dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Jan 17, 2013 1:11 pm Post subject: One headlight comes on with parking lights...(now BOTH)... |
<DISCLAIMER: I just searched on this for an hour & found nothing quite like it.>
ISSUE: The right low beam always comes on with the parking lights.
Switch through to full headlights and no problems at all - I'd just like to
be able to run the parking lights by themselves, as they were intended.
We've owned the van about 5 years and it's been doing this all along.
I've cleaned grounds, (especially when installing Jay's headlite relays),
fixed issues with incorrect/poor connections on the right parking light,
and will soon upgrade to new ceramic sockets for the 9004 bulbs.
Otherwise, all lights operate correctly - no other issues, ever.
As it hasn't seemed to be a critical issue, I've remembered & subsequently
forgotten about it every single time I get in the van...until now.
Any suggestions? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Jan 18, 2013 2:19 pm Post subject: |
BUMP.
Just lookiing for ideas here. I'm not really an electricity guy,
but I might have sounded like one for a minute...
...Anyone? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Terry Kay Banned
Posted: Fri Jan 18, 2013 6:48 pm Post subject: |
You've got a power wire to the headlamp wired wrong.
Check the back end of your Bentley for the scematic.
You've got a hot wire at the turn signal circuit feeding the headlamp. _________________ T.K. |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sat Jan 19, 2013 4:48 am Post subject: |
Did you install the 7" round headlights in your '86, or did you buy the van that way? If a previous owner installed the lights, there could be some creative wiring that needs to be addressed. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
Posted: Sat Jan 19, 2013 7:01 am Post subject: |
It's all stock before I got it, but I did cut out a set of broken fog lights he
had bolted to the bumper. Could it be they were on the headlite circuit?
There was a pair of relays doing nothing when I got there with your kit, Jay.
Must have been for the fogs...I guess you could say it was mildly molested?
Still not sure what to look for. Gotta get out there & but it's gonna be -10
before I can get to it...
"The WonderVan"
insyncro Banned
Posted: Sat Jan 19, 2013 7:28 am Post subject: |
Fogs usually only have one relay.
I would double check all the wiring versus the stock configuration per year...than check over the headlight relay wiring versus vender instructions.
May turn out to be a dropped ground at the non functional light. |
Terry Kay Banned
Posted: Sat Jan 19, 2013 7:51 am Post subject: |
Dylan,
He's got one head light working with the turn signals only--the Popeye look.
That one headlamp is picking up 12 volts from the parking lamp circuit somewhere. _________________ T.K.
insyncro Banned
Posted: Sat Jan 19, 2013 8:05 am Post subject: |
Ah ha....my bad.
Creative wiring for sure. |
Posted: Sat Jan 19, 2013 8:19 am Post subject: |
Unless your van is a very early '86 it should have come with rectangular headlights from the factory. VW is infamous for using whatever was kicking around on the assembly line in transitional years, so you could have a mix of '85 model year and '86 model year stuff in your van.
What style is your fuse block? Does it take standard ATO blade fuses, or the older ceramic GBC style?
There is really no way to know what sort of hacks a previous owner could have pulled off without digging in and doing some investigating. 12V electrical stuff is pretty simple, so it isn't that hard to get something to function without actually being wired correctly. Pull the upper grill off and see what is in there. If the wires for the headlight sockets don't have any butt connectors/wire nuts etc. it is possible that your van came with the round lights. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
Posted: Sat Jan 19, 2013 1:00 pm Post subject: |
I don't have round lights...stock rectangles.
Newer spade-type fusebox.
Build date is 1/86, so about mid-year. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sat Jan 19, 2013 2:12 pm Post subject: |
Sorry, on my tablet the van in your avatar looks like it has round headlights.
It is probably still worth pulling the grill off and looking for any obviously non-stock connectors. If the yellow low beam wires are tapped into anything else, that would most likely be the culprit.
