kirsplat Samba Member
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sun Dec 23, 2012 11:17 pm Post subject: |
Jon_slider wrote: |
what is your current "raised" ride height? ride height is wheel center to fender lip |
Kinda reluctant to highjack this thread to something else but if it helps anyone -- Using your criteria and method above ...
Westy Syn -- Nokian 205x65R15 tires -- @ 18.25 "
Tintop Syn -- Nokian 205x65R16 tires -- @18.75"
Sinka Syn (stock suspension) -- BFG 27x8.5x14 -- @18.75"
Measuring height from ground to roof top just behind passenger door ...
Westy (using roof rather than poptop) @ 1.25" higher than sinka.
Tintop @ 1.75" higher than sinka.
I did all this at night in the freezing rain so I was motivated to move fast
An aside ... when I put my 15"steels with BFG 75 sidewalls on the tintop sync. down at SdM one year (back when there was just one event) I felt a little 'tippy' laterally at that height doing more serious offroading.
Also .. years ago doing serious offroad in the Tillamook OHV in winter ... had 14" with 75 sidewall BFG's on the same tintop sync. ... never felt tippy ... quite comfortable but at times could have used more lift ... bottomed out several times.
So far ... have never bottomed out with 15" BFG 75 sidewalls on tintop sync. (upgraded susp) or the sinka sync. (stock susp). Biggest problem in both cases ... and this depends on one's set-up ... banging the hell out of the mufflers and cats in departures. But no damage except one repairable cracked cat once.
I believe there are other threads that dicker over all this so recommend we just use this info to munch on here. |
whynotvw Samba Member
Posted: Mon Dec 24, 2012 12:44 am Post subject: |
Brianfromutah wrote: |
Quote: |
Posted: Today 6:52 pm Post subject:
I just lifted my syncro westy with ome shocks with gowesty 2" lift springs. My og boge shocks were completely blown so I'm very happy I have new Ome shocks. As far as the lift, I really like the how it rides and especially the look. |
do you mind posting your ride height? Did you have to change/add anything else (control arms, brake lines, spacers, ect...) Did the shop have any issue aligning it? |
I didn't have to change anything, I did change the stainless braided break lines while I had the wheels off. I got lucky and I didn't even have to align it.
It lifted about 2-2.5 inches I wish I added the spacers in the rear. the front is little bit higher then the rear. I've had a lot of people notice right away this is a offroad vehicle since the lift.
stock with 225 75 16
Lifted with 225 75 16
another angle lifted with same tires
Brianfromutah Samba Member
Joined: May 30, 2012 Posts: 150 Location: Utah, Heber City
Posted: Mon Dec 24, 2012 7:45 am Post subject: |
Quote: |
As for shocks.... Lots of folks love their OMEs, lots of folks say they are too stiff... I want sturdy... But not 'rattle my bones over every bump' sturdy.... What shock options are folks using... What of the fox shocks I see from GoWesty? They are kinda pricey, and i assumed for a more offroad purpose?? |
I am wondering the same thing. Anybody have any comments on the OEM replacement Sachs shocks?
It lifted about 2-2.5 inches I wish I added the spacers in the rear. the front is little bit higher then the rear. I've had a lot of people notice right away this is a offroad vehicle since the lift. |
I love the look! How do you know you didn't have to align it? Did you hook it up to an alignment machine? You could still be wearing out the inner side of your tires and still not have any pulling... what is your new ride height?(hub to fender) _________________ '89 Westy Syncro w/ '09 Subaru 2.5 |
Jon_slider Samba Member
Posted: Mon Dec 24, 2012 9:31 am Post subject: |
you have my permission to give ride height when you talk about lift
help me out the WestySyn is NOT lifted right? and rides at 18.25"
the TintopSyn is lifted 1.5" and ended up at 18.75??
the SinkaSyn is not lifted and is also at 18.75??
let me put it this way. IF your van is not at or above 19.5", I dont consider it significantly lifted.
You can still add the spacers in the rear, not a big job..
what ARE your ride heights, all 4 corners? You might need 2 shims on driver rear and one on passenger rear..
