"Fuel shut Off Solenoid" tab broke!
opypr
opypr is offline
PostPosted: Sun Dec 23, 2007 8:32 am    Post subject: "Fuel shut Off Solenoid" tab broke! Reply with quote
I was removing the "idle air bypass" cable from my 34 PICT-3 CARB (the one that comes from the ignition coil), when I noticed that it came off with half of the tab. Which means that there is no tab for me to reconnect the cable to.
Could that "connector thingy" be replaced without having to replace the hole "fuel shut off solenoid".
Wondering also:
is the "IDLE AIR BYPASS CUT OFF VALVE" and the "Fuel Shut off solenoid" the same thing?
Thanks,
Opy Confused
opypr
opypr is offline
PostPosted: Sun Dec 23, 2007 9:15 am    Post subject: Reply with quote
Just wondering...
Should I put this message in another section? I have a Split, but its about a Carb
mandysbus
mandysbus is offline
PostPosted: Sun Dec 23, 2007 9:23 am    Post subject: Reply with quote
unscrew it from the carb and get another.........
opypr
opypr is offline
PostPosted: Sun Dec 23, 2007 10:37 am    Post subject: Reply with quote
I know I can buy a new one, but the question is, since it was working fine,
whether I can replace the "clip thing" only?
I found a webpage where they call it "electromagnetic cutoff valve "
VW Vet
VW Vet is offline
PostPosted: Sun Dec 23, 2007 10:55 am    Post subject: Reply with quote
Since half the tab is still there, solder a wire onto it with a disconnect a few inches down line from it.
opypr
opypr is offline
PostPosted: Sun Dec 23, 2007 11:11 am    Post subject: Reply with quote
I don't understand what you mean...
VW Vet
VW Vet is offline
PostPosted: Sun Dec 23, 2007 12:16 pm    Post subject: Reply with quote
Perhaps I didn't understand what you meant. When you say cable, do you mean wire? Are you talking about the electromagnetic valve that sticks out of the left side of the carb?
I thought you meant half the tab is still sticking out of the valve. If it is, solder a wire onto it. On the free end of the wire, crimp on a male connector which is compatible with the original wire's female connector.
Make the new piece of wire a few inches long.
bugginmiami
bugginmiami is offline
PostPosted: Sun Dec 23, 2007 3:25 pm    Post subject: Reply with quote
Anyone that has a box of spare carburators will have some spares of these.. Make a few phone calls..
* ---www.volksblast.com--- *
* -- South Miami - Feb 12th 2017 *
johnnypan wrote:
Never mess with a cat who smiles for his mug shot..he gives way less of a fuck than you do..
BarryL Premium Member
BarryL is offline
PostPosted: Sun Dec 23, 2007 7:22 pm    Post subject: Reply with quote
All those names mean the same thing. It's a cheesy way of keeping the bus from "running on" with crappy fuel. Those guys are saying to solder a wire lead to what's left of your busted one and add a male spade connector to it so you're good to go again. It might be easier to get another one.
j.pickens
j.pickens is offline
PostPosted: Mon Dec 24, 2007 9:03 pm    Post subject: Reply with quote
I usually just disable them.
Unscrew it, and you'll see the little piston which closes down when power is no longer applied. You just make it so it can't shut the fuel down by modifying or removing the piston. Depends upon the exact style solenoid you got, but its easy to figure out.
Then, you don't need any power to it.
If your engine diesels when you shut down the ignition, just put the gearshift in first with the clutch and brake depressed when turning off the ignition, then , as soon as you turn the key, keep the brake depressed, and release the clutch, thereby stopping the engine from turning and dieseling. It becomes second nature after a while.
BeaterBarndoor wrote:
Red Fau Veh wrote:
Ian
Ian is offline
PostPosted: Tue Dec 25, 2007 4:00 pm    Post subject: Reply with quote
Shocked Shocked
All your Buses are belong to us.
Love and good roads!
"I got the feeling that he and his buddies stay at the shop super-late every night wrenching on project VWs just for the sheer joy of it."
