cmaydawg Samba Member
Posted: Tue Feb 19, 2013 3:09 pm Post subject: VW 94mm pistons and barrels into a 2.0 liter 914 case |
Seems like they should slide right in but not sure. I'm aware of the piston differences between flat-top pistonsand dished pistons like whats in there. More concerned about the 2.0 liter rod length. Finally if the dished 2.0 pistons check out tolerance wise any problem with those pistons/rings and running the vw 94mm barrel/cylinder with the dished 2.0 l pistons ? Thanks in advance. |
germansupplyscott Samba Member
Posted: Thu Feb 21, 2013 1:57 am Post subject: |
it's a bit difficult to figure out exactly what you're asking...
if the VW pistons are made for a 2.0l Bus/Vanagon aircooled engine they will fit the 914. if they are 94mm bore pistons/cylinders for a type 1 engine they will not work. _________________ SL |
Posted: Thu Feb 21, 2013 1:02 pm Post subject: |
Thanks Scott, you answered it. 94mm barrels for Vanagon/Bus. What do think of running the dished pistons that are in block (if they check out) with the VW 94mm barrels, or is it better to go with a matched set of pistons and barrels |
Bleyseng Samba Member
Posted: Fri Feb 22, 2013 4:45 am Post subject: |
you can buy a set of bus 94mm pistons and cylinders with a dish from AA for $300 _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sat Feb 23, 2013 7:04 am Post subject: |
there should be no issue with mixing bus cylinders and 914 pistons. the bore is the same and if the cylinders you want to use are german and in spec and condition then it could be better to use them than reproduction parts. it all depends on the condition and measurements. but the cylinders are the same as far as factory specs go. _________________ SL |
