JeffRens Samba Member
Joined: August 25, 2012 Posts: 267 Location: Mishawaka, IN
Posted: Sun Dec 16, 2012 12:14 pm Post subject: Seat Frame Paint |
What kind of paint is best for the seat frames? I have some Dupli-Color Acrylic lacquer in a rattle can. Is that sufficient or should I use acrylic enamel with hardener or other suggestions? Thanks as always... |
stale air Samba Member
Joined: August 23, 2007 Posts: 5151 Location: Senoia Ga, formally NorCal
Posted: Sun Dec 16, 2012 12:41 pm Post subject: Re: Seat Frame Paint |
JeffRens wrote: |
There have been a ton of threads about paint for seat frames, shifter, e-brake, column, etc, and everyone has a different opinion.
I will tell you what I used. After sand blasting my frames, adding primer, and sanding, I shot them with Krylon Almond. I was told a ton of years ago by Koch, after he restored my steering wheel, that the almond was a dead match to his wheel. He was right, thats what I used, and it has heald up great. _________________ WANTED: Henry Veale Santa Rosa plate frames
Schwing Samba Member
Joined: May 10, 2009 Posts: 2506 Location: Centreville, MD
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Mon Dec 17, 2012 1:01 pm Post subject: |
For my seat frames... which I just did a few weeks ago...
If you have the luxury of being able to sandblast them squeaky clean I used epoxy alone, it is one tough finish you would be hard pressed to even chisel off. I've noticed though, on the '66 my son did where he used rattle can epoxies over other prepped painted surfaces the epoxy does not bite as well as it does to a clean rough sandblasted surface and will flake off in a short amount of time.
Unfortunately for my seat frames I just used black as I could not find an Almond type color in epoxy... it was either black or off-white as all of the light tinted colors were 'out of stock' when I went looking for it. And since my car is black I just used black as well.
If sandblasting is not an option then stripping as best as possible and then priming and painting with an acrylic for the best result and be sure to use some good prep/degreaer all along the track slides. And yes that krylon almond is nearly a perfect dead match to the original color. _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Thu Jun 22, 2017 6:12 pm Post subject: Re: Seat Frame Paint |
What do you think would be the going cost to sandblast 2 front lowback seats and the rear seat bottom and back? I'd have them all stripped of material and padding ahead of time, Thanks. _________________ 1963 Ragtop Bug |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Thu Jun 22, 2017 6:23 pm Post subject: Re: Seat Frame Paint |
That depends on who you know. I had both front seat frames and springs blasted and powder coated for $50, but I have a good connection.
Just blasting them should be $25-50 |
Posted: Fri Jun 23, 2017 8:40 am Post subject: Re: Seat Frame Paint |
txoval wrote: |
Nice, yea that's cheap. I'll have to do some calling around to see. _________________ 1963 Ragtop Bug |
