HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Posted: Wed Aug 31, 2016 2:27 pm Post subject: Re: Stranded on the way to ALASKA! |
skills@eurocarsplus wrote: |
what kind of noise? engine? suspension? |
Thanks. It sounds like a wheel speed light grinding that could almost be a brake backing plate (but it's not)
The noise only happens when it is under power and is most noticeable at slow speeds at the start of each gear.
My inclination was CV joints, throw out bearing or transmission but the mechanic thought the noise was coming from the front end.
I can't think of a noise that would be only heard under power from the front end.
I took the front brakes off and confirmed that the pistons are retracting correctly in the calipers and the wheels is moving freely when off the ground.
thoughts? _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
busdaddy Samba Member
Posted: Wed Aug 31, 2016 2:45 pm Post subject: Re: Stranded on the way to ALASKA! |
The front end lifts slightly when under power, the rear suspension moves forward a hair as well, also the front of the transmission lifts and the rear of the engine drops and the whole unit twists CCW, anything that may be touching when moved that isn't when static? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Aug 31, 2016 3:00 pm Post subject: Re: Stranded on the way to ALASKA! |
I am on the other side of the country with obligations....my time is more valuable to me than anyone here could imagine. like I said, don't rule me out.
that said, if you did it in PA, NY, DC etc I wonder who would turn up then. it's a matter of convenience that the majority of you are on that coast. I'd much rather spend the money on a hooker that gave me gonorrhea. ... |
I have similar logistics. I would like to be a fly on the wall at the meet up, but I live in the middle of the Pacific Ocean. I would be amenable to a "go fund my airline ticket".
Here's some info for you Skills
http://www.mayoclinic.org/diseases-conditions/gonorrhea/basics/prevention/con-20020917
Aloha
tp |
RONIN10 Samba Member
Joined: April 30, 2007 Posts: 594 Location: Seattle, WA
Posted: Wed Aug 31, 2016 4:12 pm Post subject: Re: Stranded on the way to ALASKA! |
HastaAlaska wrote: |
My inclination was CV joints, throw out bearing or transmission but the mechanic thought the noise was coming from the front end. |
Can you coast it down a decent hill in neutral, without the engine running? The CV joints would speak up then and your ambient noise level would be reduced. The effect of power may simply exaggerate an existing noise.
Also consider using a buddy to listen to the vehicle externally as you drive by. That may help pinpoint front or rear end noise. _________________ Andrew
Oscar: 1976 Westfalia Deluxe Camper, 2.0L FI, Manual Transaxle |
Xevin Samba Member
Posted: Wed Aug 31, 2016 5:35 pm Post subject: Re: Stranded on the way to ALASKA! |
So now you've seen Alaska. When will the lucky person be announced that wins the Kombi? Will you make a video of the drawing? What on Earth is in Mexico that is so important. Legal stuff? Surf? Food? Cheap beer? Etc.
you should probably follow the coast from Oregon down. And perhaps loop the Olympic Peninsula too. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
SGKent wrote: |
Manfred58sc Samba Member
Posted: Wed Aug 31, 2016 6:49 pm Post subject: Re: Stranded on the way to ALASKA! |
Outer bearing (front end) check is in order, especially if you have done a recent replacement with a Chinese bearing, they only go 8-10K miles. Sometimes dry torsion leaves can make strange noises, make sure your beam is well greased, I would make sure no water pockets have been trapped in there. Maybe recording and posting the noise would help if your equipment allows for that. _________________ Fat chick owner/operator |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Wed Aug 31, 2016 6:58 pm Post subject: Re: Stranded on the way to ALASKA! |
This spring with my 71 westy I had a bad scraping sound it was coming from the rear it took me a few days to fine it I thought it was a bad rubber on the spring plate I took it apart and a small rock fell out that all it was and it sounded REAL bad. _________________ where its cold and snowy |
Xevin Samba Member
Posted: Fri Sep 02, 2016 9:16 pm Post subject: Re: Stranded on the way to ALASKA! |
Meet up 20th September, Seattle if you want. |
Ben, you still on for this. My schedule is locked and I'm good to go. I'll drive up from Portland the 20th. Notcboy, I'm off the 21st too Ronin10 find a spot with lots of room and good suds. Any PDX boys want to Carabus up?
