Randy in Maine Samba Member
Posted: Sun Dec 16, 2012 8:37 am Post subject: Rear vent window pin part |
Foxmon was over here yesterday looking for the "hinge" or pivot pin for the rear drivers side vent window on his 78 westy. It allows the vent window to open and close.
I am not sure what it is supposed to look like but it looked to be about 8mm and about 25mm long with some sort of a "flat screwdriver bit" type of connection to the window. Mine and his were so rusty that there was not much left of it.
What is it called, anyone know the part number or got a good one?
Thanks!
Randy |
pioneer1 Samba Member
Joined: February 11, 2008 Posts: 2069 Location: Ontario Canada
Posted: Sun Dec 16, 2012 9:09 am Post subject: |
I believe that pin is part of the frame and when it's gone/rotten you need to find a new vent window from the classifieds or wrecking yard _________________ "Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Dec 16, 2012 9:13 am Post subject: |
pioneer1 wrote: |
I believe that pin is part of the frame and when it's gone/rotten you need to find a new vent window from the classifieds or wrecking yard |
X2, bad news unless you can remove the glass from the frame and weld the pin back in, it was originally riveted (end mashed over) into the frame but twists out when the lower pivot siezes. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Dec 16, 2012 9:54 am Post subject: |
Cool. I knew one of you guys would know.
I will let him search for one. It will be good for him.
I replaced my window back there with a non-vented one, so that is why I had one sort of laying around but in tough shape. |
foxmon Samba Member
Joined: September 20, 2012 Posts: 126 Location: Maine
Posted: Sun Dec 16, 2012 3:32 pm Post subject: |
Some of the least corroded bits on my bus (that's Randy's pivot pin on the right!) but the tenon is cleanly sheered off in the window frame
Desertbusman Samba Member
Posted: Sun Dec 16, 2012 8:32 pm Post subject: |
With the non-attached pin there is a solution that does work and did on mine. And since I only use that vent open when not driving, the tension resistance amount wasn't a concern.
The pin was shot so I made a new one. And the pin is sized for a nice clearance fit into the hole in the frame. And the pin is locked tight in the clamp. S o the end result is the vent frame rotates on a fixed pin. _________________ 71 Superbug
71 Westy |
foxmon Samba Member
Posted: Mon Dec 17, 2012 11:37 am Post subject: |
Desertbusman wrote: |
The pin was shot so I made a new one. And the pin is sized for a nice clearance fit into the hole in the frame. And the pin is locked tight in the clamp. S o the end result is the vent frame rotates on a fixed pin. |
So you made a round tenon on your pin so to speak and drilled a round hole in the window frame?
Thanks |
Posted: Mon Dec 17, 2012 2:47 pm Post subject: |
With the original pin removed it already left a hole in the frame. Don't remember but I might have cleaned up the hole a bit with a drill. But never did take the glass out of the frame. _________________ 71 Superbug
71 Westy |
