Outer cargo Floor Repair
ccb_dan
ccb_dan is offline
PostPosted: Sat Feb 23, 2013 10:18 am    Post subject: Outer cargo Floor Repair Reply with quote
Just need some quick confirmation from you all that this is the piece I need. I have to replace the outer portion of my cargo floor by the doors.
My bus is a '65 11 window.
Thanks.
http://www.bustoration.com/KF-131--Cargo-Floor-Repair-Section-10-RIGHT-55-66_p_60.html
Z
Z is offline
PostPosted: Sat Feb 23, 2013 11:37 am    Post subject: Reply with quote
As long as your damage doesn't extend in more than 10" from the sill, that piece should cover it.
Is there damage to the rocker panel, as well?
ccb_dan
ccb_dan is offline
PostPosted: Sat Feb 23, 2013 12:05 pm    Post subject: Reply with quote
Yeah not bad though. Is that one of those "while you're at it" things? Take care of the rocker too?
ccb_dan
ccb_dan is offline
PostPosted: Sat Feb 23, 2013 2:48 pm    Post subject: Reply with quote
So I was looking on Bustoration for the rocker pieces and I'm utterly confused. Do I need the inner strengthener? The only part that looks messed up on my bus is the outer floor, the rocker and the sill between the floor and rocker.
Can someone link me to the pieces I need to do that repair?
Thanks.
Z
Z is offline
PostPosted: Sat Feb 23, 2013 4:39 pm    Post subject: Reply with quote
There are three pieces to the 'rocker' - the inner, the outer and the inner strengthener, which attaches to the back/inside of the outer rocker. Some of the replacement outer rockers have the inner strengthener already attached, and I think some don't.
Not sure what you mean by the "sill between the floor and rocker". If you mean the weatherstrip channel, that is part of the outer rocker.
Is this yours? (from your gallery) If so, I would guess that you need the outer, the inner strengthener and the floor at least. No way to know from the pic if your inner is good or bad. That looks like some weatherstrip held water, since there doesn't appear to be much rust beyond where the rubber goes.
There are scads of pics here showing the pieces and how they fit together much better than any diagram, even the online parts list. You can check in these for a better idea of how things go together:
http://www.thesamba.com/vw/forum/search.php?search..._chars=200
Hard to say any more until you do some exploratory surgery...
Z
Z is offline
PostPosted: Sat Feb 23, 2013 4:40 pm    Post subject: Reply with quote
http://www.bustoration.com/KF177--Rocker-Cargo-Doo..._p_98.html
this is the two-piece assembly.
And this is what it looks like from the inside (this is a dc rocker, but you get the idea...)
ccb_dan
ccb_dan is offline
PostPosted: Sun Feb 24, 2013 4:37 am    Post subject: Reply with quote
Thanks Z! Yeah that's mine in that pic. And yup...by "sill" I mean the weather stripping channel...not sure what it was called.
Thanks for the links...I'm gonna order the outer floor, strengthener and outer rocker as you suggested and go from there.
Thanks again!
krusher
krusher is offline
PostPosted: Sun Feb 24, 2013 1:57 pm    Post subject: Reply with quote
the panels from wolfsburg west are all better for those areas,
(06:31:07) RoachGhia: "i drink dick way too fast"
ccb_dan
ccb_dan is offline
PostPosted: Sun Feb 24, 2013 5:25 pm    Post subject: Reply with quote
Thanks Krusher. I can get everything but the floor piece form WW as it is out of stock. Is it a mistake to mix and match parts form different vendors? I mean get the rocker pieces from WW and the floor from Bustoration? Am I asking for fitment problems if I do that?
krusher
krusher is offline
PostPosted: Mon Feb 25, 2013 8:53 am    Post subject: Reply with quote
non of them are perfect, you will have to tweak and tap and work with them all for best fit.
I have used them all and they will all work with some attention to detail in any combination.
The outer cargo rocker which comes with the inner strengthener already spot welded from WW is better then the CF one.
