pawesty Samba Medic
Joined: June 28, 2003 Posts: 1545 Location: Northern Vermont
Posted: Thu Oct 23, 2003 3:51 pm Post subject: keepin the heat in the bus?????? |
hi guys, i recently reconnected the factory heat in the 78 transporter. i'm sealing up air leaks and closing off the cool air vents for the winter. my question is, has anyone insulated behind the panels? what r rating insulation? any problems encountered or suggestions would be greatly appreciated. i know there used to be a good thread on rustproofing and insulating a bus on type2 but the thread no longer works. thanks in advance from snow flurry in october pennsylvania! dave _________________ "Go smell the wind, go far. Hear the marvelous strange chime of midnight" Kerouac
79 westy
78 westy
purveyor of refurbed westies and parts!!! inquire within!
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Thu Oct 23, 2003 4:01 pm Post subject: |
There's an over the top article about insulation on www.type2.com _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
75BusBlues Samba Member
Posted: Thu Oct 23, 2003 10:44 pm Post subject: Re: keepin the heat in the bus?????? |
pawesty wrote: |
hi guys, i recently reconnected the factory heat in the 78 transporter. i'm sealing up air leaks and closing off the cool air vents for the winter. my question is, has anyone insulated behind the panels? what r rating insulation? any problems encountered or suggestions would be greatly appreciated. i know there used to be a good thread on rustproofing and insulating a bus on type2 but the thread no longer works. thanks in advance from snow flurry in october pennsylvania! dave |
I put pink solid fanfold insulation (along with all sorts of rustproofing) behind all the panels in my Bus. I'm not sure of the R-value, but it keeps us warm in Chicago down to about 20 degrees. Any colder than that and I have to break out the catalytic propane heater. I can't recommend them enough. Get the one with the built-in fan - it sits perfectly in the walk-through.
By the way, the pink fanfold insulation has the advantage of not absorbing or holding water, unlike the NASA foil covered insulation. Besides the engine compartment where there is enough heat to deal with any moisture, the foil stuff is like a wick in the interior... |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Oct 25, 2003 4:26 pm Post subject: |
Here's an interesting heat bandaid that my wife came up with when we were living in Sun Valley, Idaho... We insulated everything, ran ALL the heat up front, and then my wife hung a clear shower curtain behind the front seats from ceiling to floor. It kept ALL the heat up front, we could push it aside and still get into the back, and I could still see out all the windows! It looked lame but it WORKED. When it can get to -40F, you don't give a damn what it looks like! |
pawesty Samba Medic
Posted: Sun Oct 26, 2003 12:25 pm Post subject: |
hey guys, i'm gonna do the insulation over the next few days. how did you run all the heat up front? i'm looking at coleman catalytic heater, and as far as the shower curtain....i'll hang matches off my a** to beat the cold thats a comin!!!lol thanks for the advcice guys. dave _________________ "Go smell the wind, go far. Hear the marvelous strange chime of midnight" Kerouac
79 westy
78 westy
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Sun Oct 26, 2003 3:22 pm Post subject: |
You could use a flexible dryer vent hose, or something similar. Tape it to the out let, and run it up front under the bottom of your curtain. If it's long enough, you can even use it for a quick defroster, by pointing it at the window! Jeremy |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Sun Oct 26, 2003 5:41 pm Post subject: |
there is a great thread on this somewhere in this forum. Was started back in february if i remember right... _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
Posted: Sun Oct 26, 2003 5:46 pm Post subject: |
check out the "heat, OHMYGAWD" thread for lots of good info. _________________ OG JHC
2% |
Bottomend Grease
Joined: September 20, 2003 Posts: 1500 Location: Smell Aye! via Nude Hamster!
Posted: Sun Oct 26, 2003 11:06 pm Post subject: |
What exactly is fanfold insulation and where can I get some? It's just about time for me to start getting my heat togather and this stuff sounds like the thing for me. |
josh Samba Member
Joined: July 13, 2003 Posts: 1773 Location: laid back in the tall grass
Posted: Sun Oct 26, 2003 11:12 pm Post subject: |
To send the heat up front-right lever down left lever halfway down. I drove my bus for years before I read the owners manual and frigured this out. People with more than 2 levers read your owners manual. |
Posted: Mon Oct 27, 2003 9:15 am Post subject: |
Bottomend wrote: |
Fanfold insulation is very dense solid core insulation about 1/4 thick. It comes folded up like an accordian, hence the name. You can get a bundle of it at Home Depot very cheap - around $5 for more than enough. It's easy to cut to size and can fit anywhere - behind panels, interior of the car on firewalls, etc. |
Posted: Mon Oct 27, 2003 9:46 am Post subject: |
josh wrote: |
Wouldn't that depend on what model the bus was? in a Kombi or Panel there is no rear heater outlet. Right? _________________ Your Vanagon sucks, Stop waving at me.
