Pacmanfever Samba Member
Posted: Wed Apr 18, 2018 7:45 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
The video is like a master class on patience & persistence.
Absolutely love it. |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Thu Apr 19, 2018 11:12 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
I had been thinking about how I was going to shape the curves for years. My first few attempts made a mess out of things. Hand sanding was the worst. It is a relief to finally see how I ended up doing it. A cut off furniture leg with a chamfer and sandpaper glued on. After the sandpaper is on I sand off the bottom smooth so it becomes a "safe" non sanding surface. Give a few spins in each corner. That marks the end of any more shaping work.
This is the coat of epoxy that defines the barrier between shaping work and smoothing work. From this point forward I should not attempt to change shape but only to smooth out the surface with fine sandpaper and fine primers. The wet reflection shows I am almost there. Next will be two coats of High build urethane then the sanding starts all over again. This is how I think about it. Welding, hammer and grinding. Coarse fillers with coarse sandpaper. Fine fillers with fine sandpaper. I had planned on hanging all three gates from the ceiling one above the other but overspray would be falling on the bottom one. I have limited space so decided last minute to lay them flat. Now to flip them over without touching any part that shows. Notice the blocks of wood holding the hinges onto a 2x4 with drywall screws. I can do one side then flip them over before dust or bugs get on them. I am painting in the same area as the sand blasting and sanding happened. It will never be clean enough. You will see the flipping when I add that to the video.
Drilled and tapped steel bars for handles and a 2x4 leg support. Flipping gates.
Rear gate was done with a bolt in the latch nut.
Here are two coats of high build urethane. I am out of time.
There are 0 days left before the weekend of shows begins. With heat lamps keeping the garage at 75 degrees the primer will be dry enough to put on the truck in the morning and go anyway. I won't be the first VW at a show in primer. You can assess my work at Red Barn alternate location tomorrow night. This has been a major push and stuff got done. My hands are sore and I have no fingerprints.
Kurt _________________ "The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639 |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Fri Apr 20, 2018 1:32 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
Hats off to you, those gates look great! (And the rest of the truck too...) |
zehbeh Samba Member
Joined: February 16, 2008 Posts: 249 Location: Stuttgart
Posted: Fri Apr 20, 2018 1:59 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
I am absolutely fascinated by the attention you are giving to all these small details.
Looking forward, seeing the red gates on Funky. |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Clara Samba Member
Posted: Fri Apr 20, 2018 6:56 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
glideking wrote: |
In the age of instant publishing I present "The Gate Flipper". |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Fri Apr 20, 2018 8:01 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
nlorntson wrote: |
The worst part of getting Schultz's gates ready for paint was the sanding. Once the metal portion is repaired, plan for a boatload of time just sanding around those pressings by hand.
Have fun! |
You are doing a stellar job on a very time consuming part of the project. It's these details on DC and SC that make professional restorations so expensive if they are done right.
And boy are you doing things right!
Have a great time at KP and RB. We'll miss seeing you! |
wcfvw69 Samba Purist
Posted: Fri Apr 20, 2018 12:41 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
zehbeh wrote: |
Kurt is just showing off! This has been my favorite thread of all time on The Samba. No one has been in Kurt's league for attention to detail or
excellent photo/video documentation.
He should of been an engineer. _________________ Contact me at [email protected]
The Samba member since 2004.
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Fri Apr 20, 2018 1:33 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
wcfvw69 wrote:
excellent photo/video documentation. |
Excellent work, I agree. But as to no one does it better, has not watched the KCW site. They have been cranking out superb quality restorations since 2001. From custom to stock, no one does it better! _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Fri Apr 20, 2018 3:35 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
Well done sir!!!!!!!!!!!!!!!! _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Mon Apr 23, 2018 6:49 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
He arrived on TheSamba, said what he was going to do, did what he said he was going to do, left more knowledge for others than a Nobel Prize, turned straw into gold, yaaawwwwn ...who ever remembers second place...yeah, hang your head.
Btw, how's the fingers? |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Mon Apr 23, 2018 10:06 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
Red or gray, doesn't matter...those are some seriously straight gates! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Apr 24, 2018 7:49 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
Z wrote: |
you don't know that, could be diverse gates _________________ regards
Uli
KombiMadness Samba Member
Joined: December 09, 2011 Posts: 388 Location: Sunshine Coast, Australia
Posted: Tue Apr 24, 2018 4:30 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
plane_ben wrote: |
Excellent work, I agree. But as to no one does it better, has not watched the KCW site. They have been cranking out superb quality restorations since 2001. From custom to stock, no one does it better! |
Totally agree. My '59 VW truck was a KCW ground up, bare metal resto and they did superb work. It was done pretty much stock and original (except for a later 1600 engine and big nut tranny). _________________ My brother & I on the roof of Dad's Splitty circa 1967 - I'm the half pint with the skinny legs! |
Posted: Tue Apr 24, 2018 7:18 pm Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
KombiMadness wrote: |
plane_ben wrote: |
Totally agree. My '59 VW truck was a KCW ground up, bare metal resto and they did superb work. It was done pretty much stock and original (except for a later 1600 engine and big nut tranny). |
We're not comparing apples to apples guys. I'm saying that Kurt (who is not a professional VW restorer) has done an amazing job out of his home shop. He's not a professional body man nor an automobile painter. _________________ Contact me at [email protected]
Posted: Wed Apr 25, 2018 4:32 am Post subject: Re: 1959 Single Cab Restoration Thread "Funky Truck" |
Bill
I probably should have been more clear in my comment. I was not really comparing the work quality, but the documentation aspect. KCW does excellent documentation on all their builds. To bad the old site crashed and they lost all the build threads. New site was able to recover the old gallery though.
Kurt's work is the best I've seen. His approach to every aspect of his restoration is thought out, and works. Like his little table leg sanding tool. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Posted: Mon May 21, 2018 11:22 pm Post subject: Vintage Speed muffler installed |
Funky was getting louder every day but I must have gotten used to it until it got really loud the other day. The novelty of having a 100% original Gene Berg kit engine has worn off. The GBE header lasted only two years and has fallen off so I replaced it with Vintage Speed stainless steel. I ground the stainless flanges a bit to get it to clear both the bumper and apron without modification to stock VW parts. I used CSP smaller stainless heat tubes to the boxes as the larger GBE tubes did not clear the VS. The sound is a much deeper growl at idle. I will check the sound driving at speed on my way to work tomorrow.
