adv rider Samba Member
Joined: September 09, 2012 Posts: 288 Location: Everett,wa
Posted: Sun Oct 27, 2013 10:02 pm Post subject: sirius |
It's about time for me to revisit this antenna/signal issue. I purchased a pioneer x7500s sirius ready radio, along with a new german antenna assy. I hope to have reception similar to my new vehicle sirius radio.
They have the additiona Sirius connector adapter in stock at best buy too _________________ 86' Wolfsburg weekender 2.1, 4spd, , merian brown |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17123 Location: Retired South Florida
Posted: Mon Oct 28, 2013 9:32 am Post subject: |
ThankYouJerry wrote: |
As an ex-XM/Sirius subscriber for years... I can say beyond an unequivocal doubt that a bluetooth head and Pandora for $36/yr is FAR, FAR, FAR superior to XM/Sirius. Unless, of course, you live for Howard Stern or something like that which is exclusive to XM/Sirius. To each his own. |
Not a big fan of Sirius, but it is ok for extended cross country trips. Does your solution require an internet connection via your cell phone? If so what sort of data use does it have streaming audio? What about when you are in an area with out cell coverage? Does it work then? What about on the fringe of cell coverage? Does it buffer? _________________ ☮️ |
BillWYellowstone Samba Member
Joined: July 16, 2011 Posts: 767 Location: Yellowstone NP
Posted: Mon Oct 28, 2013 4:07 pm Post subject: |
I have used the Pandora but key is cell reception. I live inside Yellowstone. From the small pocket at Old Faithful to the next pocket of reception is about 28 miles. Then from there to Bozeman about another 7o miles of no reception. Some areas of the country are like this and this is where the sat service shines.
Of course, the original question had to do with antenna for Sirius location. Thanks fo an alternative though. _________________ Live Fulltime in motorhome
Have 86 Westy Camper 2.1 rebuilt
Work in Yellowstone NP year round. |
big swifty Samba Member
Joined: August 21, 2007 Posts: 246 Location: Formally in Republic of VT; now in Hollywood, FL
Posted: Mon Oct 28, 2013 4:21 pm Post subject: Re: sirius antenna |
[quote="chimivee"]
adv rider wrote: |
The wire then continues forward and under the luggage rack. Magnetic puck antenna lives under there. |
I mounted mine similarly. Unscrewed the canvas retaining strip and fed the lead under. No problemo. _________________ Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3341 Location: Talos IV, Piedmont Arizona
Posted: Mon Oct 28, 2013 4:52 pm Post subject: |
Babba-Booy Babba-Booy Babba-Booy
Yo, Under the fiber rack Mr White.......................bitch. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
southernsyncro Samba Member
Joined: March 29, 2013 Posts: 11 Location: Pace,Florida
Posted: Mon Oct 28, 2013 5:12 pm Post subject: |
mine is in the front center of the dash and Ive never had any problems |
Chuckarlie Samba Member
Joined: July 06, 2012 Posts: 25 Location: Charlotte, NC
Posted: Mon Oct 28, 2013 7:24 pm Post subject: |
Stock magnet antenna on the back hatch, running the long cable through the same gasket as the defrost wires. Then through the cabinets and under the carpet to the dash. Took maybe 30 minutes to run, the cable is just long enough.
Only reception issues I have are in tunnels or forests where vehicle isn't the problem. |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Mon Oct 28, 2013 11:49 pm Post subject: |
rsxsr wrote: |
Not a big fan of Sirius, but it is ok for extended cross country trips. Does your solution require an internet connection via your cell phone? If so what sort of data use does it have streaming audio? What about when you are in an area with out cell coverage? Does it work then? What about on the fringe of cell coverage? Does it buffer? |
No, it does not require an internet (wifi) connection. 3G or 4LTE service is best. I have an iPhone and a standard plan with Verizon and don't get charged for "data" when listening to Pandora. I listen to it for 40-60+ hours/month and my bill is always the same month-after-month. Buffering is "ok" when on the fringe of service. When there is no service I simply listed to music I have downloaded on my iPhone. Bluetooth (wireless) head units are AWESOME! I have an Alpine and couldn't be happier. _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
shortride Samba Member
Joined: October 10, 2010 Posts: 1323 Location: Oklahoma
dwschwartz Samba Member
Joined: July 21, 2013 Posts: 4 Location: Seattle, USA
Posted: Sun Jun 17, 2018 9:54 pm Post subject: Re: sirius antenna |
Quote: |
Yes, this is how I ran my wire - under the pop top canvas' mounting rail near the left/front corner. Just loosen a screw or two enough to get the plug end through, then tighten back down. No drilling necessary. There is a good spot where there is a small gap in the rails - my wire runs right under this, so the aluminum rails can still lay flush and not stress the wire. |
Just want to say think you for the 2013 post @chimivee. I'd been going crazy with the cutouts from my SiriusXM radio with the antenna mounted in the dash. Routing it in the way you showed has made all the difference in the world! |
