shiningstar76 Samba Brewer
Posted: Thu Feb 21, 2013 7:36 pm Post subject: No crank condition *Solved* |
I just picked up a 71 bus. It would not crank. Just one loud click. I have tried two known good batteries. I pulled the new starter out of my 72 and put that in. Same condition. I noticed that it has what I assume is a Ford starter relay mounted near the starter. I disconnected that unit, putting a female connector on the red/black wire and remounting that to the solenoid. I momentarily enjoyed some cranking bliss and sputter over. But that was short lived. It has now gone back to a no crank condition. The oil and gen lights come on bright and show strain and dim in the crank position, but no crank. I hooked it up to the brat and tried to jump it, but only got some limited, short lived slow crank. Other than that, nothing but dimming dash lights. Any ideas? You know I love you guys and appreciate the help. Cheers _________________ KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it.
Last edited by shiningstar76 on Thu Feb 21, 2013 8:12 pm; edited 1 time in total |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Thu Feb 21, 2013 7:47 pm Post subject: |
Ignition switch bad? _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Thu Feb 21, 2013 7:54 pm Post subject: |
Red Fau Veh wrote: |
Ignition switch bad? |
Maybe. I figured I wouldn't see any drain on the dash lights if that were the case. Am I incorrect? _________________ KK4NTP
96 Tacoma
86 4Runner
My bus caught on fire and is now on the other coast with someone who gave me money for it. |
Posted: Thu Feb 21, 2013 8:14 pm Post subject: |
I pulled out the Bently which lead me to clean all the battery terminals and when I was cleaning the positive terminal the big gauge wire popped right out. I cleaned it all and tightened it up and it fired right up. Thanks for the help. _________________ KK4NTP
96 Tacoma
86 4Runner
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Mon Apr 08, 2013 8:37 am Post subject: |
That's a great example of how we think. Something fails but instead of going to the cheapest, easiest part of the system to troubleshoot first, we go to the hardest, most expensive thing first. I've had to learn that lesson more than once. Battery connections should be your first thing to look at. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
BKellogg Samba Member
Joined: November 21, 2011 Posts: 7 Location: Terrebonne, OR
Posted: Mon Feb 17, 2014 2:47 pm Post subject: 71 bay window starter problems |
I have a 71 westy that was doing great, Last week I went out to start it and all I got was a whirring sound when I turned the key on. Like there's power to the starter but won't kick over. I tried the tapping on it with the hammer trick, but nothing. I'm thinking that it's the solenoid, but thought I'd ask for a little advice before replacing it. No other dubs guys local here... ( |
SGKent Samba Member
Posted: Mon Feb 17, 2014 3:44 pm Post subject: |
Quote: |
and all I got was a whirring sound when I turned the key on. |
Is it a clicking or whirring? If whirring, pull the starter out and look at the teeth. Are they chewed up? Use a flashlight to look at the flywheel - any teeth missing. If no to both then look at the bolt that the starter fork pivots on. It could be worn down very thin and the fork is not pushing the teeth all the way out. Basically if the solenoid can pull in enough to cause the starter to run, it should be pushing the teeth into the flywheel. Either it is not doing that or the flywheel is missing teeth - or maybe the starter is loose. That is if it is a whirring sound. If it is a clicking sound over and over then it could be a weak battery or bad cables like this thread. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Feb 17, 2014 5:10 pm Post subject: |
If the flywheel does have bad/missing teeth you can try putting the bus in second gear, let the brake off, and give it a shove. This should rotate the flywheel around to where the good teeth are. It's not a fix but just a quick way to get yourself running again. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Mon Feb 17, 2014 6:11 pm Post subject: |
aeromech wrote: |
If the flywheel does have bad/missing teeth you can try putting the bus in second gear, let the brake off, and give it a shove. This should rotate the flywheel around to where the good teeth are. It's not a fix but just a quick way to get yourself running again. |
With the key in the off position.
Aloha
tp |
Desertbusman Samba Member
Posted: Mon Feb 17, 2014 6:14 pm Post subject: |
Tom Powell wrote: |
Party pooper _________________ 71 Superbug
71 Westy |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Tue Feb 18, 2014 7:33 am Post subject: |
We use to say in the MotoX world "It's all fun & Games until someone gets hurt"
"Then it's Hilarious" _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