IN LOVING MEMORY OF ROB CRESS 1968-2012
View user's profile Send private message AIM Address Facebook Instagram Gallery Classifieds Feedback
cdennisg
cdennisg is offline
PostPosted: Tue Dec 25, 2007 6:02 pm    Post subject: Reply with quote
Just cut off the piston on the inside end of the solenoid (its usually brass and is easy to cut) and thread the body back into the hole. Don't forget to tape off or eliminate that wire to it from the coil. You don't need the cut off valve usually and if the car diesels when you shut it off, just either let it go till it stops or do as has been said already. Clutch in, shift into gear, foot on brake, release clutch to stop motor. It will not hurt anything and if you decide you want to put it back that way later, this will buy you some time till you can find a new one.
When these things fail they will cause your engine to run only off idle. I have had one fail while on a trip (back before I used to disable them on purpose) and it took awhile to diagnose why it would not idle. I just pulled it out and lopped off the piston. Bus ran great and I never looked back.
My uncle had a pyramid, and it never broke.
---Cold War Motors
SCZ9-1-1
SCZ9-1-1 is offline
PostPosted: Tue Dec 25, 2007 6:26 pm    Post subject: Reply with quote
My old carb was leaking in several different places and could no longer be patched with JB weld so I sent off a couple of old carbs I had lying around as cores to Chard's Carbs and had them send me a rebuilt one. The new one they sent had the electronic cutoff and at first it didn't work and had to be freed up by turning the set screw (located next to the wire tab) in and out again and that freed the solonoid. It still didn't run like my old one so I took out the electro thingymajig and put in the jet from my old carb (old carb did not have thingymajig) and engine runs fine with no dieseling except when engine is hot after a long run on a highway and even then I've never had to use the in gear cutoff method. I'm running a single port 1600 with a pict 30.
volkscafe
volkscafe is offline
PostPosted: Tue Dec 25, 2007 7:21 pm    Post subject: Reply with quote
Agreed...Just unscrew it and cut the piston/plunger end off and screw it back on and eliminate the wire to it. You probably wont notice a difference from when it was hooked up correctly and fully functional. Everything else said of your bus not shutting off properly is getting confusing and probably will not need any figuring out...Should shut off when you turn the ignition off as normal.
opypr
opypr is offline
PostPosted: Mon Dec 31, 2007 10:12 pm    Post subject: Reply with quote
What should I use to solder it?
Embarassed
Bub
Bub is offline
PostPosted: Tue Jan 01, 2008 12:07 pm    Post subject: Reply with quote
uh...Soldering iron ?
Get one at radio shack for $8.
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
opypr
opypr is offline
PostPosted: Tue Jan 01, 2008 12:19 pm    Post subject: Reply with quote
Am asking because I was thinking of the heat while travelling, and don't have a clue of which material won't melt and make it come off again...
obviously, Im not an expert Confused
codeMechanic
codeMechanic is offline
PostPosted: Tue Jan 01, 2008 12:30 pm    Post subject: Reply with quote
the plastic on the wires would melt long before the solder does
don't worry about it, solder it on , I just happen to be doing this for mine today, strange coincidence
opypr
opypr is offline
PostPosted: Tue Jan 01, 2008 1:24 pm    Post subject: Reply with quote
Thanks, codeMechanic.
I happen to own a Soldering iron.
What should I use to solder it with?
I have used it before with a "wire" type thingy that comes "looped", looks like silver (I know it is not), for electrical computer cables... Sorry that I don't know how it is called.
But, since we are talking Automotive motor, I guess it should be something different Confused
VW Vet
VW Vet is offline
PostPosted: Tue Jan 01, 2008 2:02 pm    Post subject: Reply with quote
Go to Radio Shack and get some rosin core solder.
Heat the tab, melt on some solder.
Heat the wire, melt on some solder.
Put the two together, apply heat to melt them together.
If you have solid non-core solder, get a small can of rosin to dip onto the parts.
Do not use acid core solder for electrical work.