When you say that your headlight comes on with the running lights, do you mean that it comes on when you turn the headlight switch to the 1st position, or does it come on when you turn the key on? Your location appears to be right on the US/Canada border. Is your van a Canadian model, or US spec? _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
Posted: Sat Jan 19, 2013 3:55 pm Post subject: |
thatvwbusguy wrote: |
...headlight comes on...when you turn the
headlight switch to the 1st position... |
This.
The van is definitely US spec.
Documentation shows original delivery to a dealer in Albequerque.
I've been into the headlights a few times (just replacing bulbs & a cracked lens) but not
with this problem in mind. I don't recall anything wierd-looking but also not sure I'd
know it if I saw it. I'll get out there later this winter/spring & start the detective work.
PS: It might be a while - looks like at least a week of sub-zero temps here.
I'm NOT planning any garage work until that changes...or March, anyway...
Thanks, guys... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Tue Mar 26, 2013 8:21 pm Post subject: |
Finally got into this today. I put in new ceramic sockets (per your
recommendation, Jay) & new local grounds at the bucket brackets on each
side. The headlights are now perfectly bright. Now the only problem is...
...BOTH headlights now come on at the same time w/the parking lights @
headlight position 1 (nothing changes if I switch to position 2). I even pulled
the parking lamp, disconnected the ground & jumpered to a known good
grounding point to make sure it was isolated it from the headlight...no
change/same difference.
So now here's my question:
Is this possibly a failure mode for the headlight switch? I know the PO
replaced it but it was a while ago for sure. It seems like the switch does turn
things on & off, but the headlights are shorted to position 1 on the switch
Should I just throw in a new switch? Everything else seems to check out...
"The WonderVan"
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Tue Mar 26, 2013 8:28 pm Post subject: |
Before you replace the switch, pull just the headlight feed off the switch. Do they still come on at the first setting? If so, not the switch. If they now don't come on, bad switch. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
Posted: Tue Mar 26, 2013 8:32 pm Post subject: |
Great - very logical tip. I'll try that tomorrow. Thanks! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
danfromsyr Samba Member
Posted: Tue Mar 26, 2013 10:58 pm Post subject: |
I dunno why this thread made me think of this holiday song...
and ya know "Christmas" can be swapped with "Westfalia" pretty evenly...
Quote: |
The first thing at Christmas that's such a pain to me
Is finding a Christmas tree
The second thing at Christmas that's such a pain to me:
Angry husband:
Rigging up the lights
And finding a Christmas tree
The third thing at Christmas that's such a pain to me
Man getting over being drunk:
Hangovers
The fourth thing at Christmas that's such a pain to me
Exhausted man:
Sending Christmas cards
Hangovers
The fifth thing at Christmas that's such a pain to me
Five months of bills!
Hangovers
The sixth thing at Christmas that's such a pain to me:
Nervous wife:
Facing my in-laws
Oh, I hate those Christmas cards!
Hangovers
Rigging up these lights!
The seventh thing at Christmas that's such a pain to me:
Nervous wife's husband:
The Salvation Army
Facing my in-laws
Oh, geez!
I'm tryin' to rig up these lights!
The eighth thing at Christmas that such a pain to me:
Whining kid:
I WANNA TRANSFORMER FOR CHRISTMAS!!!!
Charities,
And whataya mean "YOUR in-laws"?!?
Oh, making out these cards
Honey, get me a beer, huh?
What, we have no extension cords?!?
The ninth thing at Christmas that's such a pain to me
A tired father:
Finding parking spaces
DADDY, I WANT SOME CANDY!!!!
Donations!
Facing my in-laws
Writing out those Christmas cards
Hangovers!
Now why the hell are they blinking?!?!?
The tenth thing at Christmas that's such a pain to me:
A mother:
"Batteries Not Included"
No parking spaces
BUY ME SOMETHIN'!!!
Get a job, ya bum!
Oh, facing my in-laws!
Yo-ho, sending Christmas cards
Oh, geez, look at this!
One light goes out, they ALL go out!!!
The eleventh thing of Christmas that's such a pain to me:
A male couch potato:
Stale TV specials
No parking spaces
DAD, I GOTTA GO TA BATHROOM!!
