NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Thu May 09, 2013 8:29 am Post subject: |
thewalrus wrote: |
You can buy new panels here or just as easily make one. And yes, there was an optional inside release handle:
Also, nice to see another local bus. Hope to see you at some shows this season |
I have been told that these internal-release, rear-hatch locks, are only compatible with the early model-years of 1968~79 VW Type 2. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Thu May 09, 2013 11:07 am Post subject: |
NASkeet wrote: |
thewalrus wrote: |
I have been told that these internal-release, rear-hatch locks, are only compatible with the early model-years of 1968~79 VW Type 2. |
That would cover the entire ( U.S.) spectrum of bay windows. In a different post there is details as to what years these fit. And by fit I mean bolt on, there was talk of a small modification that had to be done to fit other years. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Wed Jul 02, 2014 7:07 am Post subject: |
Been a while since I've updated this thread. I'll post some pics later on but I've got a lot of the van stripped of the house paint used to put the trees on, revealed a few small bondo spots, a previous weld repair, and lots of OG paint/metal, which is nice. Also got the right rear corner and battery tray welded in.
some good:
-collected parts for complete exhaust restoration.
-got new cheap Brazilian door seals on to keep the water out (old Germans were leaking bad, will use Germans after painted)
some bad:
- Headliner failed, now sagging just as it warmed up this year, was fine last year. (might re-do with better adhesive, suggestions? or paint/stain. Was the birch there originally unstained? really bummed about this one, took a whole weekend to do)
-after leaving the bus in the elements with leaking door/windshield seals, I got a nice soft spot on the driver's side floor. Dog-leg section seems ok, just one spot where the cab floor hits the seam sealer on the dog-leg. Might not be too bad if I can get at it sooner rather than later. This, after I sanded down the cab floor, both sides, treated with rust converter and painted a few months back.
Seems all my efforts so far are failing or making things worse. Ima keep digging into this money pit though....
Hopefully I can get some pictures up soon... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Tcash Samba Member
Posted: Wed Jul 02, 2014 9:04 am Post subject: |
Thanks for the tip!
For future Sambans, Permatex headliner and carpet spray adhesive DOESN"T WORK SO HOT, at least on the Marine Vinyl I used, which was pretty thick. Held for approx. 1 year then let go upon New England's thaw. Maybe as the wood expanded/ contracted from moisture? Perhaps water sealing the wood before applying adhesive would help? _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
Posted: Tue Sep 26, 2017 5:34 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
long time no post. Most of what's been going on with my bus has been un-doing of former hacks, stripping paint, and making body repairs. I really thought 3-4 years ago that I'd have this rig painted by now, but the money to do it right has been in short supply.
I digress. Posting here today with a question on my fuel injection. I have recently been having trouble with it dying once it has warmed up, and running like shit. However I can get a good 10 minutes out of it running so I have been able to run tests, check for leaks, and do regular maintenance.
Made a breakthrough last night and got it to run indefinitely, at least 30 mins, before shutting it down myself, then it started again easily when hot, which it wasn't before. Anyhow during my battery of testing and poking and prodding I noticed something, and thats my question for today.
The vacuum hose going from the decel valve down to the rubber T that goes onto the brake booster, that hose is currently normal braided hose of the correct diameter (12mm?) that one would use for the EVAP cannister, or the oil breather hose on a type 1 engine.
This hose collapses pretty good when the engine is started. Air is still able to pass through the sides I would guess but the middle sucks in on itself. I guess this means it holds vacuum so thats good at least? As part of my testing I removed this hose while the engine was running and there was some hissing while removing it and the engine died once it was removed, so at least nothing is leaking there.
My question is, is it ok that this hose is collapsing? Should I order something like this instead?
https://www.belmetric.com/black-polyamide-hose-c-1...-6426.html
I assume this hose wouldn't collapse and it's rated to withstand temps up past 200* I looked through legit vacuum hose and there is nothing in 12mm, mostly smaller ID lines available. Same with rubber coated polyamide hose.
