Paul Wilson Samba Member
Posted: Fri Feb 01, 2013 1:16 pm Post subject: |
Ok, the PDSIT 3. The actual measurements of tube heights are;
Acc. tube 12mm
power tube 15.29mm
PDSIT - 2
ACC tube 14.5mm
power tube 11.5 mm
I will correct the heights to match the -3.
jetting will be as follows:
PDSIT-2
24mm venturies
Main 132.5
Air correction 150
55 elect idle
PDSIT - 3
24 mm venturies
Main 130
air correction 120
55 elect idle
Per the chart, I should not have the power jet at all. I will leave them for now rather than remove and plug or just plug.
Paul |
mightymouse Samba Member
Posted: Mon Nov 11, 2013 5:54 pm Post subject: |
This is such a nightmare. lol
Anyone have all the paperwork in english?
It seems like a vital resource not to.
I need to know what jets i should have in 1967 32 pdsit's on an all stock 1600 with a header and single QP. Also has a pertronix vac distributor.
Plan is to put a wideband on it and jet from there. But until that comes in id love to have some input on what people have found works best.
We do have the air filter that requires the staggered jet setup.
Thanks in advance. Any info is appreciated.
Dave _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69734 Location: Phoenix Metro
Slow 1200 Samba Member
Posted: Tue Nov 12, 2013 3:53 am Post subject: |
what's the VW number on those carbs you have? I'd match first the jetting to what they came with originally |
miguedangel Samba Member
Posted: Tue Dec 16, 2014 10:29 am Post subject: |
thank you very much for this post
but I have a some problem do not know if this well my left carb has a bronze not know how to describe... 050 can not be replaced and my carburetor right has bronze 100 ... that is correct??? I do not get information from them
Carbu Left
Carbu Right
reay Samba Member
Posted: Tue Dec 16, 2014 2:24 pm Post subject: |
[quote="Slow 1200"]automatic 68-69, with altitude correcting main jets:
This is great info - so the main jets are different sizes?
I needed to rejet for my new motor and couldn't with the Alt helpers - you just can't find them in different sizes. Ended up get a beautiful pair of 1970 carbs and re-jetting those. _________________ Tom Reay
Da weiss man, was man hat!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4897 Location: Southern AB
Posted: Tue Dec 16, 2014 3:08 pm Post subject: |
Quote: |
I needed to rejet for my new motor and couldn't with the Alt helpers - you just can't find them in different sizes |
You can just take out the big lump and put in a standard jet and plug _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
reay Samba Member
Posted: Tue Dec 16, 2014 4:55 pm Post subject: |
It seems like you could, but you can't.
No threads where the jet goes into the venturi - that's what the o-ring does, and the fuel bowl and even the float are a different configuration. _________________ Tom Reay
Randall Samba Member
Joined: October 03, 2004 Posts: 1402 Location: Orange County, Alta California, El Norte
Posted: Tue Dec 16, 2014 5:01 pm Post subject: |
What if you go to bigger displacement -- 1641, 1679, 1776, and so on -- do you use bigger jets? I read a HotVWs article back in the '70s about changing jet sizes. |
Posted: Wed Dec 17, 2014 3:18 am Post subject: |
[quote="reay"]
Slow 1200 wrote: |
I needed to rejet for my new motor and couldn't with the Alt helpers - you just can't find them in different sizes. Ended up get a beautiful pair of 1970 carbs and re-jetting those. |
the differently sized main jets (and air correctors) are due to the air cleaner design, if you use the later cleaner you can jet them symetrically
I thought altitude correction main jets could actually be adjusted, but I would definetely not trust a 40 year old diaphragm |
W1K1 Samba Member
Posted: Wed Dec 17, 2014 9:01 am Post subject: |
Quote: |
What if you go to bigger displacement -- 1641, 1679, 1776, and so on -- do you use bigger jets? |
Yes, sometimes even a change in exhaust on a stock motor can warrant a jet change. You can change the venturies for bus ones (26mm) as well for better flow.
I played around with mine on the 1600cc a bit before I bought the 36 dells for the 1904cc. This was about as good as it got when I was playing with it with the 26mm vents.
1973 super
daos Samba Member
Joined: January 01, 2017 Posts: 309 Location: Stockholm, SWE
Posted: Sun Jul 07, 2019 11:56 pm Post subject: |
so how does the archive work? if i go the index page there is no link called 'manuals' yet that's what's in the url. if i shorten the url to just 'manuals' there's a whole page of info which isn't in the index.. |
daos Samba Member
Posted: Mon Jul 08, 2019 8:58 am Post subject: Re: Stock jetting specs for PHN and PDSIT carbs |
ok, thanks. i was thinking about all the exhortations to 'use the search' so often aimed at people asking questions. turns out there's a bunch of hidden info on the site that would never turn up just using the indexed material.
what does samba dog say? |
