ARPM Case - Cam Sensor?
risk
risk is offline
PostPosted: Tue Feb 05, 2013 10:07 am    Post subject: ARPM Case - Cam Sensor? Reply with quote
I'm running an old ARPM two piece case.. noticed the indention and I started thinking..
Is the indention in the casting in this area meant to be machined for a cam gear sensor?
Dale M.
Dale M. is offline
PostPosted: Tue Feb 05, 2013 10:19 am    Post subject: Reply with quote
Doubt it..... Cam sensor were never really a VW thing.... Only real sensor was on flywheel for diagnostics.....
Dale
“Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
risk
risk is offline
PostPosted: Tue Feb 05, 2013 12:14 pm    Post subject: Reply with quote
So, if not for a cam sensor, what is the indention cast in there for?
bug66
bug66 is offline
PostPosted: Tue Feb 05, 2013 12:58 pm    Post subject: Reply with quote
Dale
I do agree on stock engines. But on an ARPM case?
What else (if it is for a sensor at all) could it be for?
Dale M.
Dale M. is offline
PostPosted: Tue Feb 05, 2013 1:33 pm    Post subject: Reply with quote
How just about a characteristic of casting.....And nothing more...
Dale
Steve Arndt
Steve Arndt is offline
PostPosted: Tue Feb 05, 2013 3:40 pm    Post subject: Reply with quote
Go for it!
http://www.badbugracing.com/cam_sensor.htm
SRP1
SRP1 is offline
PostPosted: Tue Feb 05, 2013 5:07 pm    Post subject: Reply with quote
Let's not speculate...Instead take a measurement from the centerline of the cam to that detent, and see if it makes sense for a cam sensor location.
I don't think that's a casting characteristic, but who knows.
I'm leaning more to the fact that it may be a possible sensor location, but only a measurement will tell. From the pic it looks a little to far outboard????
lostinbaja
lostinbaja is offline
PostPosted: Tue Feb 05, 2013 6:22 pm    Post subject: Reply with quote
If I'm not mistaken, ARPM cases were out of production long before crank position sensors were used, let alone cam position sensors. I could be wrong?
Jerry...
If it's being towed, it must be a trailer!
"Vee Grow Too Soon Oldt Und Too Late Schmardt"
RIP Morgan
My photos
http://www.manxgallery.org/gallery/album92
mcmscott
mcmscott is offline
PostPosted: Tue Feb 05, 2013 7:42 pm    Post subject: Reply with quote
The boss may be in a correct(kinda) location but,,, Ding! Ding! Ding!
SRP1
SRP1 is offline
PostPosted: Tue Feb 05, 2013 8:57 pm    Post subject: Reply with quote
Anyone know the last year of production for those cases?
risk
risk is offline
PostPosted: Wed Feb 06, 2013 7:38 am    Post subject: Reply with quote
From what I have read the cases were produced from 1982-1985, and A-RPM was sold to Dee Engineering in 1988.
Got that info from this site:
http://deanodyno-soars.com/history.html
I was thinking about starting a thread dedicated to A-RPM stuff. So far I have the case, the generator stand, and an air filter top. I know that they also made heads and I've seen an A-RPM shifter for sale in the classifieds before.
risk
risk is offline
PostPosted: Wed Feb 06, 2013 7:59 am    Post subject: Reply with quote
Steve Arndt wrote:
Go for it!
It looks like the indention on my case is about the same distance from the cam centerline. I will measure and post what I find.
Is this your engine? I was wondering how you balanced the cam and gear..
Stripped66
Stripped66 is offline
PostPosted: Wed Feb 06, 2013 9:38 am    Post subject: Reply with quote
FWIW, later cases did not have that indentation in the casting.
66brm wrote:
Bodacious wrote:
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor.
I don't think electrickery works that way
flyboat
flyboat is offline
PostPosted: Wed Feb 06, 2013 9:56 am    Post subject: Reply with quote
Are these cases special in any way?
79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car
SRP1
SRP1 is offline
PostPosted: Wed Feb 06, 2013 11:40 am    Post subject: Reply with quote
Looking closer (not on my phone) it looks like a drill index mark.
It appears to be in the same location as the oil galley restrictor/plug on
a stock factory case.
I'll bet that's all it is....
