686 bus-boy Samba Member
Posted: Tue Dec 25, 2012 5:54 am Post subject: Harley into VW |
Has anyone used the rewaco engine adapter from a harley to vw transmission or fitted a harley motor in a vw? Any feedback appreciated. |
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1296 Location: south san francisco
Posted: Tue Dec 25, 2012 9:42 am Post subject: |
ya why for one. but i think the kit is more for some one building a trike. seen one in sturgis. still probably a dumb idea with the motor in the back with little air going to it? in a bug the motor will burn up. unless you can modify a doghouse shroud to fit it somehow? |
volksnhousin Samba Member
Joined: July 18, 2006 Posts: 326 Location: Ellerslie, GA
meciscokid Samba Member
Joined: August 12, 2008 Posts: 40 Location: Chico, CA
Posted: Tue Dec 25, 2012 12:01 pm Post subject: |
WOW! What a project. Hope his health holds out to see this to completion. Its nice to see he has family support too. |
Posted: Tue Dec 25, 2012 3:48 pm Post subject: |
now that i see what you are doing . it seems you can do it .but you need some kind of scoop or something to get air to the motor. or it will die. i worked on a guy's chopper before that had a big box i front of the motor for a stupid boom box and stuff. well the motor blew up from over heating. the thing needs a good air flow . |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Tue Dec 25, 2012 8:48 pm Post subject: |
Well, there's always the Revolution motor, designed with Porsche's help too! Funny how these things sort of come full circle. _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum. |
Posted: Wed Dec 26, 2012 3:16 am Post subject: |
Thanks for replies guys, i realise the air flow is an issues but im sure it can be overcome, im not worried about performance, thats not the reason for doing it, i think to see that symetrical v twin sitting there would be very cool, and the sound, well thats just a bonus! ive contacted rewaco regarding the kit and am awaiting a reply just to see exactly what you get in it. The revolution motor would be cool to use with its porsche pedigree but the twin cam b motor is the one to use because of its counterweighted crank design which reduces all the vibration. |
Volfandt Samba Member
Joined: March 15, 2012 Posts: 500 Location: Knox County, East TN
Posted: Wed Dec 26, 2012 6:01 am Post subject: |
Neat concept....
Back in the day, HD used to make a nice chrome electric cooling fan that mounted on the left side and covered the space between the cyl's. It was thermostatically controlled and would move a good amount of air over the cyl's. Made mainly for dressers that did alot of parade type cruising.
Now it detracts from the awsome HD left side engien profile but it is one solution to get some air over those cooling fins.
Way back in the day I was crusing an old 77 shovelhead through some very serious big city stop & go and the engine heated up so much the pipes started glowing red up near the head. Once I got it out into open air it cooled off and suffered no damage. May not have turned out as well if I had sat in that bumper to bumper much longer tho
Dave _________________ 1972 Karmann Ghia, the Dragon slayer.... |
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Wed Dec 26, 2012 7:37 am Post subject: |
Heck, I think I saw my pistons going up and down mired in Daytona Bike Week traffic _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
Altema Samba Member
Joined: June 20, 2010 Posts: 2904 Location: Lower Michigan
Posted: Wed Dec 26, 2012 11:21 am Post subject: |
Volfandt wrote: |
Way back in the day I was crusing an old 77 shovelhead through some very serious big city stop & go and the engine heated up so much the pipes started glowing red up near the head. Once I got it out into open air it cooled off and suffered no damage. May not have turned out as well if I had sat in that bumper to bumper much longer tho |
That would be a good cooling solution, but he will also need to pull air into the compartment. Glad you didn't cook that 77! I've been in my share of traffic jams with the Ghia on hot days, but interestingly enough, they cool down when idling. My summer engine temperatures are usually around 170 degrees F when driving. Last summer I let the engine idle for about half an hour without moving on a hot day, and the engine temp dropped to 143.
Paul |
Clayman340 Samba Member
Posted: Fri Aug 17, 2018 6:17 pm Post subject: Re: Harley into VW |
I contacted Rewaco USA looking for their patented adapter and they had no clue as to what I was asking for. I had to show proof from patent files that it was their own design. They said they would check their contacts in Germany. I never heard back from them. Still searching... A Harley V twin would look sick hanging off the back of my Tow'd. |
DeathBySnuSnu Samba Member
Posted: Fri Aug 17, 2018 7:24 pm Post subject: Re: Harley into VW |
As I understand it.....the swap never did go over well and the production of the adapter parts ceased.....all quite a few years ago.
Every once and while you see a used adapter come up.
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Fri Aug 17, 2018 9:13 pm Post subject: Re: Harley into VW |
That just looks badass! I have no idea how well it would work ignoring the obvious airflow problem. I know the Harley engines have a pretty long stroke, I have no idea about how much torque/hp they make. |
Tbirdusa Samba Member
Joined: November 29, 2006 Posts: 1460 Location: Kansas City, MO
Posted: Fri Aug 17, 2018 9:27 pm Post subject: Re: Harley into VW |
That story of the Evo is sad. A six month project and 9 years later, it's still not done. _________________ Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Sun Aug 19, 2018 12:49 pm Post subject: Re: Harley into VW |
That really is a sad story, even worse that at the end it is let down by a brand new engine constructed with design defects. _________________ Ancient vehicles and vessels