Its really really useful when you say you lifted 2", to give a number you ended up at.. PLEASE!
I have them, with GW +2 springs. I dont like that the warranty depends on GW repairing, they wont replace.. Yes they are for offroad, I would buy the Trailmaster System instead.
but I liked my OME shocks with old .org springs ride better than my GW setup, less body roll.
My Syncro Westy TDi, weighs over 5000 pounds, and has a motor and tire on the back that add 500 lbs over stock. Rear ride height is 21", with a 3" spacer on the driver rear, and a 2" spacer on passenger rear. See without spacers I would be at 19" or less, again, my heavy rig..
ps People with "stock" Syncros, including BrianfromUtah, could you post your current ride heights, all 4 corners, so we can begin to determine what "stock" is.
btw, tires do not matter for "ride height" (actually feder height) measurement. Tires do increase ground clearance. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
bosruten Samba Member
Posted: Mon Dec 24, 2012 10:54 am Post subject: |
No complaints.
_________________ '87 Syncro Weekender |
Posted: Mon Dec 24, 2012 10:56 am Post subject: |
I love the look! How do you know you didn't have to align it? Did you hook it up to an alignment machine? You could still be wearing out the inner side of your tires and still not have any pulling... what is your new ride height?(hub to fender) |
I didn't go to alignment shop yet because I'm replacing my steering rack. I'll go after that. But it seems to ride just as before.
1. front: center of the wheels to bottom of the lip 20"
2. rear: center of the wheels to bottom of the lip 19 half inches
By the way I love the way my OME with Gowesty 2"lift prings rides very smooth, when I go over speed bumps really fast, the rebound is a bit harsh but like everyone says there are no perfect fit. But this set up is perfect as it will get for my needs. By the way I got everything new for about $800 shopping around and being frugal. |
Posted: Mon Dec 24, 2012 11:23 am Post subject: |
great details, thanks!
I see you have a rear mounted tire carrier, which explains the need for a shim in the rear
And when you shim the rear the front will drop a little from the pressure increase at the back.. should be just about perfect, maybe 20" rear, 19.75" front, from adding a single 1/2" shim, possibly only needed at the spare tire side, driver rear
note, changes to driver rear spring height, affects the passenger front, the force moves diagonally. You need to measure each corner, or you may end up with the driver front being taller ride height than passenger front, same in rear..
for example, you may need 2 shims driver rear, and one shim passenger rear, to make your front wheels match ride height to each other..
I dont expect an exact match rear to front, I actually like the rear 1/2" higher than the front. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Mon Dec 24, 2012 11:32 am Post subject: |
bosruten wrote: |
No complaints. |
What wheel/tire combo do you have on there?
Do you have the stock 2.1WBX?
Thanks,
D _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Mon Dec 24, 2012 11:58 am Post subject: |
Jon_slider wrote: |
help me out the WestySyn is NOT lifted right? and rides at 18.25" ... the TintopSyn is lifted 1.5" and ended up at 18.75??
the SinkaSyn is not lifted and is also at 18.75?? |
The westy and tintop syncros have the upgraded suspensions ... OME and either syncro.org or smallcar springs. The sinka syncro is stock - original shocks and springs and 14" wheels.
Jon_slider wrote: |
let me put it this way. IF your van is not at or above 19.5", I dont consider it significantly lifted. |
All I was looking for was ride comfort, stabilization in crosswinds and better clearance for backroading and light offroading. For serious offroading I usually put on the 15"/75 sidewall BFG's which raises my ground clearance even more.
Jon_slider wrote: |
btw, tires do not matter for "ride height" (actually feder height) measurement. Tires do increase ground clearance. |
Jon ... my impression on this thread is people are looking for a raised ground clearance with comfort and good handling and not get too tall. There are other threads that get into the science of serious offroading where tables of specs are analyzed. I've read them all and know you've been in the thick of that
For the purposes here I'm presuming when someone says they lifted 2" after installing a stronger suspension and wheels/tires they mean ground clearance lift from where they were before, often (roughly) stock. |
Posted: Mon Dec 24, 2012 12:25 pm Post subject: |
excellent info, so your vans have
18.25" ride height on a lifted westy syncro and
18.75" ride height on a lifted tin top syncro
and BFG 215x75x15 tires (27.8" diam), add 1" more ground clearance
A friend has a Syncro Westy with new GW +2 springs and OME shocks., his rear ride height is 19.5".
