipes. |
Posted: Mon Dec 10, 2012 8:53 pm Post subject: |
The passenger side is always shorter than the drivers side, but wow, your right, both sides on yours looks to to short.
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Dec 25, 2012 5:58 pm Post subject: |
If it doesn't reach std 36hp heater boxes, then it is probably 40hp stale air. The J pipes on the 40hp ones are 2" longer than 36hp. _________________ John Henry
'57 Deluxe
'56 Single Cab |
templeofspeed Samba Member
Joined: June 06, 2007 Posts: 279 Location: Central midwest
Posted: Wed Dec 26, 2012 8:15 am Post subject: |
Looks like 40hp heat riser flanges in the full size 1st picture... also looks like someone cut all the bell-mouths off. |
Posted: Wed Dec 26, 2012 8:26 am Post subject: |
bell mouths were not cut off as the stale air engine doesn't use them. looks like the muffler was made that way, not hacked.
Posted: Wed Dec 26, 2012 8:42 am Post subject: |
bugpartslou wrote: |
bell mouths were not cit off as the stale air engine doesn't use them. |
I believe you are incorrect. Pre 1958 36hp mufflers did not have the flares for the connection to the heater boxes, but did have for the tail pipes (except for the very earliest twin tailpipe mufflers~55 or so). All factory spec 40hp stale air mufflers had the flares.
The muffler you have pictured may not have had the flares cut off, but if you think about it, how is it supposed to clamp? I don't see any slots to make the original early flat clamps work.
Maybe the muffler shop is supposed to weld the thing on...
Really not trying to start a heated debate. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Dec 26, 2012 9:10 am Post subject: |
y'all are forgetting the major difference between a 36 and 40 hp muffler, the heat riser bolt pattern
Not a clear shot posted but it looks like a 40 hp muffler _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Wed Dec 26, 2012 9:32 am Post subject: |
ok I guess I'm incorrect. That's why I asked for help. Yes, the pre-heat flange matches a stale air 40 muffler perfectly. |
