65 Bus door locks do not work
Page: Previous  1, 2
peaceful warrior
peaceful warrior is offline
PostPosted: Wed Jan 16, 2013 12:46 pm    Post subject: Reply with quote
This is a photo of a 68 door handle and wing. You can see that the wing is shorter but the handle is the same. I am checking on the part number now. Give me a few moments.
"Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian
fluxcap
fluxcap is offline
PostPosted: Wed Jan 16, 2013 12:48 pm    Post subject: Reply with quote
Wow, I couldn't see much size difference from the other pics, but it really jumps out when side by side!
Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black."
peaceful warrior
The J & K latches are right and left for a 67.
TOOB Member #15
Brian
peaceful warrior
PostPosted: Wed Jan 16, 2013 12:52 pm    Post subject: Reply with quote
Yes, it sure does. The L wing on the 68 handle is 12.5 mm from back to the tip of the L. Huge difference.
BarryL was spot on. You probably have 67 handles.
Also, I cannot find a part number on the L wing on the 68 latch, or my magnifying glass is not working.... Laughing Laughing
TOOB Member #15
Brian
peaceful warrior
PostPosted: Wed Jan 16, 2013 1:40 pm    Post subject: Reply with quote
BTW, I was thinking about a solution. Why not get new lock mechanisms that will work with the handle you have. They are more readily available including new, maybe.
TOOB Member #15
Brian
peaceful warrior
PostPosted: Wed Jan 16, 2013 1:50 pm    Post subject: Reply with quote
Correction: The K handle is a 67 and the J is a 68, right or left. I have no idea why the earlier handle has a later letter code. Hmm?
Clara?
TOOB Member #15
Brian
kevinflynn56
kevinflynn56 is offline
PostPosted: Wed Jan 16, 2013 3:17 pm    Post subject: Reply with quote
No lie! Side by side the difference is vast (by millimeter standards anyway)...
A friend of mine owns a body shop and has a box of old VW door handles. I'm heading out there this weekend.
I'll keep you posted.
Thanks everyone!
peaceful warrior
PostPosted: Wed Jan 16, 2013 3:53 pm    Post subject: Reply with quote
Thanks everyone!
Pray Dancing
TOOB Member #15
Brian
coolerthanelvis
coolerthanelvis is offline
PostPosted: Wed Jan 16, 2013 3:54 pm    Post subject: Reply with quote
L-wing part number.
This is not a part number, it's the key code for your bus. If you ever lose your keys, a locksmith can make you a new one using this number to look up the profile.
Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob
PostPosted: Wed Jan 16, 2013 5:09 pm    Post subject: Reply with quote
Moderator says:
Just wanted to say there is some great information and photos in this post so I added it to the Bus FAQ as "64-67 Front Door Handle Troubleshooting".
Thanks to the people posting.
peaceful warrior
PostPosted: Wed Jan 16, 2013 6:06 pm    Post subject: Reply with quote
L-wing part number.
Good to know, I thought it would have been on the cylinder.
TOOB Member #15
Brian
BarryL Premium Member
BarryL is offline
PostPosted: Wed Jan 16, 2013 7:30 pm    Post subject: Reply with quote
Just switch the cam/hockey stick thingy for the longer ones if you can find a good pair. Grab a couple extras as they are all notoriously weak.
peaceful warrior
PostPosted: Fri Jan 18, 2013 9:38 am    Post subject: Reply with quote
BTW, why isn't anyone repopping these? I searched for them, new and used and they are just not available.
TOOB Member #15
Brian
kevinflynn56
PostPosted: Wed Jan 23, 2013 12:43 pm    Post subject: Reply with quote
What a difference a hockey stick makes...
Nothing succeeds like success!!! Thanks for ALL the help youse guys are great!
BTW - looks like I have a pair of 68-69 door handles looking for a good home!
peaceful warrior
PostPosted: Wed Jan 23, 2013 3:00 pm    Post subject: Reply with quote
Cool! Good for you Kevin!
TOOB Member #15
Brian
srfndoc
srfndoc is offline
PostPosted: Wed Jan 23, 2013 3:24 pm    Post subject: Reply with quote
68 handles are one year only and pretty hard to find so I would post them on the Bay window parts forum.
Evan's Spreadsheet for Bus RPM, based on gearing & tire size (ODS Format)
"The world is in no hurry for another painted bus."
-Maurice
BulliBill
BulliBill is offline
PostPosted: Wed Nov 11, 2015 1:00 pm    Post subject: Re: 65 Bus door locks do not work Reply with quote
Howdy all,
Just to shed a little more light (or maybe add to the confusion) here a few photos and descriptions of what I call "lock actuator pins" for the push-button style outer cab door handles from 1964 through 1967 Split-Bus and the 1968 only Bay Bus. Some folks (above) call 'em hockey sticks, etc. If I understand Bus door locks correctly (and I don't claim to, only Gabriel can call himself a lock expert), the 1964 through 1966 push button handles used a "T" series key, lock tumbler and "lock actuator pin" with a "T" key code stamped into the shaft (see photos). Notice how thick the base material is on this one, almost 4.1mm thick (see my illustration and measurements). Then for the 1967 model year the "1967-only" remote lock mechanism was modified, the "L" series double-sided keys and lock tumblers were introduced and the "lock actuator pin" had a thinner base (2.3mm thick), a thicker, taller and different shaped pin shaft with angled support casting and the "L" series key code was stamped into the pin shaft.
So far - so good?
Okay, in 1968 the doors changed a whole bunch, and now we have a new remote lock mechanism for these Bay-Bus doors, the keys and lock tumblers remained "L" series, but a new and considerably smaller lock actuator pin (shorter, thinner pin shaft with no key code stamped in) was needed for the new 1968 only remote lock mechanism.
Hopefully my photos and my crude illustration of the different dimensions of each of the three pins will help to shed a little light on the difference. Over all of these years, probably lots of folks have switched and swapped parts and some of us now have issues with unwittingly mix-matched parts.
So if I got it right, the left pin is 1964 through 1966, the middle one is 1967 only and the right one is 1968 only. Let me know if there are corrections. I hope this helps, bring on the corrections, and any further clarifications!
Now go talk amongst yourselves...
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 12:41 pm    Post subject: Re: 65 Bus door locks do not work Reply with quote
^^ that was awesome Bill! I've developed an interest in these... since picking up a '65.
I took the liberty to put it all on one pic...
aka: Evan
mandraks
mandraks is offline
PostPosted: Thu Jul 14, 2016 3:03 pm    Post subject: Re: 65 Bus door locks do not work Reply with quote
here is a picture of awesome Bill
regards
Uli
easy e
easy e is offline
PostPosted: Thu Jul 14, 2016 3:20 pm    Post subject: Re: 65 Bus door locks do not work Reply with quote
Hah, Mr. Elliott is clearly an impostor Mad There is only one Awesome Bill Wink
aka: Evan
Page: Previous  1, 2
Page 2 of 2