Charities!
She's a witch...I hate her!
Oh, I don't even KNOW half these people!
Oh, who's got the toilet paper, huh?
Get a flashlight...I blew a fuse!!
The twelfth thing of Christmas that's such a pain to me:
Two men:
Singing Christmas carols
Stale TV specials
No parking?!?
WAAAAAAAAAAH! WAAAAAAAAAAH!
Charities!
Gotta make 'em dinner!
I'm not sendin' them this year, that's it!
Shut up, you!
FINE! YOU'RE SO SMART, YOU RIG UP THE LIGHTS!!!
And finding a Christmas tree |
and the VW camper version...
Now please bear with me, I transcribed this at 2am just before bed... it may need a little polish before we can sing it for the holidaze
Quote: |
The first thing about camping that's such a pain to me
Is finding a Shady tree
The second thing about camping that's such a pain to me:
Angry husband: Fixing the lights
And finding a Shady tree
The third thing about camping that's such a pain to me
Man getting over being drunk: Hangovers
Fixing the lights
The fourth thing about camping that's such a pain to me
Making Reservations
Hangovers
Fixing the lights
The fifth thing about camping that's such a pain to me
Five months of SNOW!
Making reservations
Hangovers
Fixing the lights
The sixth thing about camping that's such a pain to me:
Nervous wife: Facing my in-laws
Oh, I hate those Reserved sites!
Hangovers
Fixing these lights!
The seventh thing about camping that's such a pain to me:
Nervous wife's husband: The Park Ranger!
Facing my in-laws
Five months of snow!
Reservation Fees!
Oh, geez! is the world spinning!
I'm tryin' to Fix these lights!
The eighth thing about camping that such a pain to me:
Whining kid: I WANNA MAKE SMORES!!!!
Campground Policies
Five months of Snow!
Oh, making out these Reservations nine months in advance!
The ninth thing about camping that's such a pain to me
A tired father: Finding Level parking spaces
DADDY, I WANT MORE MARSHMALLOWS!!!!
Quite hours?
Facing my in-laws
Writing out those Site #s
Hangovers!
Now why the hell are the lights blinking?!?!?
The tenth thing about camping that's such a pain to me:
The Batteries Not charging
No level parking spaces
BUY ME SOMETHIN' from the concession store!!!
Get a job, ya bum!
What do you mean all the sites are booked!!
Peeing in the bushes..
The eleventh thing about camping that's such a pain to me:
No TV RECEPTION!!
The battery is going dead
Poison IVY
Noisy Neighbors
The twelfth thing about camping that's such a pain to me:
Singing campfire carols
The Battery is dead
No parking, it's a hike in campsite? ?!?
Would the barking dogs SHUT UP!
I'm not Making reservations this year, that's it!
waking up on a picnic table.
And finding a Shady tree |
Abscate wrote: |
Posted: Wed Mar 27, 2013 5:30 am Post subject: |
"The WonderVan"
Posted: Thu Mar 28, 2013 3:57 pm Post subject: |
shadetreetim wrote: |
Before you replace (it), pull the headlight feed off the switch... |
The spades are all the locking type - they're tight in the connector. How/what to use to get them out...??? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Mon Apr 15, 2013 6:45 pm Post subject: |
So after straightening out my windshield washers this weekend,
I went to check into the headlights again. I turned on the headlights,
hit the high beams once and the wipers came on for a swipe or two.
Turned lights off & tried again...no more wipers, but still both headlights
come on with the parking lights.
Makes me think it might be the first symptoms of an ignition switch on the
way out. Could this explain the original headlight/parking light issue?
I do have a spare in the glove box - maybe I'll just swap it in & see... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Mon Apr 15, 2013 10:48 pm Post subject: |
Another possible suspect would be the windshield wiper switch, since the high beam switch is actually part of this assembly.
http://www.van-cafe.com/home/van/page_63_157/windshield_wiper_switch_-_black.html _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
