carl4x4 Samba Member
Joined: March 20, 2012 Posts: 679 Location: United Kingdom
Posted: Sat Feb 09, 2013 11:14 am Post subject: Which clutch bearing needed? |
I bought a pre-70 200mm clutch kit, but I have a horrible feeling that I have bought the wrong one and that this is a 70+ clutch throw arm and gearbox. Can anyone confirm this for me please?
If it is 70+ is there anything else I need apart form the release bearing, am I missing any fixings or are they part of the release bearing?
Thanks. _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
63beryl Samba Member
Joined: November 24, 2006 Posts: 745 Location: SE Idaho
Posted: Sat Feb 09, 2013 11:42 am Post subject: |
The 70 and up transmissions have the sleeve around the input shaft like yours, so you need the newer style throw out bearing. The bearing will come with new retaining clips, so you shouldn't need anything else to install the new bearing. |
Posted: Sat Feb 09, 2013 12:00 pm Post subject: |
kombiboy wrote: |
Thanks, I thought as much there goes any chances of me installing the engine tomorrow _________________ 1969 UK Karmann Ghia build http://www.thesamba.com/vw/forum/viewtopic.php?t=518789&highlight= |
Ian Godfrey Samba Member
Joined: September 25, 2006 Posts: 1137 Location: Melbourne Australia
Posted: Sat Feb 09, 2013 2:11 pm Post subject: |
Also remember your pressure plate should be the late type with out the ring. If you have an early pressure plate you can usually remove the ring so the fingers or diaphram run directly on the throwout bearing |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Sat Feb 09, 2013 2:58 pm Post subject: Which clutch bearing needed? |
71> clutch kit needed, 67-70 is the early collar style TO bearing and preasure plate _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Tue Jun 22, 2021 9:53 am Post subject: Re: Which clutch bearing needed? |
I need help deciding what type of throw out bearing to purchase, very confused looking at all the variations. I have a KCR built IRS transmission. The guy working on my engine is balancing the pressure plate and asked me to send him a pic of the throw out bearing cross shaft. When he got the pic, he said I had an 'early' one meaning pre 71? Not sure why that is since my Ghia is a 71, but perhaps when you get a custom transmission built they just send whatever, unless you specifically state what you want. See pics.
And here is my pressure plate
I was told based on the cross shaft that the collar stays on. That's fine, but given the cross shaft, can someone please let me know what type of bearing to purchase, and what if any clips I need as well? Hopefully the experts can tell by the pics what to recommend.
Thanks for your help
Jeff _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
c21darrel Samba Member
crocteau Samba Member
Joined: March 31, 2005 Posts: 1204 Location: Philaburbia
Posted: Tue Jun 22, 2021 10:53 am Post subject: Re: Which clutch bearing needed? |
rbsurfguy wrote: |
...can someone please let me know what type of bearing to purchase, and what if any clips I need as well? |
Like Darrel said, for example: https://www.jbugs.com/product/32-1205.html?rrec=true |
Posted: Tue Jun 22, 2021 3:30 pm Post subject: Re: Which clutch bearing needed? |
Thanks guys, that's the one I was looking at and wanted to confirm. Check on the safety wire.
I was also told the cross shaft was not a heavy duty style, do you recommend I change that as well since I'll be running a 2332cc. Does it make a difference?
Is that something that's fairly easy to do? I am a bit mechanical and have lot's of cool tools, unless I need something specific to remove, like an 8lb BFH!
2012 Passat-Sold
Posted: Tue Jun 22, 2021 6:17 pm Post subject: Re: Which clutch bearing needed? |
Makes sense, thanks Darrel, appreciate it!
2012 Passat-Sold
Posted: Tue Jun 22, 2021 7:28 pm Post subject: Re: Which clutch bearing needed? |
I'd also replace that seal that is behind the throwout bearing, it is very easy to get to now, and really annoying to have to take the engine out later if it leaks.
......... bitter experience |
Posted: Wed Jun 23, 2021 3:20 am Post subject: Re: Which clutch bearing needed? |
Despite how it looks, the transmission has never been used since being built 5-6 years ago, it's just been sitting mounted all the years I was deployed, so not sure why I would have to change the seal. It was also filled with fluid about 2 years ago.
2012 Passat-Sold
simon varley Samba Member
Joined: March 12, 2020 Posts: 175 Location: Geelong Australia
Posted: Wed Jun 23, 2021 4:05 am Post subject: Re: Which clutch bearing needed? |
because if it has been sitting for 5 years dry, it may have hardened. For a couple of bucks you might as well. |
Posted: Wed Jun 23, 2021 9:06 am Post subject: Re: Which clutch bearing needed? |
Bentley says to coat the outer edge with compound sealant. Any specific type I should use or anyone can recommend? Or is that what they use to call gasket sealer?
2012 Passat-Sold
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jun 23, 2021 11:03 am Post subject: Re: Which clutch bearing needed? |
rbsurfguy wrote: |
Jeff |
Factory says to use sealant for that and the flywheel seal. My dad never did, and we have not done so for over 3 decades and almost 400,000 miles. Just make sure the bore is clean of corrosion or scratches, and no sharp edges. Use oil to lube up the seal inside and outside just before installing.
Have used 300-400 grit wet dry sandpaper to polish any suspect bore to get it to seal up. _________________ In Stereo, Where Available! |
Posted: Wed Jun 23, 2021 11:20 am Post subject: Re: Which clutch bearing needed? |
Thank you Sir. I don't remember my dad ever using sealant for that spot when he was building VW engines. If you look at my pics above, it looks like KCR did use something, so if the seal fits as tightly as it looks, I figured a little oil would suffice to slide into place.
Since I don't plan to purchase a tool just to extract the seal, even though I dig buying tools, I will be careful when removing and check the surface to ensure no scratches or scarring.
All this info has been very helpful, thanks.
2012 Passat-Sold
Posted: Wed Jun 23, 2021 12:40 pm Post subject: Re: Which clutch bearing needed? |
This way is primitive, but effective:
https://www.thesamba.com/vw/forum/viewtopic.php?p=4713338&highlight=#4713338
As mentioned in that thread there is a blueprint for the proper tool that should be in the "Local Manufacture of Tools" accessible thru the "Technical" button of this TS website. Seek the "VW Tools" column there. Tis a fascinating collection to go thru often. All the blueprints were available to VW dealers so as to allow them to make many of the air cooled VW specific tools they needed. _________________ In Stereo, Where Available! |
Posted: Wed Jun 23, 2021 2:29 pm Post subject: Re: Which clutch bearing needed? |
I like the double screw method...immediate action to solve a problem!
Have seen the tool section but thanks for the reminder. I always read those in Hot VW's every month.
2012 Passat-Sold
