der58SC Samba Member
Joined: September 15, 2006 Posts: 1359 Location: Oceanside, CA
Posted: Sat Feb 03, 2018 9:01 am Post subject: Re: Engine compartment fire control? |
thanks for the response. I like the setup. That should cover any kind of fire you might have. _________________ Like a midget at a urinal, I'm always on my toes
KCCO!!
Strictly Vintage 2s |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1105 Location: Martinez, CA
Posted: Sat Feb 03, 2018 11:13 am Post subject: Re: Engine compartment fire control? |
der58SC wrote: |
thanks for the response. I like the setup. That should cover any kind of fire you might have. |
Hopefully... But even more hopeful I'll never need it.... _________________ -Adam
'59 Mango Bus
'69 Bug |
dubstar Samba Member
Joined: January 17, 2009 Posts: 1437 Location: New York
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Fri Aug 17, 2018 6:24 am Post subject: Re: Engine compartment fire control? |
dubstar wrote: |
Is anyone running the 3-foot length in a bus? |
I think they come in lengths of 2 or 3 Meters . I just ordered a 2 meter one for my bus.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Fri Aug 17, 2018 5:45 pm Post subject: Re: Engine compartment fire control? |
Three meter recently installed
EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Sat Aug 18, 2018 12:56 am Post subject: Re: Engine compartment fire control? |
I think it's better to have some more volume, that's why I installed this Firetec system:
HMVWNAB Samba Member
Joined: September 23, 2006 Posts: 1084 Location: Sunshine State
Posted: Sun Apr 17, 2022 12:54 pm Post subject: Re: Engine compartment fire control? |
zozo wrote: |
I was wondering as I installed the 6 foot application how someone would mount the 9 foot model, given the rigidity of the tube and maintaining the recommended six inch bend radius.
_________________ What are the last 2 words of the National Anthem?
PLAY BALL! |
RWK Samba Member
Posted: Sun Apr 17, 2022 4:34 pm Post subject: Re: Engine compartment fire control? |
It's a good system, they have been used in industry for decades, pretty common
option on sinker EDM's back in the day.
Another thought I have is a door or flap on the inside of the air intake louvers, put one of those parts washer melting tab's on it some how so that the flaps or door shuts when it reaches the critical temp, that way the OXYGEN available for the fire is reduced dramatically, assuming all your tin and seals are in place, and leave the deck lid closed in the event of a fire, maybe spray extinguisher thru vents, again cutting off air supply.
This would buy time for extinguishing the fire (if it doesn't burn it's self out) with on board fire extinguisher.
Even with the blaze cut I would carry an extinguisher. _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
Juan Samba Member
Joined: September 01, 2003 Posts: 878 Location: Miami, FL
Posted: Mon Aug 08, 2022 8:03 am Post subject: Re: Engine compartment fire control? |
Bumping this up to ask: does a bus need a 10 ft application? I see ads here recommend that length for bus and Ghia. I have a shorter one on my Ghia and seems about right (not sure what length). Just asking cause price for a a 10ft is steep right now. _________________ Instagram: @juanskombi
1967 Velvet Green/Pearl White Kombi
1964 Pearl White Ghia Coupe
1969 BMW 2002
1959 Ford F100 |
Posted: Mon Aug 08, 2022 9:56 am Post subject: Re: Engine compartment fire control? |
Juan wrote: |
Bumping this up to ask: does a bus need a 10 ft application? I see ads here recommend that length for bus and Ghia. I have a shorter one on my Ghia and seems about right (not sure what length). Just asking cause price for a a 10ft is steep right now. |
Does it need a 10ft? Maybe, maybe not, but it also doesn't need one at all. I have the big guy installed because I'd rather have more than not enough. That being said, anything is probably better than nothing, and as others have mentioned, even with Blazecut, one should still keep a fire extinguisher in the cab. _________________ -Adam
'59 Mango Bus
'69 Bug |
