busdaddy Samba Member
Joined: February 12, 2004 Posts: 51156 Location: Surrey B.C. Canada, but thinking of Ukraine
crushie Samba Member
Joined: September 23, 2011 Posts: 878 Location: alberta
Posted: Tue May 31, 2016 3:45 pm Post subject: Re: 1974 and 1975 westy info thread |
When I ran the bus exhaust noise only came out of the three holes.
The fourth hole (screwdriver shows location) is a smaller thread and only goes in about an inch or so.
The other holes are about 4 inches long. Maybe the temperature port they speak of?
_________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
Posted: Tue May 31, 2016 3:50 pm Post subject: Re: 1974 and 1975 westy info thread |
Well if it ain't leak'n don't worry..................................for now, if you don't find it will it find you roadside in the middle of nowhere?, unless maybe it's already been plugged with a valve adjuster screw? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue May 31, 2016 3:58 pm Post subject: Re: 1974 and 1975 westy info thread |
busdaddy wrote: |
Well if it ain't leak'n don't worry..................................for now, if you don't find it will it find you roadside in the middle of nowhere?, unless maybe it's already been plugged with a valve adjuster screw? |
Weird thing is when I drive a screwdriver in there it only goes an inch or so and it hits hard, like cast metal, not carbon build up. The other three holes, I loose my screwdriver. Can't use that for a cht could I? _________________ 1974 VW Combi 1800 Auto. Weber 32/36 |
cheftaylor74 Samba Member
Joined: November 18, 2007 Posts: 45 Location: Encinitas, Ca
Posted: Fri Jun 10, 2016 5:07 pm Post subject: Re: 1974 and 1975 westy info thread |
Hi there. I need to buy a new table for my 74 deluxe westy. Can someone take a photo of how the hinges attach to the wall? I feel like I'm missing a bracket or something. A photo of the underneath of the table when opened would be appreciated!
Thanks! |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Jun 10, 2016 7:27 pm Post subject: Re: 1974 and 1975 westy info thread |
The hinges dont attach to the wall - they attach to a small 1x2strip of wood that attaches to the wall. Not the best pic.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Xevin Samba Member
Posted: Fri Jun 10, 2016 7:57 pm Post subject: Re: 1974 and 1975 westy info thread |
From my 72 same idea I believe.
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Jun 10, 2016 7:59 pm Post subject: Re: 1974 and 1975 westy info thread |
Dude. You dont know these people. Why you showing off your pole like that? _________________
t3kg wrote: |
1964 1500 S
Xevin Samba Member
Posted: Fri Jun 10, 2016 8:03 pm Post subject: Re: 1974 and 1975 westy info thread |
notchboy wrote: |
Dude. You dont know these people. Why you showing off your pole like that? |
I know. It's all old and crusty. You did a nice job polishing your pole _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Fri Jun 10, 2016 8:10 pm Post subject: Re: 1974 and 1975 westy info thread |
Xevin wrote: |
notchboy wrote: |
I know. It's all old and crusty. You did a nice job polishing your pole |
I found that in the gallery - that's some other dudes pole.
My pole is sacred - like a totem. People come from miles around to admire it.
t3kg wrote: |
1964 1500 S
Posted: Sat Jun 11, 2016 11:17 am Post subject: Re: 1974 and 1975 westy info thread |
Lol. Some of you need to get out more...
Thanks for the pics Xevan and Notchboy! What are the dimensions of the wood strip that the table secures to? I think I may have tossed it when I was cleaning out all the crap accumulated from the PO. |
Posted: Sat Jun 11, 2016 1:03 pm Post subject: Re: 1974 and 1975 westy info thread |
Ill go measure mine from the 74. Of the 6 screws that hold the hinge to this stick - two are longer and match a 7th thats seen in the middle - these go through the panel and hold the table to the wall of the bus.
t3kg wrote: |
1964 1500 S
Posted: Sun Jun 19, 2016 3:40 pm Post subject: Re: 1974 and 1975 westy info thread |
When I got the 74 Im currently restoring - the curtains had been replaced with ones so burnt by the sun that Im sure the OG ones met the same fate in the hot Texas Sun.
But I did have the front windshield curtain albeit in ok shape but on its way too to rotts ville. I did notice at the time that the 74 curtain was less dense than the later 78 dark green ones I had.
Here are some close up pics of these unobtainium drapes and the description of weave and density.
Firstly the 74-75 ones - the green next to the orange one - feel thin and organic like cotton. The thread is not thick thus making the weave thin - if that makes sense. You can put a light behind it and see light for sure. I would surmise the thin weave and the organic thread make it prone to rotting in the sun - fast. Maybe one of the reasons you never see them for sale ever.
This second green on the bottom appears and was sold as a 74-75 curtain. But its made of silky synthetic like polyester or a blend thereof. Same weave - same construction - different material.
Obvious when held next to later, long lasting, heavier weaved 76-79 curtains.
Its my best guess from the pieces I have in front of me that VW had OG 74-75 cotton curtains that failed fast. Then they were replaced by synthetic blend - I can confirm this with a burn test - to aid in longer life - less fade?
Id love to see if others have OG curtains in their rides and what type - conditions they are in.
t3kg wrote: |
1964 1500 S
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Wed Jun 22, 2016 7:01 pm Post subject: Re: 1974 and 1975 westy info thread |
For what it’s worth, and probably already known, the orange plaid Westfalia on the first page is a 75, due to there being a jump seat. 74 just had the stool and middle cubby with the infamous yellow pail.
I also had the complete set (including windshield) curtains when I bought my bus. Orange like everything else, the outsides of the curtains were so sun faded, they are literally pink. So as much as I want to rock OG curtains, I can’t, one side orange, the other pink.
Sam _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Wed Jun 22, 2016 7:48 pm Post subject: Re: 1974 and 1975 westy info thread |
SamboSamba22 wrote: |
Sam |
Most all curtains from the 75-79 range have the sunburn on one side. People find the front curtains and make rears out of them.
Having og pink curtains is a step above most as these 74-75 ones seem to vanish more so than the later ones. _________________
t3kg wrote: |
1964 1500 S
Posted: Wed Jun 22, 2016 7:59 pm Post subject: Re: 1974 and 1975 westy info thread |
I love the orange. But I agree that a splash of something else like green would be good. Im not sure how long I could live with orange on orange on orange on orange............. _________________
t3kg wrote: |
1964 1500 S
Posted: Wed Jun 22, 2016 8:18 pm Post subject: Re: 1974 and 1975 westy info thread |
On orange, on orange, on orange...orange
Really though, I dig it too. I never knew I liked the color so much. My main concern aside from privacy of course, is to keep the sun off the interior. I've thought about tinting the Windows, but I want to keep the OG glass clean and period correct. Also the shit of tint that was on there when I bought it, that was ummmm, fun?!
I'll be getting my sewing on soon.
FSAG (For Shits and Giggles) - "secrets of the Nazca" Expedition Unknown on Travel Channel there is a 15 window behind the lady in an interview, followed by a vintage 60's photo of a lady with a split window bug. Yeah, I'm eating chocolate watching the travel channel. Man I wish Mexico wasn't so damn crazy.
Denzel1975 Samba Member
Joined: July 18, 2016 Posts: 3 Location: Rimouski, Quebec
Posted: Tue Aug 16, 2016 10:50 am Post subject: Re: 1974 and 1975 westy info thread |
Some of you ever had a gas smell issue with their 1975 bus ? What should I start to check to resolve that problem ?