He has BFG 215x75x15 tires, and his ground clearance is 12".
I think a lifted syncro paired with 28" tires is a reasonable configuration, not extreme.
But it is certainly not for everybody. It costs in fuel mileage, and you need to buy a spare tire carrier too. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Mon Dec 24, 2012 12:58 pm Post subject: |
Jon_slider wrote: |
and BFG 215x75x15 tires (27.8" diam), add 1" more ground clearance |
That is correct. For my variable needs I find that ideal. I presume the ride height difference between the westy and tintop syncros reflects the additional weight of the westy.
Jon_slider wrote: |
I think a lifted syncro paired with 28" tires is a reasonable configuration, not extreme. But it is certainly not for everybody. It costs in fuel mileage, and you need to buy a spare tire carrier too. |
They can also throw the speedometer off between 3 to 8 mph's depending on traveling speed. Returning from a syncro event at Hollister last spring wearing the taller BFG's ... was getting a lot of dirty looks by the cops ... realized I was going about 9 mph over the speed limit .... speed limit 70 ... westybob speedometer sez 72 .... westybob really going 79. |
Posted: Mon Dec 24, 2012 6:01 pm Post subject: |
westy syncro 2.5 suby engine stock springs/shocks (24 yr old)
RF 18 1/2
LF 18 1/4
RR 18 1/4
LR 18
sags 1/4 to the left and 1/4 inch in the rear.
I bought 2" GW springs but judging from what i have read so far anything over 19 1/2 ride height is no good without other mods. I would like to sit right at 19 1/2. seems like the GW springs lift it to about 20"
Original idea was much like deadsetmonkeys in the idea that the new springs would improve handling (at least a little over the 24 yr old sagging springs) also i love the look of the 2" lift, and i wanted it to be a bit more capable off road. I am now thinking smallcar springs with either new OEM or OME shocks. I also want the van to be able to drive across the country on the highway if needed. Small Car claims about a 19 1/2 inch ride height on a syncro westy with suby power. Seems to be a good compromise to me.
Anyone want to buy a set of brand new never used GW 2" lift springs? _________________ '89 Westy Syncro w/ '09 Subaru 2.5 |
Posted: Tue Dec 25, 2012 10:54 am Post subject: |
Jon_slider wrote: |
I'm sticking with a 14" rim on a Hankook using the clamshell. I only need a spare to get to the closest repair shop. At worst, I rotate the 14" to the rear because of the big brakes.
I run BFG A/T 215 75 16 on CLK's, no spacers. _________________ '87 Syncro Weekender |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Tue Dec 25, 2012 11:32 am Post subject: |
They don't list that size BFG A/T.
The rim size isn't the issue but the overall diameter of the rim with tire is.
Posted: Tue Dec 25, 2012 11:34 am Post subject: |
It overheats the Viscous Coupler (about $1500 installed) if you run tires that are not the same size on a Syncro.
In your case, I think your spare is 2" smaller diameter.
IF you had a decoupler ($2000+ installed), you could run a mismatched spare. A decoupler costs more than a tire carrier ($600-$1100, plus install).
I dont recommend mismatched tires on a Syncro, my approach is to keep all 5 tires in rotation, including the spare.
One of the BEST reasons to get larger rims, is to fit a Big Brake Upgrade ($900 plus install) _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Tue Dec 25, 2012 11:50 am Post subject: |
Jon_slider wrote: |
One of the BEST reasons to get larger rims, is to fit a Big Brake Upgrade ($900 plus install) |
Again, I am using VC's big brake kit so the 14" will NEVER go on the front. How would having a slightly smaller OD tire on the rear damage my VC?
