randywebb Samba Member
Posted: Thu Feb 14, 2013 4:51 pm Post subject: Fuel Pump Electric Terminals |
Is there any way to tell which terminal s supposed to be ground and which gets + 12V?
thx _________________ 1986 2.1L Westy 2wd Auto Trans. |
insyncro Banned
Posted: Thu Feb 14, 2013 4:58 pm Post subject: |
Most fuel pumps have it marked on them. |
Posted: Thu Feb 14, 2013 5:04 pm Post subject: |
Sometimes only one pole is marked, so if you don't see a + or - designation on one pole, look at the other. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
insyncro Banned
Posted: Thu Feb 14, 2013 5:08 pm Post subject: |
I have seen different sized posts as well....IIRC, larger +, smaller -. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Thu Feb 14, 2013 6:17 pm Post subject: |
insyncro wrote: |
Might just be a red + painted on as I recall. |
Posted: Fri Feb 15, 2013 2:01 pm Post subject: |
Here is my problem - I think the old pump is bad and removed it for bench testing.
But I want to hook it up correctly for testing. I don't see any polarity markings anywhere. There is an "R" which you can see in the photo, BUT BOTH terminals have that "R" on them.
Any ideas?
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Fri Feb 15, 2013 2:11 pm Post subject: |
Clean the build up from the end of the pump and Look for the polarity marking molded into the plastic. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
insyncro Banned
Posted: Fri Feb 15, 2013 2:15 pm Post subject: |
Syncro Pilot wrote: |
Clean the build up from the end of the pump and Look for the polarity marking molded into the plastic. |
X2 |
insyncro Banned
Posted: Fri Feb 15, 2013 2:26 pm Post subject: |
Bosch pump:
Posted: Fri Feb 15, 2013 3:12 pm Post subject: |
thx - will have a go at that _________________ 1986 2.1L Westy 2wd Auto Trans. |
