420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Tue Dec 18, 2012 12:30 pm Post subject: |
If the wound spring on the shaft is tight, & you have the pulling spring to the arm to the plenum your good there.
You've got a 4 speed so the kick down arm isn't hanging up on the side of automatic tran arm.
You mentioned you re-shaped the TPS arm, and this I think is where the problem might be.
*the metal arm on the switch would "fall" when held in the way its on the bus. so i gave it a tweak. i tried to adjust per Bently but the throttle shaft, tps lever and cam are worn. this coming tax refund ill get new ones.*
( not to say that there isn't still a vacuum leak somewhere to--the electrical tape at the TB seal is kinda hoakey )
*I totally agree so i got a new TB seal coming my way from you.*
That switch, even though you can hear it clicking means one thing only--it's a working micro switch.
*it seems to be working ok since the horrible bog is pretty much gone.*
You have to set it up right first--a peliminary set up, and then adjust it so it clicks on & off at the right time.
*i will buy an adjuster cam from you soon....holding out since my future TB may have one.*
Did you some adjusting on the throttle stop screw too?
*yes feller gauge .004 closed TRIED to set .010 open but the switch arm and worn cam would not permit, so i got it as close as possible...took about an hour to find a decent spot.*
Can you feel the ICU vibrating when you have the engine running?
*yes i can, but i makes the engine take too long to throttle down and im draging the clutch when shifting.* _________________ once you realize im not impressed we will get along just fine |
Terry Kay Banned
Posted: Tue Dec 18, 2012 1:17 pm Post subject: |
The seal is en-route.
The altered arm angle to the cam is more than likely the biggest problem.
The cam is worn, the arm is in a position where maybe it isn't opening & closing at the right time---
What I would do while I was waiting for the new seal to arrive is to get the TB off of the engine & while it's in your lap or on the bench , verify that the trottle plate is cloing all the way.
Verify that the TB shaft isn't shot & wobbling in the bore.
Once you get that ironed out,I'd get a new TPS cam and start over on the adjustment process.
This will get you closer to a properly adusted TPS than you have now. _________________ T.K. |
Posted: Tue Dec 18, 2012 2:07 pm Post subject: |
Terry Kay wrote: |
This will get you closer to a properly adusted TPS than you have now. |
last night i adjusted the switch over and over, the switch has a metal lever that dropps since its old, upside down i can get it to open at .10 but when i turn it over it wont close . the butterfly also looks like its scraping the wall as it closes and opens, i can push it back hard and this will drop the idle. im guessing buy used good TB, new tps, new cam, the shaft wont wobble, just move up and down a little. thanks for everyones help. So is idle with ICV connected or disconnected? _________________ once you realize im not impressed we will get along just fine |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Tue Dec 18, 2012 3:07 pm Post subject: |
A couple of new shaft seals would help out as well, the ones in your T/B are probably factory and hard as a rock which provide no sealing at all which is a small vacuum leak.
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
Terry Kay Banned
Posted: Tue Dec 18, 2012 3:29 pm Post subject: |
If the switch arm is falling, you've got bigger problems than you thought.
The switch is No Longer Available from anywhere, other than a workaround also looks like fix from the Van-Cafe.
If the stock switch is all done, your going to have to go to this fix if you want the idle problem to get ironed out.
There is no other way to get this done right now. _________________ T.K. |
Posted: Tue Dec 18, 2012 3:34 pm Post subject: |
whip618 wrote: |
Phil |
i have yet to find some. or are they a common o ring with a specific size? show me the Vanagon gurus.
as for the throttle body closing, it is common to close and then still have a "hair" left to close. also is there a chance i bent the plate when i was pushing the throttle to close with my hand?....no gorilla strength but i did have to help it. _________________ once you realize im not impressed we will get along just fine |
Posted: Tue Dec 18, 2012 4:04 pm Post subject: |
New seals are NLA, I have a large number of good used ones saved from the throttle bodies that I rebuild, if your interested in a couple pm your address and I will send you several.
The sticking is usually caused from the throttle plate wearing a groove into the bottom of the throttle bore.
Depending on which throttle body casting you have the groove can be much deeper causing the problem to be worse and to add to this since both the throttle plate and throttle body are aluminum they tend to stick together or gall which is why the throttle plate will not return to idle every time you let off the throttle.
I also have many good used TPS if interested.
Posted: Tue Dec 18, 2012 4:12 pm Post subject: |
whip618 wrote: |
Phil |
mine is like that , but more on the side not at the shaft, any fix for this or is it done? as for the switch im interested. ill pm you and i may have to wait until after the holidays and my daughters b-day....December is a double whammy month for me....i feel like im crapping out money i dont have. _________________ once you realize im not impressed we will get along just fine |
Old_Ben_Gun Samba Member
Joined: December 18, 2012 Posts: 30 Location: Spanaway Washington
Posted: Tue Dec 18, 2012 10:09 pm Post subject: |
Stranger than science: On some models on the power steering pump there is a small switch. This little bugger bumps up the idle when it is cold to make it easyer for the steering system to pressure up. After chasing around an idle problem for a very long time fixing this little switch corrected a sticking high idle. |
Terry Kay Banned
Posted: Tue Dec 18, 2012 11:58 pm Post subject: |
Ben Gun,
First I think he should get the TB issues ironed out & operating properly, then once that is all dialed in, move on to other accessory electrical items.
The OP has a boogered up throttle body,(maybe) a free swinging in the wind TPS actuating arm--no spring load on it, and a worn out TPS operating cam.
I'd start at the TB and then move on to bigger & better, & less obvious engine managemnt item's. _________________ T.K. |
Rodknock Samba Member
Joined: April 06, 2006 Posts: 516 Location: Boulder CO
Posted: Wed Dec 19, 2012 9:49 am Post subject: |
Old_Ben_Gun wrote: |
Where is this switch located? |
Posted: Thu Jan 31, 2013 2:55 pm Post subject: |
OK, so Phil sent me a sweet care package....a tps, throttle shaft seals, and a newer cam and lock plate. (im getting you back buddy!) i took it all apart, cleaned it and indeed my throttle body is worn and getting hung up.
i got it on with a new seal...(thanks TK) BUT it wont adjust to bently spec since the TB has Vertical shaft play. it gets warm and will not close.....so i adjust as best as i can. it kept bogging so my buddy at the local shop( Rick @ A&D torrance CA) set my timing, then adjusted the AFM. BUT it ran rich! it was fine cold but bogged once warm and the idle would stay at about 1800 unless i blipped the gas pedal.
the next day i adjusted the AFM back to where it normally is at idle and it ran great, no bog, no hesitation. i also checked voltage with the green wire unplugged to the O2 sensor and i was at about 0.5-0.7 volts at idle, ill check again but at this point its never ran better! it idles at 950-1000 rpm. thanks guys and i appreciate all the help. if you ever have afm problems, id check timing first, then tps switch, then voltage to the afm, then the O2 sensor. _________________ once you realize im not impressed we will get along just fine |