Skills I'll pick you up at the airport Bigbore did you get my donation? We might need to get Stuart out of retirement for the night _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Fri Sep 02, 2016 9:20 pm Post subject: Re: Stranded on the way to ALASKA! |
Xevin wrote: |
Skills I'll pick you up at the airport Bigbore did you get my donation? We might need to get Stuart out of retirement for the night |
Well if hes not then we do a GSBG meet
Bound to have some kind of fun. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
thebusandus Samba Member
Joined: February 12, 2014 Posts: 412 Location: Alaska
Posted: Sat Sep 03, 2016 5:43 am Post subject: Re: Stranded on the way to ALASKA! |
I had a scraping sound from the rear only noticeable under certain conditions like after letting off the gas, it was because my rear axle nut was to loose.. This could very well be your issue since you just did your bearings in Anchorage, they require a retorque or at least a check after driving a few hundred miles.. Although my noise didn't show for 20000 miles, it went away after retorque for the drivers side. _________________ 2.2 Suby powered - 75 Westy - Rita
Panamerican Highway - 2014-2017 |
Posted: Sat Sep 03, 2016 2:03 pm Post subject: Re: Stranded on the way to ALASKA! |
Manfred58sc wrote: |
Outer bearing (front end) check is in order, especially if you have done a recent replacement with a Chinese bearing, they only go 8-10K miles. Sometimes dry torsion leaves can make strange noises, make sure your beam is well greased, I would make sure no water pockets have been trapped in there. Maybe recording and posting the noise would help if your equipment allows for that. |
8-10k That's criminal! No noise coming from the wheels when coasting though and only audible at low speed.
RONIN10 wrote: |
Also consider using a buddy to listen to the vehicle externally as you drive by. That may help pinpoint front or rear end noise. |
Thanks I tried as you suggested but with someone hanging off the back but they were not able to tell if the noise was coming from either side unfortunately. Doesn't seem to be happening when coasting so perhaps not the CV joints then?
DiVo wrote: |
I had a scraping sound from the rear only noticeable under certain conditions like after letting off the gas, it was because my rear axle nut was to loose.. This could very well be your issue since you just did your bearings in Anchorage, they require a retorque or at least a check after driving a few hundred miles.. Although my noise didn't show for 20000 miles, it went away after retorque for the drivers side. |
Worth a check, although the nut has a cotter pin in it so it shouldn't that stop it from coming lose?
When I was with Ralfy in Anchorage working on the rear breaks, bearing housing and bearings he mentioned that the rear spring plate bushing was probably responsible for the bad camber on the rear tires.
Since leaving Anchorage we've burnt through a tire pretty quickly, down to the canvas. Couldn't find a R14 195 8 Ply tire anywhere, only a second hand 4 ply. I suspect that this tire isn't going to last long (it's a de-studded winter tire too) but now in Whitehorse, YT and can't find a decent tire here either.
Not sure if the camber is related to the scraping noise that we are troubleshooting but thought it would be worth a mention.
Xevin wrote: |
you should probably follow the coast from Oregon down. And perhaps loop the Olympic Peninsula too. |
Yes we will make a video of it. Probably be out early October. We'll start counting up the list and preparing the draw in October.
Have to go to Mex, mainly to comply with visa restrictions. Need to stay fairly local as it's probable (but not guaranteed) that someone in north america will win the Kombi.
Xevin wrote: |
Ben, you still on for this. My schedule is locked and I'm good to go. |
We'll be there. _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Posted: Thu Sep 08, 2016 8:45 am Post subject: Re: Stranded on the way to ALASKA! |
5 days 5000 kms later, 1 oil change, (high zinc formula - runs much quieter) 2 mechanics for a second opinions on that noise.
I think I'm chasing a couple of issues. The front end noise has gone so was probably dirt or rock.
There is now a intermittent 2000rpm noise coming from either the fan or the alternator. probably the bearing. Strangely heard a rodant climbing into the engine whilst it was warm on a very cold night. Checked out the fan with a scope cam to see if that did any damage. can't see any cracks.
Now in mid BC, Canada headed to the island to do some work on it. Not worried, just keeping you updated.
Happy Travels _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Posted: Thu Sep 08, 2016 3:32 pm Post subject: Re: Stranded on the way to ALASKA! |
Right on !! _________________ Fat chick owner/operator |
Xevin Samba Member
Posted: Tue Sep 13, 2016 9:30 am Post subject: Re: Stranded on the way to ALASKA! |
Ben, Don't forget the big boy knickers it should be a civil non personal goof, at least before my 6th pint
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...8d3785d91e _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Tue Sep 13, 2016 10:43 am Post subject: Re: Stranded on the way to ALASKA! |
watch the "Trump" roast on youtube with Obama- what a hoot- doubt your gathering will be that rough. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Xevin Samba Member
Posted: Thu Sep 15, 2016 2:21 am Post subject: Re: Stranded on the way to ALASKA! |
Ahhh Ben? You out there? Is this thing working? Is this thing on?
Clatter wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Thu Sep 15, 2016 6:56 pm Post subject: Re: Stranded on the way to ALASKA! |
Well we got one more. Xatie is going to come out for this huge event. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Xevin Samba Member
Posted: Fri Sep 16, 2016 10:49 am Post subject: Re: Stranded on the way to ALASKA! |
6:00ish or 18:00
https://www.google.com/search?q=stellar+pizza+seat...ent=safari _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
