DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Fri Jan 04, 2013 4:15 pm Post subject: Planned Fuel Tank Drop |
I'm finally going to start this job mid next week. 1971 Bug Guy you wanted to observe or partake, let me know if so.
I'm going to read most of the threads and I have an excellent tutorial from a vanagon syncro mechanic with simple picturals to follow. I want to keep it simple and am totally intimidated by this job but it must be done for many reasons now. I will be dropping it then working on repair/cleaning/whatever is needed and it probably won't go back on for at least a month. I don't know what I need to order/replace/fix until I get it down.
Any hints, technique help, etc.... would be greatly appreciated. I will have help for the parts that are too heavy for me etc... but basically I'm doing this. gggggggggrrrrrrroooooooaaaaaaaaaaannnnnnnnnnnnnn! _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1867 Location: Pittsburgh PA (ish)
Posted: Fri Jan 04, 2013 4:22 pm Post subject: |
If you're following along on a syncro tutorial to do a 2wd you will soon be extremely surprised...... |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Fri Jan 04, 2013 4:23 pm Post subject: |
Stating the obvious... you'll want the tank pretty near empty before you do the final draining. |
DAIZEE Samba Member
Posted: Fri Jan 04, 2013 4:31 pm Post subject: |
no its not a syncro tutorial, he drew basic, simple pics for me. Yes I have been using up the fuel and have many large containers to drain into if needed. I will be inside a shop and will be able to use the hoist and tools and muscles too _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
DAIZEE Samba Member
Posted: Fri Jan 04, 2013 4:36 pm Post subject: |
have the shop's floor hydraulic jack but also a high stand to support. I'll be doing it but it'll probably be more like me helping the guys take it off. Once it's off, then I'll do all the cleaning, hoses, grommets etc...Yes the guys have spoiled me but I've earned thousands of credits over the past 6 mths. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
wecm31 Samba Member
Joined: August 05, 2012 Posts: 358 Location: Eganville, Ontario
Posted: Fri Jan 04, 2013 4:58 pm Post subject: |
I did mine laying under the slightly raised van....you are
well ahead of the curve with your setup.
The biggest problem I had was getting it back on!!! With the straps
mounted in their rear slot holes, make sure the tank is fully towards
the stern before raising that last inch or two and securing the strap
bolts. And try to save/reinstall those plastic wear pads that go between
the straps and the tank. _________________ Gerald P
1985 Vanagon (Betty) & 1985 BMW R80RT (Wilhelm)
vintage boxers!!
Gone are the days we stopped to decide
Where we should go, we just ride:) |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Fri Jan 04, 2013 5:04 pm Post subject: Re: Planned Fuel Tank Drop |
DAIZEE wrote: |
Any hints, technique help, etc.... would be greatly appreciated. I will have help for the parts that are too heavy for me etc... but basically I'm doing this. gggggggggrrrrrrroooooooaaaaaaaaaaannnnnnnnnnnnnn! |
DUDE, you have 7,000+ posts. Can't you do a search? I think there are a couple of hints, techniques already outlined for you. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
theDrew Samba Member
Posted: Fri Jan 04, 2013 5:08 pm Post subject: |
I just went through this...few things....
be very careful with the brittle expansion tank roll over valves. They're $36/pop.
used vasoline when I was putting in all the seals and on the filler tube, make things pretty easy
while you have it out, check the fuel sender and probably replace the ground wire. I did not do this and am kicking myself cuase you can't get to it with the tank in. I did a new sender, but didn't check it and I think its the ground wire.
I used a atv jack to get the tank back in -- I think this made things pretty easy. (relatively)
For the hoses going to the expansion tanks, I tied them to string and fed those through the frame before hand, so once I got it into place I could just pull the string and get the hoses in the right spot.
try to be as clean as possible to keep contamination to a minimum to the fuel. Once I was done, I cycled the pump a few times and then replaced the filter. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
DAIZEE Samba Member
Posted: Fri Jan 04, 2013 5:09 pm Post subject: |
feel better? I'm not a wrencher and I'm trying to learn and I respond well to encouragement and I've worked dammed hard to get these benefits so DUDE, I'm a duddette or would a 4/3 be more readily understood? _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
geo_tonz Samba Member
Joined: August 01, 2012 Posts: 1472 Location: Courtenay, BC, CANADA
Posted: Fri Jan 04, 2013 5:19 pm Post subject: |
Unless you know it's been done in the last few years go ahead and order a gas tank re-seal kit like GW or VC carry. CIP carries some of the parts but the kits from the other are better quality stuff and more complete. Make sure you order the right one for your filler neck type.
Also make sure you read up on the threads about how some tanks can easily chew up the fittings for the fuel level sender and result in a freshly resealed tank that leaks on it's first fill-up (like mine...gotta drop it again). There's a method to doing it right.
Also get a fuel line kit and do the rest of your fuel lines if they haven't been done already.