I appreciate any suggestions folks may have. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Tue Sep 26, 2017 6:19 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
Try grounding the wire going to the temperature sensor on the drivers side cylinder head & see if it runs any better. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Sep 26, 2017 6:39 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
TDCTDI wrote: |
Try grounding the wire going to the temperature sensor on the drivers side cylinder head & see if it runs any better. |
asking about a vacuum hose here. Thanks anyway. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
busdaddy Samba Member
Posted: Tue Sep 26, 2017 7:20 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
That hose is sized like that for a reason, its likely not related to your dying issue but when it's decel time you need the full flow. The Belmetric link isn't working for me, but NAPA sells a 1/2" brake booster hose IIRC, that's only 1mm bigger and should work with some brake reservoir line sleeves or heat shrink on the fittings first. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Sep 26, 2017 7:48 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
busdaddy wrote: |
That hose is sized like that for a reason, its likely not related to your dying issue but when it's decel time you need the full flow. The Belmetric link isn't working for me, but NAPA sells a 1/2" brake booster hose IIRC, that's only 1mm bigger and should work with some brake reservoir line sleeves or heat shrink on the fittings first. |
BD here are the specs:
asiab3 wrote: |
Posted: Tue Sep 26, 2017 8:03 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
ROCKOROD71 wrote: |
TDCTDI wrote: |
asking about a vacuum hose here. Thanks anyway. |
No prob, just with the symptoms that you provided, it didn't sound vacuum related. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Sep 26, 2017 12:16 pm Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
busdaddy wrote: |
Is it too much to ask for a properly fitting vacuum hose?
seriously, no one out there has an opinion on this Cohline 12mm Polyamide hose? Works up to 217 PSI and lists vacuum hose as an application. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Tue Sep 26, 2017 6:58 pm Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
if it's old an spongy try to replace it with whats there.
I use the breather hose you posted on all of my *GASP* brake booster stuff and have NEVER had it collapse.
that said, your link shows what, 15mm o/d which would be a bitch to neck down to 12mm...
if you want plastic, mk1-3 and some 4 had hard plastic booster lines, and the 12mm stuff will slide over it (I had to do this for a 16v swap)
the only time I have seen that stuff collapse is when it has been exposed to oil. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Wed Sep 27, 2017 6:56 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
skills@eurocarsplus wrote: |
the only time I have seen that stuff collapse is when it has been exposed to oil. |
Skills, the hose there now is maybe a year old. It is still soft, I guess that is the problem? You can easily pinch it together by hand, so I am guessing when a lot of vacuum is applied it's not too hard to collapse it. Should the engine not be producing this much vacuum? Maybe this is a clue to my running issues, although I got huge improvement in that in the last couple of days. I still want to clean a bunch of electrical connections and inspect some relays before I take it on a long test drive, but it IS running through warm up and not dying on its own anymore.
The link i posted is for hose with an ID of 12mm, which is what I thought was needed in this application. perhaps I am mistaken? Maybe someone can correct me and let me know what size actually goes there. Even Mayor Ratwell's site is kind of sketchy on the details:
http://www.ratwell.com/technical/VacuumHoses.html
It shows a short length of hose coming off the decel valve with an ID of 15mm, then hard tubing going down to the brake booster T, the hard tubing OD is 15mm, so it makes sense that the hard tubing fits into the short hose coming off the decel valve, and that the T ID is 15mm as well, though Ratwell says that info is not available.
Anyhow, my current set up is one long braided hose, I guess the ID is 15mm then, the breather hose. On the brake booster T it is attached like this:
using a small metal pipe fitting. It fits snug into the T. So I guess I need a 15mm hose that WON'T collapse with the applied vacuum. Would wire-reinforced hose work? Something like this:
https://www.belmetric.com/wire-reinforced-hose-c-1...-9456.html
Really appreciate the response. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Sep 27, 2017 7:55 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
For a temp fix, / testing- you can feed a screen door return spring (or such) inside and see if it helps. I know- don't be in such a hurry- just get the right hose and don't worry bout it. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Wed Sep 27, 2017 8:03 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
...and the appropriate hose would be.....?
