beetlenut Samba Member
Posted: Sun Apr 07, 2013 4:03 pm Post subject: |
danno627 wrote: |
Why did you choose to repair the heater channel instead of replacing it? How did you treat the rust inside? Also, are you painting the car green again? |
The actual heater channel itself was in good shape, so I reused it once I cleaned it up and repainted it. For me the rocker metal that surrounds the channel was shot, specially the bottom piece with the captive nuts that the body bolts go into. I actually bought all separate pieces and replaced them while the body was still on the car. I also used the Eastwood rust encapsulator kit to do the tunnel and heater channel areas. I'm going to try and color match the green that's on the car now for all the new sections of new metal on the car. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
dubjeep Samba Member
Joined: December 24, 2011 Posts: 354 Location: Rhode Island
Posted: Sun Apr 07, 2013 5:08 pm Post subject: |
I am not sure if I want to go the route that you did for my heater channels. The right side is pretty bad in the rocker area, but the drivers side looks perfect, except for the front wheel well portion. _________________ "Harvey"--My 1970--http://www.thesamba.com/vw/forum/viewtopic.php?t=495804 |
Posted: Sun Apr 07, 2013 7:26 pm Post subject: |
You could do a full one on one side, and just a front section for the other. One thing I found out about the front sections was that they did not come with the bottom piece that has the captive nuts for the front body bolts. I had to make those myself and weld them to the top section. Since I still had the body on the pan at that point, it allowed me to line everything up nicely. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Sat May 18, 2013 7:36 pm Post subject: |
Ok, so I managed to color-match the paint on the car. Turns out it's a base coat clear coat urethane, so that should make blending any areas a little easier.
I'm dry fitting up the front end and getting the 73 bumper brackets to fit up with the ugly 74 triangular holes. I'm also going to move the bumper about an inch closer in to the body. So today I modified the brackets and started work test fitting one of the brackets. I also have the 73 bumper hole seals.
Front of car with one of the new brackets. I should mention that I already welded in the 73 bumper repair sections on both sides that take the 73 solid mounts.
Cardboard template of the patch I need to weld in to close up that hole and mate up with the new 73 bumper seal
Test fitted fabricated patch
Patch welded in
Backside of patch with the mounting bracket and seal
Wetstuff wrote: |
aaronr25 Samba Member
Joined: September 06, 2009 Posts: 267 Location: NW Arkansas
Posted: Sun May 19, 2013 5:41 pm Post subject: |
Wow most people would have hauled it off for scrap. Nice work saving your ride. _________________ 65 Bug
66 Landcruiser FJ40
Life's too short to drive a stock VW |
Posted: Sun May 19, 2013 7:42 pm Post subject: |
aaronr25 wrote: |
Wow most people would have hauled it off for scrap. Nice work saving your ride. |
Well, I would too if I were to do it over again. Something to be said about "ignorance is bliss" when it comes to car projects and kids!! I finished the other bumper bracket hole today. The reassembly to test fit everything before paint is kind of a nice place to be after all the years of welding and fabrication.
Wetstuff wrote: |
Murdock00 Samba Member
Joined: April 16, 2013 Posts: 72 Location: Georgia, USA
Posted: Sun May 19, 2013 10:35 pm Post subject: |
Wow a lot of work, but keep it up! |
Posted: Mon May 20, 2013 4:57 am Post subject: |
danno627 wrote: |
What kind of welder are you using? |
It's a small Lincoln WeldPak 110 with the shielding gas set-up and .023 wire. Does everything from 22 gauge to 1/4 inch. Its been a bullet proof machine for the last 10 years. _________________ scrapyards are for quitters
Wetstuff wrote: |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Mon May 20, 2013 5:16 am Post subject: |
Nice work on the bumper slots.
It will probably make you cringe but I just did the opposite, turned a 71 fender into a late one for my 74
Posted: Mon May 20, 2013 8:06 am Post subject: |
Joel wrote: |
Thanks. Not cringe, but you probably had the easier job of it! _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Mon Jul 15, 2013 8:29 am Post subject: |
Getting ready for paint. Building a paint booth around the body with clear plastic, a box fan, and airconditioning filters. And I'm sanding, and sanding, and sanding...
Wetstuff wrote: |
Posted: Tue Jul 16, 2013 4:34 am Post subject: |
danno627 wrote: |
Very cool. I still need to get out there and see this thing in person. |
Ha! Better hurry, I might just have it done in a year or two! The government sequester is giving me an extra day a week to work on it, so hope to at least get it painted this Summer. _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Sat Jul 20, 2013 8:09 pm Post subject: |
The wife and I are house shopping so we haven't had a whole lot of time. Plus I keep fixing other people's junk. Soon I hope. I'm stockpiling tools for now. _________________ "Harvey"--My 1970--http://www.thesamba.com/vw/forum/viewtopic.php?t=495804 |
Posted: Mon Sep 02, 2013 5:07 pm Post subject: |
Teaser alert.
Got some color matched paint on the bug. Had some issues with the clear coat, so had to sand it down with 400 then 800. Waiting for a low humidity day to reshoot. Then the body goes back on the pan!
Wetstuff wrote: |
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Mon Sep 02, 2013 7:21 pm Post subject: 74 Super Rusterection |
Wow, What can one say, but very nice work going on in your Garage. Your on the home stretch now. Keep em coming. |
Posted: Fri Sep 06, 2013 6:33 pm Post subject: |
danno627 wrote: |
Paint match looks good in the pictures. |
In the new house yet?? _________________ scrapyards are for quitters
Wetstuff wrote: |
Posted: Sun Sep 08, 2013 4:11 am Post subject: |
beetlenut wrote: |
danno627 wrote: |
In the new house yet?? |
Closing date is September 27th. We had to renegotiate with the sellers after the appraisal came in 10K low. Hopefully done jumping through hoops and just waiting now. When I get the house you can come by and see the bug, but it's not moving until a couple of weeks after we get settled in. _________________ "Harvey"--My 1970--http://www.thesamba.com/vw/forum/viewtopic.php?t=495804 |
