Hella fluted lenses date codes
Fetz
Fetz is offline
PostPosted: Thu Feb 14, 2013 5:31 pm    Post subject: Hella fluted lenses date codes Reply with quote
Trying to date code a set of hella fluted headlight lenses.
This is how the lenses are stamped:
10801 HELLA L. 441. 561
Any insights appreciated.
Miklo
¡Chale!
Miklo is offline
PostPosted: Fri Feb 15, 2013 11:34 am    Post subject: Reply with quote
This may help...
Bosch Hella SWF SHO Blaupunkt date codes
Miklo
'55 Type1 "Ozma"
'66 Type1 "Charlotte" RIP
Antelope Valley's Mobile Air-Cooled Guru
Dr OnHolliday wrote:
As I remember it, lowriding was not one of the criteria that Adolf gave to Dr. Porsche...
janerick3
janerick3 is offline
PostPosted: Sat Feb 16, 2013 8:04 pm    Post subject: Reply with quote
Hella lenses are not date-coded.
Is the "10801" and "HELLA" cast into the lip or the face of the lens?
If these are cast into the lip at the top, are there any numbers cast into the lip at the bottom?
Where is the "L 441.561" located?
Pictures will help immensely.
Thanks,
Jan K.
Fetz
Fetz is offline
PostPosted: Mon Feb 18, 2013 3:25 pm    Post subject: Reply with quote
All of these numbers appear to be stamped on the top of the inside lip.
There is also a small triangle and the number 36 stamped on the bottom inside lip.
These lenses have the vw logo cast on top of the outside and Hella cast on the bottom. There are also the letters A and NL inside a circle cast on each side of the hella logo.
janerick3
PostPosted: Wed Feb 20, 2013 9:24 am    Post subject: Reply with quote
These lenses most likely date from 1955-58, as the "A" and "NL" markings started about 1955 and the part number moved from the lip to the face of the lens around 1958-59.
Thanks,
Jan K.
