boomtown Samba Member
Joined: July 05, 2008 Posts: 68 Location: Daytona Beach
Posted: Sat Feb 02, 2013 9:38 am Post subject: Horn wiring, 1972 super |
https://www.thesamba.com/vw/gallery/pix/1021101.jpg
Can get horn to work with jumper from wire in steering colume center to horn ground but how do I now make the physical connection without the jumper?
David _________________ When the children get older and want to know where the money went, show them your vacation videos. |
Jeremy1984 Samba Member
Joined: November 03, 2012 Posts: 129 Location: Etowah,TN
Posted: Sat Feb 02, 2013 11:51 am Post subject: |
when you pull the horn button off of your steering wheel there should be a short wire running from the button to the center of the wheel (where a brass ring makes contact with a metal tab on the turn signal switch assembly). Then the ground goes through the horn button to the turn signal switch wiring. here is a diagram from speedy jim's site. If everything inside the column is right, then taking the brown horn wire out to the other side of the horn should trigger it. hope this helps.
_________________ Rebel Wire Representative
[email protected] |
Posted: Sat Feb 02, 2013 1:03 pm Post subject: |
Jeremy1984 wrote: |
Thanks Jeremy, On my way to the garage to see if this helps.
Thanks
Posted: Sun Feb 03, 2013 6:58 am Post subject: |
Found the two plugs located on the bottom of the steering wheel column. The brown wire is located in the plug close to the passenger side. Brown wire had been cut and spliced to a red wire that dead ended. The PO had sprayed everything under the dash so locating colored wires was difficult. I wiped most painted wires with lacquer thinner and identified most colors. Good progress on that front. I now have continuity between the copper contact located under the steering wheel and the brown wire. It appears the PO removed the brass ring from under the wheel. I now need to work through this problem. Thanks for the help to date. More progress to follow.
