Herrod Helper causing higher temps?
Steve22
Steve22 is offline
PostPosted: Sat Jan 26, 2013 8:42 pm    Post subject: Herrod Helper causing higher temps? Reply with quote
Yeah, you read it right...
I wanna know if anyone has ever had a Herrod Helper cause higher oil temps or higher engine temps in general.
'65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter
JerryMCarter1
JerryMCarter1 is offline
PostPosted: Sat Jan 26, 2013 10:10 pm    Post subject: Reply with quote
http://vwparts.aircooled.net/Herrod-Helper-Rear-Spoiler-Street-Wing-p/herrod-helper.htm
No way --
Jerry
Experience always triumphs over hearsay and You get to select which theory to believe
baxsie
baxsie is offline
PostPosted: Sun Jan 27, 2013 9:59 am    Post subject: Reply with quote
I think it would create a line of low pressure just under it. Since that is where the primary engine cooling air is supposed to come in, you would want high pressure on those vents, not low pressure.
I think the cooling system would have to work harder to pull air in through the its main vent, sucking against the suck created under the spoiler.
I think higher engine temps would be guaranteed.
1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
"I'm not getting older, I'm getting bitter."
JerryMCarter1
PostPosted: Sun Jan 27, 2013 10:03 am    Post subject: Reply with quote
the claim is :
"The installation of this rear wing will help your car's stability over 60mph,"
Very doubtful - I would like to see them prove it !
Looks like a piece of junk to me !
'69Custom
'69Custom is offline
PostPosted: Mon Feb 11, 2013 5:55 pm    Post subject: Reply with quote
JerryMCarter1 wrote:
the claim is :
I can confirm your doubts, personally. I've run both versions. Regardless of aesthetic tastes, the only noticeable difference achieved from either one has been an overall reduction of road noise.
-Tim
1969 Frankenbug
1965 Ford Mustang
:2gunfire: F-U-M-P!
~"I thought I was wrong once, but I was mistaken." ~The Boss
Please excuse any typos as my iPhone doesn't speak English very well.
tham64 wrote:
Why tune a big round again and again????? For me.... 1 hour will solve the case Cool
www.endlesscustomz.com