I'll go double check but 215/75/16 BFG A/T is the size...maybe a Canadian thing? _________________ '87 Syncro Weekender |
Posted: Tue Dec 25, 2012 11:55 am Post subject: |
Jon_slider wrote: |
IMHO the best reason to have bigger rims is the ability to run slightly lower profile tires that give the stock rolling diameter. This gives shorter sidewalls that flex less and give better cornering characteristics with a slightly firmer highway ride.
I run a configuration like that on my 2wd and it changed from a wallowing pig to a more nimble pig that can handle surprisingly well. |
Posted: Tue Dec 25, 2012 12:17 pm Post subject: |
bosruten wrote: |
How would having a slightly smaller OD tire on the rear damage my VC? |
From the owner's manual under tires(page 116) Applies additionally to the syncro - "all four wheels on the vehicle must always have tires of the same size, construction and tread type so that the viscous coupling does not abnormally activate the front wheel drive. Different tires on the front or rear wheels exert additional stress on the drive train components, causing increased tire wear and impair vehicle control"
To figure out the rolling diameter difference of a 27" to 28" tire for example multiply by PI and you will find out that that one tire is traveling over 3" slower every rotation which is a significant amount.
You can get away with doing it for a short duration with a decoupler.
Posted: Tue Dec 25, 2012 12:21 pm Post subject: |
to lift or not to lift
go for 2" lift plus 28" tires if
1. You want Bigger Front Disk brakes
2. You have thousands of dollars to spend on rims, tires, springs, tire carrier.
3. You drive offroad and need more ground clearance
4. You don't mind losing 10% of your horsepower to taller tires, because you have a conversion motor.
not to lift
1. No need to buy spare tire carrier, no need to buy springs, no need to buy new wheels and tires.
If you want the "badass" look, put some 14" BFG AT tires on, and call it good. Everything else will stay the same, fits in the spare location, power and acceleration are stock, and chicks still won't look at your van, guys will.
slightly would be a couple millimeters, not a couple inches like you seem to have.. but, don't worry, if you don't get a flat, it won't matter
IF you run a smaller tire on back, it engages the VC more, making it hotter, which can ruin it.
http://www.vanagon.com/syncros/faq/syncro-faq.htm
How does the Vanagon Syncro's viscous coupling work?
The viscous coupling is constructed of a series of metal plates. Half the plates, (plates 1, 3, 5, 7, etc.) are connected to the input drive shaft coming froward from the transmission. The other half of the plates (plates 2, 4, 6, 8, etc.) are connected to the front differential. These plates are enclosed in a chamber with a very unusual silicon fluid. When the rear wheels and front wheels are moving at the same speed, all the plates move at the same speed, nothing special happens, and little power is transmitted through the coupling. But, when the rear wheels begin to lose traction and spin, the plates connected to the driveshaft begin to spin faster than the plates connected to the front differential. This causes a shearing action in the silicon fluid, which almost instantly heats and thickens, becoming much more viscous. This now highly viscous fluid locks the two sets of plates together and power is transmitted to the front differential and thus the front wheels. VW says this happens as quickly as 1/4 turn of the spinning rear tire.
http://users.rcn.com/derekdrew/vanagon/viscous_couplings_vanagon_syncro.htm
"As for the reason why the silicone in the viscous coupling gets too
stiff and starts causing trouble the people I asked unanimously
answered: to much strain. However, this is not referring to relentless
off road driving in groundless mud, but rather to small but permanent
differences in rotational speed between front and rear axle while doing
normal on road driving. These differences in rotational speed can be
caused by such things as unequal tire wear or different tire pressure.
Tire diameters should be the same within a 2 to 4 mm tolerance. Or, in
other words, if you're measuring the depths of the grooves in your
tires, the differences should not exceed 1 to 2 mm.
Thus people not caring tire pressure and tire wear, people having
mounted different tire brands on the front and rear axles, as well as
people never routinely using their spare tire so it gets worn roughly
the same way as the other tires are most probably ruining their viscous
coupling pretty fast."
Rotating Syncro tires
http://www.vanagon.com/syncros/technica/tire-rotation/index.htm _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