May as well get a filter while you're at it.
Once you have it out you can decide if you need a new tank, check the expansion tanks for cracks and decide if you want a new fuel level sender. Maybe you want to just replace the sender anyway...they do fail and they're not that pricey and you'd save on shipping ordering it with the tank reseal kit.
Not sure where you are in the Great White North but here on Van Isle I found Lordco (an auto parts chain) to be the cheapest for a tank if it comes to that. CIP was cheaper but then the shipping made it more.
GT _________________ ---------------------------------------------------
"Ron Burgundy": 1991 Vanagon Multivan (Weekender) 2.1L Auto - Driver/Camper |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Fri Jan 04, 2013 5:49 pm Post subject: |
If you are taking a trip south in the future stop in VA and we will take it out and do the sender and vent lines 3 hr stop over at most. |
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 658 Location: Lancaster PA
Posted: Fri Jan 04, 2013 6:06 pm Post subject: |
Hardest part is getting it back in and getting the vapor lines hooked up. Other than that it's easy. _________________ wv2yb0252gg092706 |
cellerdoor Samba Member
Joined: July 10, 2012 Posts: 403 Location: Fairfax Virginia
Posted: Fri Jan 04, 2013 6:14 pm Post subject: |
In the middle of mine. I would strongly consider a new tank or be ready to order one up. I wasnt experienceing any issues but after seeing the condition of the tank it made sense.
After draining the tank by removing the outlet and inlet lines it still had 5 gallons of gas left.
This is one third of the junk that came out of the tank
Found a few pin holes and leaky vent lines (note stains all over tank)
Do it and do it right _________________ 1986 Westy |
DAIZEE Samba Member
Posted: Fri Jan 04, 2013 7:47 pm Post subject: |
Thanks for the offer Alaric but I'm not on road till April/May.
Good tips and hints. Yes I am prepared to order new tank if needs be but until I get it dropped I don't know what I need altho I do know I need new hoses to vapor tanks and I don't have a functional fuel gauge. I'm leaving myself lots of time for it being out of commission for now. I expect the worst case scenario so no surprises.
Having bilateral eye surgery in April or May so need to do it now. Shop only slightly cool, not warm and not cold. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
peasant Samba Member
Posted: Fri Jan 04, 2013 9:45 pm Post subject: |
Go for it! I am doing this job for the second time on another van, be careful with the roll over valves like someone else said. The nipples can be fragile and break. Often times the fuel expansion tanks top seals are bad. THey were on both the vans I did it on.
Do all lines and be sure to use clamps. If $$$ is tight and the tank is in decent shape, prep it as best as possible, leave the sender as is, like others said putting in a new one can cause leaks.
If funds are not an issue, do it all (tank, sender, etc.) just be sure to do it right or you might have to do it again. Also, Be sure use sealer of some sort(gasoline resistant) on the grommets etc.
Kayakwesty (sp?) write up on his site is good to review beforehand as well
Good Luck!!
Ohh Yea, If you have not done power steering lines and they seem rusty/leaky, now is a good time to do it, alot of the stuff is out of the way. There are some good threads on what exactly is needed. I am also doing that while the tank is out. _________________ 89 wolfsberg weekender carat
89 Westfalia |
rlamb Samba Member
Joined: March 26, 2012 Posts: 211 Location: Sweet Home, OR
Posted: Sat Jan 05, 2013 12:28 pm Post subject: |
I did mine last summer following kayak westy's tutorial here: http://www.kayakwesty.com/gastank.html
I took me more time than I thought it would, but wasn't too bad. His tutorial is GREAT! The cinder block was very helpful. The inside of my tank was totally fine, and I cleaned and painted the outside with bed liner. Definitely use Vaseline on the grommets when putting everything back together. I didn't have enough on there, and punched one grommet right into the tank when reassembling. It was a PITA - had to take it all out and fish the grommet out of the tank and reinstall. The gas resistant RTV sealant on the grommets is important too.
Be careful when reinstalling the fuel sender unit! http://www.thesamba.com/vw/forum/viewtopic.php?t=513681&highlight=fuel+sender+plastic _________________ 1984 Westfalia - Ford Cologne 2.8L conversion
2003 Passat GLX Wagon (4Motion) |
Posted: Sat Jan 05, 2013 12:32 pm Post subject: |
I did one a few years ago, and my one regret is not testing the fuel tank sender for accuracy at the bottom of the range. Installed a new one, and didn't set this. In my case the result is my gauge stays on F for around 15 miles and shows E when I have 2.5gal left. Oops.
Make some wire extensions so you can connect it electrically with the tank beneath the van. Test for "E" since there's no fuel in it, and if needed quickly remove the sender, bend/tweak and re-check. Repeat if needed til perfect.
To fix it after the tank is all installed again is a hassle I don't want to deal with.
I'm doing another tank this Spring on a different van and won't forget this very important step. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
