NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Sun Dec 23, 2012 2:49 pm Post subject: Corvair 5 speed conversion |
http://www.corvairkid.com/5-speed.htm
Could this be applied to use in a VW? I know Corvairs spin the wrong way. Maybe flip the diff housing over? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Sun Dec 23, 2012 5:43 pm Post subject: Re: Corvair 5 speed conversion |
looks like nose cone size and shift rod position would also be a problem. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
BDubVdub Samba Member
Posted: Sun Dec 23, 2012 10:32 pm Post subject: |
Why not just use a 911 trans? I found one on her for $425. It doesn't require much modification. |
scottydub Samba Member
Posted: Sun Dec 23, 2012 11:55 pm Post subject: |
I had a corvair in a van, with a stock vw transmission. It spins the opposite direction and even if you flip the pinion over, it will still eventually cause your tranny to wear out quicker. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Mon Dec 24, 2012 8:51 am Post subject: |
A bit off the subject but there used to be a kit that made the entire Corvair drivetrain almost a bolt-in to a VW chassis after cutting off the frame horns. I think it was called the Trans-Vair conversion or something like that and was offered by a company called OTTO Parts. They had a kit for Bay window busses too. I used to have some literature that showed the conversion but have no idea where it is now. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Mon Dec 24, 2012 12:04 pm Post subject: |
I know a gentleman by the name of Harold Eggeman back in CA, who had an Otto kit in his Type 2. He used a 95 hp in the conversion, but anything up to even the 180 hp engines have been used. The torque from the Corvair powerplant made it actually enjoyable to drive, instead of flip flopping between gears all the time like with a VW four. I recall he said he tuned it to get decent mpg too, mid 20's or something like that. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Subarugears Samba Member
Joined: January 03, 2012 Posts: 294 Location: Sydney, Australia
Posted: Tue Dec 25, 2012 1:03 am Post subject: |
You can bolt a reversed Subaru 5 speed 2WD transmission right in to Type 1,2 and 3 VW's. If you want to retain the VW engine there's also an adaptor plate and flywheel available that bolts to type 1 and type 4 motors.
www.subarugears.com _________________ http://www.subarugears.com |
