natdubs Samba Member
Joined: October 31, 2010 Posts: 23 Location: lincolnshire england
Posted: Sun Jan 06, 2013 8:58 am Post subject: Split bus King and link pin beam on a late bay how to ? |
Got me a rust free mid sixties k&l pin beam that I am going to narrow and fit on my 74 bay.
Someone told me late bay hubs go straight on, yes they do but when you put the disc on it fouls the spindle.
Does anyone know how to run latebay hubs on k&l pin beam ?
I want to keep the late wheel bolt pattern too.
I am aware I will have to fabricate a bracket for the brake caliper but that is no problem.
I know the "new" bay buses run k&n pin beams with discs but the parts are just to expensive for me. |
Aspro Samba Member
Joined: September 01, 2012 Posts: 70 Location: Australia & UK
Posted: Sun Jan 06, 2013 2:16 pm Post subject: |
Can't say I've heard of anyone doing this. As far as I know everyone running KnL with a disc set up runs brazilian spindles and brakes OR aftermarket kits like CSP or Fatbus etc. Best to talk to the usual suspects in the UK like T2D or Slamwerks. Might shine some more light on the issue. |
Posted: Thu Jan 10, 2013 1:15 pm Post subject: |
Looked into this in a big way and found out track differences, spindle sizes etc.
To cut a long story short I am gonna put a machined spacer between the hub and spindle.
All I have to do now is fabricate a bracket for the caliper, which should be no problem as I work in engineering anyways.
I will let you all know how I get on |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Jan 10, 2013 1:23 pm Post subject: |
just so you know, the bolt pattern, where the beam bolts to the frame, is different between the split beam and the '74 frame. |
Posted: Thu Jan 10, 2013 1:31 pm Post subject: |
[/img]
http://www.volkszone.com/VZi/attachment.php?attach...1352412832
This is the low down dirty rat the beam is going on.
Looks different now as its been sign written and has porsche gas burner wheels, roof rack full of junk etc
Posted: Thu Jan 10, 2013 1:32 pm Post subject: |
hazetguy wrote: |
I am narrowing anyways so that is not a problem, but thanks any ways dude |
Aspro Samba Member
Posted: Thu Jan 10, 2013 4:33 pm Post subject: |
Looking good Nat, even if it is a late one Where abouts are you in Stinkonshire? I'm just out of Horncastle. Should catch up for a warm one. |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Thu Jan 10, 2013 5:57 pm Post subject: |
only 68,69 maybe 70 can use linkpin beams. _________________ once you realize im not impressed we will get along just fine |
Shaun Murray Samba Member
Joined: December 23, 2008 Posts: 587 Location: Far from the city lights
Posted: Thu Jan 10, 2013 6:20 pm Post subject: |
hazetguy wrote: |
If he's narrowing the front beam and making new endplates he can drill them for the late bay bolt pattern and it should work fine. I think there is a diagram on the lowering forum with the bolt pattern and spacing deminsions. I've thought about swapping a K&L beam into my '72 to gain more ground clearance, but the expensive brake options stalled that plan. _________________ "Cross Country Trip" http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight= |
GeoffP Samba Member
Joined: July 14, 2002 Posts: 400 Location: Blaine WA / Vancouver
Posted: Fri Jan 11, 2013 2:59 pm Post subject: |
Shaun Murray wrote: |
hazetguy wrote: |
If he's narrowing the front beam and making new endplates he can drill them for the late bay bolt pattern and it should work fine. I think there is a diagram on the lowering forum with the bolt pattern and spacing deminsions. I've thought about swapping a K&L beam into my '72 to gain more ground clearance, but the expensive brake options stalled that plan. |
I found this drawing its better than the one out there already it has more dimmesions (should be on the lowering forum bit really)
Posted: Fri Feb 01, 2013 2:12 pm Post subject: |
Found a dude on here that has done this, messaged him but no reply yet.
He's jeremyrockjock looking at his old posts he's well known on here I guess. |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22449 Location: Escondido CA
Posted: Sun Feb 03, 2013 8:55 am Post subject: |
notchboy wrote: |
You know you are mad dont you?
yer man.............. |
Posted: Sun Feb 03, 2013 11:27 am Post subject: |
natdubs wrote: |
hazetguy wrote: |
From this drawing I'd angle the bottom tube 18 degree though |
SGKent Samba Member
Posted: Sun Feb 03, 2013 11:54 am Post subject: |
Quote: |
Notchboy wrote: You know you are mad dont you? |
He isn't mad. Just another Looney Englishman. It goes back to why my ancestors left that place - just in time too. They had these civil wars in England. Roundheads vs. Cavaliers. Cromwell won. The TeaParty Conservative types of that era worshiped him as their Conservative leader for a few years then he died of a bladder infection - too many women of the night??? A couple a years later the English were so pissed at the government he set up they dug him up (a dead man), put him on trial in court, found him guilty and hung him (his corpse) followed by dismembering him and sticking his head on a pole and then burying him all over England so no one could find the grave. Insanity is in their blood at times. No different than sticking a split suspension into a bay. In five years the next guy will ask how to remove it, stick the pieces on his scrap heap and send it off to be melted down into steel for 10,000 tin cans and sent all over the Isles to be buried in landfills like Cromwell was. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Feb 07, 2013 1:04 pm Post subject: |
SGKent wrote: |
He isn't mad. Just another Looney Englishman. It goes back to why my ancestors left that place - just in time too. They had these civil wars in England. Roundheads vs. Cavaliers. Cromwell won. The TeaParty Conservative types of that era worshiped him as their Conservative leader for a few years then he died of a bladder infection - too many women of the night??? A couple a years later the English were so pissed at the government he set up they dug him up (a dead man), put him on trial in court, found him guilty and hung him (his corpse) followed by dismembering him and sticking his head on a pole and then burying him all over England so no one could find the grave. Insanity is in their blood at times. No different than sticking a split suspension into a bay. In five years the next guy will ask how to remove it, stick the pieces on his scrap heap and send it off to be melted down into steel for 10,000 tin cans and sent all over the Isles to be buried in landfills like Cromwell was. |
So in "England in the 80's and 90's what did people do to the front end of there split buses ? Yep thats rite junked them for later ball joint bay beams. Over here you have two options if you wanna go really low, either red 9 design or re-instate a k&L pin beam. I'd say its gone full circle to be honest or as the same as everything else in the aircooled world its forever changing !!!!!!!! |
Posted: Sun Mar 03, 2013 1:52 pm Post subject: |
I has brake caliper adapter drawings. Last bit of the jigsaw ! |
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Sun Mar 03, 2013 3:16 pm Post subject: |
Just another screwed-up bus. _________________ where its cold and snowy |