Not is a hurry at all, still have some things to do here and there before I attempt driving this thing any distance. However, if I had come to a consensus yesterday on an appropriate hose It would have been ordered already and in my hands tomorrow.
Busdaddy (if you ever look at this thread again) is the 1/2" hose you suggested 1mm bigger than 12? or the stock 15? I guess I could take a spare decel valve with me to try it, but really, I would like to get a proper size metric hose if I can. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
furgo Samba Member
Joined: September 06, 2016 Posts: 944 Location: Southern Germany
Posted: Wed Sep 27, 2017 10:27 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
Just to be clear, you're looking for the specs of hose C in ratwell's diagram, right? That is:
I asked a similar question a while ago here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8480061#8480061
IIRC the consensus was that it was vinyl hose. If you need the missing info from ratwell's page (the inner diameter, right?), here's what I've just measured on a spare one I've got at home:
- OD = 15 mm
- ID = 13 mm
ROCKOROD71 wrote: |
Made a breakthrough last night and got it to run indefinitely, at least 30 mins, before shutting it down myself, then it started again easily when hot, which it wasn't before. |
Good job! Could you trace what you did to get it to run indefinitely? _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Decode your M-Plate |
Posted: Wed Sep 27, 2017 10:41 am Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
Well, KINDA hose C. right now it is one hose running from the T to the decel valve, so basically one LONG hose D in Ratwel's diagram, using a short metal coupler to mate it ti the brake booster T.
The hose I am using collapses so I am trying to figure out a suitable hose to replace it with. I could use the vinyl hose like you show if I knew what to buy, what OD (outside diameter) that tubing is.
Can't really trace what I did to get an improvement in my running situation. I replaced the TSII sensor first and that had basically no effect. then I adjusted the valves, point gap (my points were virtually NOT opening) changed the oil, tightened every clamp on every hose I could, tightened every screw, nut, bolt I found loose, pulled relays and checked fuses for damage, and started cleaning grounds and electrical connections. Somewhere in there it started running for longer than 10 minutes. No idea what did it but NONE of this can possibly hurt and its free to me. We'll see how far I can get before I have to run to someone for help.
If you have measurements on that hose I would greatly appreciate it, thanks so much. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
furgo Samba Member
Posted: Wed Sep 27, 2017 1:53 pm Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
ROCKOROD71 wrote: |
If you have measurements on that hose I would greatly appreciate it, thanks so much. |
The OD is essentially what I already mentioned on my last reply, but I'm adding all the measurements in a diagram to have them all in one place. That's all you should need I think. I hope it helps.
ROCKOROD71 wrote: |
Can't really trace what I did to get an improvement in my running situation. [...] |
Bummer, I was hoping for that magic finding that would help me on my bus too In any case, glad you got it working! _________________ '79 Westy, P22 interior, FI 2.0 l Federal, GE engine (hydraulic lifters)
Posted: Wed Sep 27, 2017 2:10 pm Post subject: Re: KrustyKamper 1977 Westy FI *** UPDATE *** |
Furgo, thank you so very much, the diagram is great. I think I can get what I need now and have this as reference for the future, shopping around for a proper tube per factory specs.
My takeaway with these FI engines is that you have to really just go through them step by step when they give you these weird troubles. It is not particularly hard or difficult to understand but it is TEDIOUS. More so than a simple type 1 with a carb, where it is air, fuel, spark and go. On these it's like "oh, that one electrical connection that is buried under the plenum is a little corroded? COOL your engine runs like shit now"
In particular I was very naughty and drove this shitbox through an entire winter in Boston, where they not only salt the roads but use this liquid brine that basically melts everything it touches, including metal. Needless to say there is a lot of cleanup to do, its been slow going.
I'm sure you will get to the root of your problem, just keep knockin things off the list and keep posting in your thread, you are getting great results! See what happens when you get that TSII replaced.
PS- where in Europe are you located? _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
asiab3 wrote: |
