GB2S Samba Member
Posted: Wed Feb 06, 2013 7:16 pm Post subject: Engine swap question 1600dp in a 63 |
I am putting a 1600 dp from a 73 into my 63 and thought I would be a little proactive and ask what am I going to need to get this engine in. I thought I would ask before I have the engine balancing on a jack and it's 5 minutes before the part store closes.
A little back ground there is currently an engine in it, unfortunately its out of a 58, but I do have all the tin.
The engine going in is completely stock. The only modification is I have the 66 6volt flywheel so I don't have to grind the tranny..
So whats the installation process, and what modifications to the engine tin will I have to make, or anything else.
Thanks in advance
Geoff _________________ 1963 Ragtop |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Wed Feb 06, 2013 7:49 pm Post subject: |
For a 63? Nothing. Earlier ones might need breastplate mods. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Ojai63dbl Samba Member
Posted: Thu Feb 07, 2013 5:58 am Post subject: |
I have a dual port 1600 in my '63. It slips right in.
Only things I can think of:
1) I assume bug is 12V now, 12V coil, lights etc. based on the 66 flywheel.
2) Make sure the clutch pressure plate is correct for your tranny. The late bugs used a tranny with a metal collar that takes a different pressure plate. Its a simple swap of he pressure plate . If you use wrong one you cant engage clutch. This has happened to me when I forgot to look on a used engine swap to get a car rolling.
3) you mount the voltage regulator on side of engine - your regulator on 58 was on genie
4) Heater box hose connections (rubber bellows) might be different size for opening if you run with them |
ludsbug Samba Member
Joined: March 08, 2005 Posts: 234 Location: Gardnerville NV
Posted: Thu Feb 07, 2013 6:59 am Post subject: |
I own a '63 bug. The wife and I removed a 1600 dp '71 engine. Found no problems in removing engine, but when replacing the 1600 dp back, issues occurred. Only three of the four engine mount bolts had been in place before. I was bound and determined to get all four in. Took a while, and some bruised knuckles but all four bolts went in. The tin and the engine seal is a tight fit but it works. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Feb 07, 2013 7:21 am Post subject: |
You DO have the tin for the 1600, correct? 1200 is different....... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Thu Feb 07, 2013 1:24 pm Post subject: |
It fits but is tight as a duck's arse. I find it helpful to remove generator pulley and valve covers/bails on rhs, just so you can get it rearwards enough to slide forward. _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
GB2S Samba Member
Posted: Thu Feb 07, 2013 4:36 pm Post subject: |
Thanks everyone, I really do appreciate it.
SgtSamy Samba Member
Joined: July 10, 2010 Posts: 734 Location: Miami, Florida
Posted: Thu Feb 07, 2013 4:42 pm Post subject: |
Ive read that you need to trim the 1600 breast plate to put a 1600 DP in an old Beetle. Is this really needed or it just fit tight? _________________ At the moment owner of:
1968 Mex Beetle |
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
Posted: Thu Feb 07, 2013 5:32 pm Post subject: |
I put a 1600 in my '63 years ago. I believe it was out of a '73 it was an AE engine as I recall.
I had no trouble with it. I did have to grind my bell housing which was probably the hardest part, as I didn't want to take too much down, so I would grind a bit, try it, take it out, grind some more... did that about 4 times. And I switched to a semi-automatic starting motor (no bushing problems).
When you're putting it in, don't for get the throw-out bearing! I was tightening the last bolt on mine when I noticed it sitting on the bench...mocking me. |
