Project 66 Daily Driver.
Page: Previous  1, 2, 3 ... 23, 24, 25, 26, 27, 28  Next
EA812
EA812 is offline
PostPosted: Tue Feb 06, 2018 9:28 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Post pictures of wheels and Steve will pop up!😁 that's exactly how I taped it off and pressed it into the seam with cardboard. The whole front of the wheel is painted in black first too. The backs I'm just gonna brush black.
Project 66 Daily Driver http://www.thesamba.com/vw/forum/viewtopic.php?t=538786&highlight=
Herbie build
http://www.thesamba.com/vw/forum/viewtopic.php?t=336044
EA812
EA812 is offline
PostPosted: Tue Feb 13, 2018 10:05 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Parts run for Herbie to get some over sized studs for the oil drain plate. One stripped out when attempting to change the oil a month ago. I have a similar problem on A Bomb too, one stud on each engine isn't locked into the case. So when I undo that one stud it becomes an oil drain 😂 but this time some of the lock tight I tried to put on it took some of the case with it.
Herbie build
EA812
EA812 is offline
PostPosted: Sat Feb 24, 2018 9:41 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Took advantage of the decent weather today and decided the paint is dry enough to install the hub caps. Laughing
Herbie build
EA812
EA812 is offline
PostPosted: Sun Apr 15, 2018 6:12 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Our first trip to Mansfield Drive In. I don't know how it happened but we were the first to arrive. We even stopped to pickup dinner on the way.
Good times and good movie, Ready Player One. On the way home though The left front drivers side drum was dragging. On initial check it looks like moisture in the brake fluid and the wheel cylinder was half seized. Brake bleeding is on the list today.
Herbie build
EA812
EA812 is offline
PostPosted: Mon Apr 23, 2018 3:54 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Here is a shot from the trip to the CTVWA Dust off yesterday. This is Rt 32 just the other side of Stafford CT. One of my favorite roads to cruise on. It's also the route to and from the drive in. It's very dark on the way back late at night.
Herbie build
EA812
EA812 is offline
PostPosted: Thu Apr 26, 2018 5:21 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Here a few more shots form last Sunday at the Connecticut Volkswagen Association’s 2018 Dust Off in Pomfret CT. If we can this is one of the few times we bring both cars to a show. It’s a nice ride mostly through the country side to get there, instead of going through Hartford. Another reason we like to take both out.
Herbie build
EA812
EA812 is offline
PostPosted: Tue Aug 28, 2018 8:08 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Since I haven't posted any updates in a long time I thought I would put a few new photos up.
This is in front of my local bait and tackle shop here in town, Yankee Bait and tackle . The Historic section of town.
also this building always looked like a real good place for a photo shoot . I would pass it on my way to the Connecticut river for fishing but never stopped to look at it till this photo. its down a little dead end road.
Just a cool spot after getting fuel.
Out in front of work on Drive Your VW Beetle to work day back in June.
We just had to bring both cars to the CVA 5th annual Frog Rock gathering
Last Saturday night cruising. Soapstone Mountain Sommers CT.
Herbie build
EA812
EA812 is offline
PostPosted: Wed Aug 29, 2018 10:17 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
This is something I'm trying out , a new fuel pump. From CB Performance. It's got the clips to hold the pivot pin in and I kinda liked that about it. I haven't had an issue with the pin coming out but know of several others who have. The pump I was using before came with the car and it is unknown just how old it was.
Herbie build
EA812
EA812 is offline
PostPosted: Fri Aug 31, 2018 9:38 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
EA812 wrote:
This is something I'm trying out , a new fuel pump. From CB Performance. It's got the clips to hold the pivot pin in and I kinda liked that about it. I haven't had an issue with the pin coming out but know of several others who have. ]
Oh yeah and it is a pump for an alternator engine. I got an alternator pump and push rod with the car when I bought it so the correct push rod is in.
Herbie build
EA812
EA812 is offline
PostPosted: Mon Oct 29, 2018 3:30 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
Just out doing regular car things.......
Herbie build
mikec4193
mikec4193 is offline
PostPosted: Tue Oct 30, 2018 3:21 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Love the fall colors...I think we are past "peak" here tho...your car looks like a natural amongst the foliage...
thanks for posting
MikeC
Dad bought his first Beetle on Dec 17, 1953.
EA812
EA812 is offline
PostPosted: Tue Oct 30, 2018 4:34 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
Tks, Mike! We are at peek but it was late and I'm guessing the Foilage will be quick.
I almost forgot the exciting part though. A couple weeks back I was coming back from work (I take it occasionall during nice weather) and I decided to take the long way home when the generator light started to glow. Since it wasn't on fully and would almost go out when at idle I figured it wasn't the belt and couldn't do much in the dark. It ran fine and no electrical issues but suspected the voltage regulator was on the way out for a long time so swapped out the regulator from Herbie and problem solved. Back in business.
Herbie build
EA812
EA812 is offline
PostPosted: Sun Nov 04, 2018 4:01 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
Today was a beautiful day to do something old VW cruising in A Bomb.
Herbie build
EA812
EA812 is offline
PostPosted: Tue Dec 04, 2018 3:59 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
Here it is December 4 and I'm still able to take a ride in it!
Herbie build
Beetlebaum
Beetlebaum is offline
PostPosted: Wed Dec 05, 2018 4:22 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
Good to see you still at it with this Bug. I was reading through the thread again a few days ago.
1973 Super Beetle
2003 New Beetle
Post your Super here: http://www.thesamba.com/vw/forum/viewtopic.php?t=331999
Beetle Bums VW Club Member
EA812
EA812 is offline
PostPosted: Sat Dec 08, 2018 8:06 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Tks, even though it's not getting used as a daily driver anymore I try to take it out as much as possible and keep going with this thread. It has bailed us out a couple times this year when one of our more modern vehicles is down for repairs. Coil springs on the wife's car broke, it was out if commission for a week. Wheel bearings, brake rotors, pads,and calipers on my truck. It was down for 5 days. Everything becomes a project vehicle after ten years of city driving 😂
Herbie build
EA812
EA812 is offline
PostPosted: Thu Jan 10, 2019 1:09 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
Although not as vintage but I'm working on another project vehicle, 1985 Toyota 4runner. We're going to see if it can handle a year of driving like A Bomb did.
https://www.yotatech.com/forums/f115/project-daily-driver-85-4runner-306689/
Herbie build
EA812
EA812 is offline
PostPosted: Thu Feb 28, 2019 3:14 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
New 12v signal/hazard flasher for A Bomb, we could have used this feature on our little trip to Lake Champlain that time! I blew the brand new 12V signal / hazard flasher that year with crappy Chinese tail light bulb holders. Them junkie things were shorted out from the start
And I still have the old thermal flasher we got with Herbie in case it goes out.
Herbie build
EA812
EA812 is offline
PostPosted: Sun Mar 17, 2019 1:32 pm    Post subject: Re: Project 66 Daily Driver. Reply with quote
First ride of the season!
Herbie build
EA812
EA812 is offline
PostPosted: Wed Mar 20, 2019 10:41 am    Post subject: Re: Project 66 Daily Driver. Reply with quote
Looks like another good day for a cruise!
Herbie build
Page 24 of 28
