74autobot Samba Member
Joined: January 31, 2013 Posts: 65 Location: Texas Corners, MI
Posted: Sat Feb 23, 2013 5:29 pm Post subject: a few questions before i install this fog light switch |
i received my fog light switch from Poland today and i just wanted to make sure that it is the correct switch? also which blank should i or rather which is the blank that would have been used for the fog switch? last question is what is this blank used for next to the headlamp switch? im going to get out to the garage tonight and get this installed.
thanks,
Justin
_________________ For once you have tasted flight you will walk the earth with your eyes turned skywards,for there you have been and there you will long to return. |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
Posted: Sat Feb 23, 2013 5:44 pm Post subject: Re: a few questions before i install this fog light switch |
74autobot wrote: |
thanks,
Justin
The blank space next to the headlight switch is for oem clock. _________________ Parts for sale https://www.thesamba.com/vw/classifieds/search.php?username=APPLEGREENVW
02/76 Beetle sedan |
cletus_zuber Samba Member
Joined: January 08, 2010 Posts: 2408 Location: Gladstone, Ore
Posted: Sat Feb 23, 2013 6:07 pm Post subject: |
Either 1 or 2 should work great and look factory.
Kudos to you for not just drilling a hole for some Walmart style switch! _________________ 1972 1302
HPMX 40's & 019 |
toyvergnugen Samba Member
Posted: Sat Feb 23, 2013 6:10 pm Post subject: |
On my 74 I have mine located in your position#2. Looked more natural there. The last blank may have been for cars with gas heaters.
It has been a long time since I installed my switch but it is a three position switch. Off, rear fog and both front and rear fog depending how it is wired. I believe the warning light is a reminder that rear fog is on. You can wire to remind you that front fogs are on.
I wired mine for driving lights and no rear fog. If wired correctly fogs should go out when high beams are on. Also be sure to use a relay.
yours is correct for SB. Early Rabbit and Scirocco ones are identical except the icon is rotated 90 degrees and the part #. Rabbit ones start with 321 and SB ones start with 133. Hope this helps. |
Posted: Sat Feb 23, 2013 6:18 pm Post subject: |
thanks to all of you thats all the re assurance i needed. i agree with not hacking this car up i dont want to be the molester for any future owners. thanks for the wiring tip i will have to wire it up my own way since i will not have a back fog.
regards,
justin _________________ For once you have tasted flight you will walk the earth with your eyes turned skywards,for there you have been and there you will long to return. |
Posted: Sat Feb 23, 2013 6:32 pm Post subject: |
I don't have a back fog either. More common in Europe. |
CarlIseminger Samba Member
Joined: May 12, 2008 Posts: 833 Location: Grand Forks, ND
Posted: Sun Feb 24, 2013 12:52 pm Post subject: |
Spot #1 is used for the gas heaters when they were installed. So I would go with # 2 for the fog light. But most dealer installed fog lights used a toggle switch instead of the rocker switch. |
Posted: Sun Feb 24, 2013 4:15 pm Post subject: |
CarlIseminger wrote: |
Thanks for the insight, now when you say dealer install are you talking about an American dealer? Im wondering what the factory installed, if this was the correct switch?
Regards,
charlie VT Samba Member
Joined: January 19, 2013 Posts: 56 Location: Central Vermont
Posted: Sun Feb 24, 2013 4:18 pm Post subject: |
Would there have been a factory or at least a period specific switch for other models, like a '68? _________________ 1968 Savannah Beige Bug |
Posted: Sun Feb 24, 2013 4:42 pm Post subject: |
The switch i got was listed for a 72& up super beetle. That is all i know about fog light switches.
Regards,
Justin. _________________ For once you have tasted flight you will walk the earth with your eyes turned skywards,for there you have been and there you will long to return. |
Joel Samba Member
Joined: September 04, 2006 Posts: 11099 Location: NSW Australia
Posted: Sun Feb 24, 2013 10:10 pm Post subject: |
charlie VT wrote: |
Would there have been a factory or at least a period specific switch for other models, like a '68? |
No fog light switches were factory, all dealer or PO installed.
Most dealers would have just installed generic toggle switches, there is a brand new never sold 79 cab at a dealer on here somewhere which has never been on the road fitted with foglights, it just has a crappy Kmart toggle switch.
If you want something factory looking what I did with my bug before I found the correct 1303 super beetle foglight switch like the one in this post was use a Porsche one.
It matches flat windscreen beetle ones very nicely.
you can see it to left of my cigarette lighter.
The only time I've ever seen one as original fitment is on the 72 Oettinger convertible at the museum
vw_hank Samba Member
Joined: February 07, 2001 Posts: 5371 Location: Everett WA
Posted: Sun Feb 24, 2013 10:22 pm Post subject: |
Joel agen is right, it was a dealer thing, so it was a mix & match to what you would have had in your car,, The Porsche one is very nice! The Bus dome light switch is great also!!! That's what I have.. _________________ 1302s sunroof..
1600cc motor. Glenn ring 010. full toplineparts.com suspension. factory front disk brakes. Tram type-3 rear brakes. Hurst shifter. empi-8's. low-back's. tons of mods! |
Posted: Mon Feb 25, 2013 10:58 am Post subject: |
So if there was never a factory installed switch and only a dealer option what makes the switch i purchased the correct switch? And why is there a blank in the dash for a switch? Thanks for the input guys, i love learning about those crazy Europeans!
Regards,
Justin _________________ For once you have tasted flight you will walk the earth with your eyes turned skywards,for there you have been and there you will long to return. |
19super73 Hardcore Stock Nazi
Joined: October 18, 2007 Posts: 4351 Location: Cité Soleil
Joel Samba Member
Posted: Mon Feb 25, 2013 1:43 pm Post subject: |
74autobot wrote: |
Regards,
Justin |
So you want the long winded answer?
It was made for one very small market in Europe where it was compulsory for cars to have front and rear foglights, think from memory it was Denmark or similar so it was a very low production switch, took me ages to find one.
The dealers in mainstream markets like US wouldnt have chased up that switch hence the generic ones were mainly used. |
Posted: Mon Feb 25, 2013 2:45 pm Post subject: |
Joel wrote: |
74autobot wrote: |
Regards,
Justin |
Ok! Thats a perfect explanation and makes more sense to me. So really the factory switch looks more out if place on the dash compared to the rocker switch you had previously had installed from a different vw. Well thanks for the schooling and i feel a little more purified today.
Regards,
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Mon Feb 25, 2013 3:19 pm Post subject: |
toyvergnugen wrote: |
Early Rabbit and Scirocco ones are identical except the icon is rotated 90 degrees |
Which way was the icon rotated? For front fogs, the lamp would be aimed to the left. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
Joel Samba Member
Posted: Mon Feb 25, 2013 3:25 pm Post subject: |
We are talking about the switch not the light, all the others used the switch sideways so the icon is the other way around
74autobot wrote: |
Regards, |
I think given the choice most people would want the stock oem switch, they match the other switches and don't look like a hack job.
I've yet to see an aftermarket generic toggle switch that looked nice and like originals. |
Posted: Mon Feb 25, 2013 4:01 pm Post subject: |
Joel wrote: |
Joel, that switch that you have pictured there is actually up-side down (for the early Rabbit etc) is it not? _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Joel Samba Member
Posted: Mon Feb 25, 2013 5:16 pm Post subject: |
77kafer wrote: |
Joel, that switch that you have pictured there is actually up-side down (for the early Rabbit etc) is it not? |
Yep, so it would look pretty silly installed in a 1303 super with the icon sideways....
