gitchesum Samba Member
Joined: November 10, 2003 Posts: 513 Location: North Cali
Posted: Sat Feb 09, 2013 9:57 am Post subject: Adjusting brakes with smoothies ? |
My 356 wheels, and my Mangles all have holes in them to reach the adjusters....my smoothies don't...it looks like I have to take my wheels off to adjust my brakes ??? _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 rag w/356B brakes
61 356B
Honda XLR 250, 69 Z50, Yamaha 100 Enduro...and others.
GMC SLT 4x4 Dmax
Kubota L3710, not enuf attachments.
And various VW's that come and go... |
Miklo ¡Chale!
Joined: August 27, 2008 Posts: 2058 Location: Antelope Valley, Ca
Posted: Sat Feb 09, 2013 10:05 am Post subject: |
Nope... you don't adjust them, ever...
You should still be able to access the hole with the cap off on Vw drums.
356 drums adjusting hole is more on the outer edge of the drum, looks like you will have to remove the smoothies. _________________ ✠Miklo✠
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote: |
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche... |
Posted: Sat Feb 09, 2013 7:19 pm Post subject: |
Would it compromise the strength of the VW wheel if I drilled a coupla holes it it....not like the cars pulls a coupla G's into a corner... _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
Mitey62 Samba Member
Joined: August 01, 2008 Posts: 537 Location: Everett, WA
Posted: Sat Feb 09, 2013 8:54 pm Post subject: |
Did you read the previous reply? Take the hubcap off. Ta-DAAAA |
Miklo ¡Chale!
Posted: Sat Feb 09, 2013 9:34 pm Post subject: |
Mitey62 wrote: |
Did you look at his "signature"? He has Porsche 356 drums...
gitchesum, why not take the wheels off instead if drilling holes in the smoothies? _________________ ✠Miklo✠
'55 Type1 "Ozma"
Posted: Sat Feb 09, 2013 9:38 pm Post subject: |
Aaahh, actually no, I typically ignore signatures. |
Posted: Sat Feb 09, 2013 9:43 pm Post subject: |
Yea...that,s what I'll have to do.....I'll look at the adj access hole in the drum and see if I can drill holes in the rims. The drag would be different w/o the wheel/tire in place so adjusting with those off might be a learning curve. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
gt1953 Samba Member
Posted: Sun Feb 10, 2013 7:44 am Post subject: |
I would not drill holes in a smoothy why ruin it. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
johnnypan Samba Member
Joined: October 24, 2007 Posts: 7431 Location: sackamenna
Posted: Sun Feb 10, 2013 9:01 am Post subject: |
Drill the wheel,then get them balanced...for the best balance allow them to add weight on either the outside or inside wheel flange..some dont like the look of the weight on the outside flange,but you get a much better balance. |
Posted: Sun Feb 10, 2013 9:44 am Post subject: |
Good idea...however my bug won't go fast enuf to notice if the wheels/tires are balanced.
As far as ruining a smoothie...it won't be seen under a hubcap, plus even most VW people likely would notice even if I left the hubcap off. _________________ Looking for SP Kadron manifolds...please !!
57 SC
61 356B
GMC SLT 4x4 Dmax
longboard511 Samba Member
Posted: Sun Feb 10, 2013 9:53 am Post subject: |
just take off the wheel to adjust it
tighten it up till the wheel is locked then back it off 3-4 notches |
Miklo ¡Chale!
Posted: Sun Feb 10, 2013 10:12 am Post subject: |
longboard511 wrote: |
just take off the wheel to adjust it. |
X2.
I'll trade you my Vw drums for your 356... you can keep your wheels on! _________________ ✠Miklo✠
'55 Type1 "Ozma"
doc1976 Samba Member
Posted: Sun Feb 10, 2013 10:35 am Post subject: |
drilling a hole in the wheels to adjust the brakes would be like cutting off the rear apron the remove the engine. Are you that lazy? how often are you adjusting brakes that you cant get the floor jack and the impact gun out and take the wheels off? good time to give the wheel wells a good cleaning too |
KTPhil Samba Member
Posted: Sun Feb 10, 2013 10:53 am Post subject: |
gitchesum wrote: |
Good idea...however my bug won't go fast enuf to notice if the wheels/tires are balanced. |
At 55mph you will feel the imbalance. |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Sun Feb 10, 2013 5:11 pm Post subject: |
KTPhil wrote: |
gitchesum wrote: |
At 25mph the tire will feel the difference!
If you must run smoothies, I think I would pull the drum off and mount the wheel to the drum. mark the wheel through the brake adjuster hole and drill 1 hole in the wheel. You don't need 5 holes, just 1.
This way you still get better feel for your brake adjustment by having the mass of the wheel/tire bolted in place.
And if you got your wheels spin balanced ON the car, they would always go back on in the correct lug location. But good luck finding a shop that knows how to spin balance on the car and has the machine to do that! _________________ Mother Nature is a Mean Evil Bitch! |
