sobelsaint Samba Member
Posted: Tue Feb 19, 2013 2:29 am Post subject: Steering Shaft Missing Copper Sleeve |
I found a steering shaft with the copper ring missing for the horn contact button. What are the options for replacing it? |
Rustforlife Samba Member
Joined: August 24, 2007 Posts: 588 Location: Texas-y'all
Posted: Tue Feb 19, 2013 4:00 am Post subject: |
As far as I know, there is no way to replace the contact sleeve. You will most likely have to source a correct steering shaft. _________________ 1956 Ragtop |
Posted: Tue Feb 19, 2013 9:00 am Post subject: |
Bummer. How does the wire connect to the brass ring? |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Tue Feb 19, 2013 4:21 pm Post subject: |
sobelsaint wrote: |
The wire is crimped between the Brass collar & the steering tube. There's also some cardboard to isolate it from grounding
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Posted: Tue Feb 19, 2013 5:48 pm Post subject: |
It seems like it would be an easy part to sell. Maybe I can find something at the hardware store. |
splitjunkie Samba Member
Posted: Tue Feb 19, 2013 7:11 pm Post subject: |
the copper sleeve is just a smidge over 1" . Pick up a piece of 1" copper pluming pipe and you should be in good shape. _________________ Chris
Posted: Tue Feb 19, 2013 7:49 pm Post subject: |
Thank you guys for all the help. |
sparkleplenty Samba Member
Joined: January 09, 2008 Posts: 1110 Location: California
Posted: Wed Feb 20, 2013 7:53 pm Post subject: |
I might have one of these laying around...I'll let you know.
Russ _________________ '56 European Oval Ragtop-Stock
'56 Karmann Ghia Coupe-Stock
'59 Italian Series I Li150 Lambretta-Stock
"Give a man a fish, feed him for a day. Teach a man to fish, feed him for a lifetime."
"Only when the tide goes out do you discover who is swimming naked." |
Posted: Wed Feb 20, 2013 8:05 pm Post subject: |
That would be great. Please do. |
Posted: Wed Feb 20, 2013 8:06 pm Post subject: |
I just checked...No go...I have one but it must be off a different model...sorry
It's shorter than the oval style..it's looks like it might be type II... _________________ '56 European Oval Ragtop-Stock
nick696 Samba Member
Posted: Thu Feb 21, 2013 2:46 pm Post subject: |
Just source a new copper ring and press it on.
While you are at it, place a new wire.
I did it on mine and it worked out great |
Posted: Thu Feb 21, 2013 10:11 pm Post subject: |
Where did you source a new copper ring? |
JiI Samba Member
Joined: February 18, 2006 Posts: 1844 Location: Michigan
Posted: Sun Sep 24, 2017 9:40 am Post subject: Re: Steering Shaft Missing Copper Sleeve |
A bronze bushing can work too. I just need to find a replacement for the contact holder on the column!
Jeff |
schwartzkafer Samba Member
Posted: Tue Oct 03, 2017 9:05 pm Post subject: Re: Steering Shaft Missing Copper Sleeve |
Maybe a PEX copper ring. You can probably rent the pex tool that compresses the copper ring (good tool is kind of expensive). It may even work on a standard copper sleeve from a piece of rigid copper pipe. Worth a shot. The pex rings are very cheap, and can be gotten from any hardware store. |
mynameismud Samba Member
Joined: October 23, 2002 Posts: 5922 Location: Middle of a corn field
Posted: Sun Feb 27, 2022 3:21 pm Post subject: Re: Steering Shaft Missing Copper Sleeve |
I'm in the same boat and trying to figure out what happened and how I can remedy the situation. The shaft is 24 spine and has the raised shaft behind the splines but, the copper sleeve and paper is missing as well?
Has anyone had success in retrofitting a copper band as discussed earlier?
My column cover does have the contact brush holder, (which I find odd it remained with all the other strange things done). and I do have a new contact brush.
I'm guessing this is why the PO had a horn button mounted to the dash.. _________________ Even YOU can prevent FIRES!
Click to view image |
