woggs1 Samba Member
Joined: February 22, 2007 Posts: 531 Location: South Pacifica California
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
woggs1 Samba Member
Posted: Thu Jan 17, 2013 9:36 am Post subject: |
dobryan wrote: |
How do you intend to use it? |
On the roof to recharge the house battery. _________________ 4 speed 88 Westy |
ZanaEvyPapa Samba Member
Joined: July 31, 2010 Posts: 255 Location: Gainesville, FL
Posted: Thu Jan 17, 2013 9:48 am Post subject: |
more info here: http://www.solyndra.com/technology-products/cylindrical-module/
These are not good for mobile applications because they are basically glass tubes. They would break in no time. Also, $2.50/watt seems expensive, no? _________________ 82 Diesel Westy
03 Jetta TDI
Gainesville, FL |
peasant Samba Member
Posted: Thu Jan 17, 2013 9:56 am Post subject: |
ZanaEvyPapa wrote: |
Also, $2.50/watt seems expensive, no? |
Has solar come down that much? I remember not that long ago when I bought some panels 2.50 was a steal. _________________ 89 wolfsberg weekender carat
89 Westfalia |
bluebus86 Banned
Posted: Thu Jan 17, 2013 11:44 am Post subject: |
110 volts, 40 mA shorted current. (at "full sun")
you can buy ten for $7.50 each.
You will need some electronics to get the voltage right for a battery charger application.
You will need to rig some mounting system.
I dont know what they wiegh, but they are a meter long and near an inch in diameter and filled with a silicone fluid. They likely are not light.
since they are glass, breakage may be an issue in a mobile applicaton. you may have to consider shock mounts, and a protective cover.
Seems like it might be a bit of work to do it.
If you do it, you should probably buy some spares while you still can. when there gone there gone. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Thu Jan 17, 2013 12:50 pm Post subject: |
HSC is a cool place to shop for electronic stuff, i have gotten many bits from them over the years. Maybe i will swing by and check out obama's(our) failed loan money investment. |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Thu Jan 17, 2013 1:00 pm Post subject: |
I might have to ask my brother or father to get me some of those to use on my garage if the Rohnert Park store has any in stock. |
yiucycle Samba Member
Posted: Thu Jan 17, 2013 6:25 pm Post subject: |
wonder how to run this so it will go from 110v to 12v. Will a MMPT charger can convert that high of a voltage? _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
insyncro Banned
Posted: Fri Jan 18, 2013 7:23 am Post subject: |
I would use the tubes in a residential setting, but not for a mobile situation.
Too fragile and other, better suited PVs are not that much more cost when you will be all said and done. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
