castlerox Samba Member
Joined: February 14, 2009 Posts: 119 Location: Phoenix, Az
Posted: Fri Mar 01, 2013 12:35 pm Post subject: Uh OH - EMISSIONS FAIL - Oxides of NITROGEN (NOX) - HELP? |
I went to emissions today.
Everything is cool but...
See images below. Anyone know what the problem may be? I am not that mechanically inclined...
Thanks for your info if you have some!
Matt _________________ 1985 Wolfsburg weekender SVX
1998 Gen 2.5 Montero - all locked up
2014 Acura RDX - my never let me down |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Fri Mar 01, 2013 2:58 pm Post subject: |
High NOX happens when the combustion chamber temperatures are high. There are a couple of tricks to get it down for emissions testing.
1. Do not warm the engine up prior to testing. The coolant temps should just be coming off the cold area on your gauge. Keep the cylinder heads cool. This will increase your HC, not a problem if your Catalytic converter is working and has "fired up" and your O2 sensor is working. You will still pass the HC and your NOX will be lower.
2. En-rich the fuel mixture..this works sometimes..if your O2 sensor is not working.
3. Replace the catalytic converter (when your emissions numbers are so close to passing..it could be your Cat is not working). When the Cat gets to the end of days it will not scrub the NOX. BusDepot and RockAuto have them for about $100 to $120 |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Fri Mar 01, 2013 7:21 pm Post subject: |
Your HC and CO are so close to the limit that this is obviously a cat converter problem. With a new cat, functioning oxy sensor and no other problems, you would be well under the test fail limits.
If your oxy sensor was bad or almost dead, you would most likely fail on HC. This is why I would suspect the cat and not other components like the oxy sensor. The default ECU mixture when the Oxy sensor goes bad is too rich to pass HC. Sub in a new "test" cat for emissions testing and after passing, use it next year again. Unless you wish to have emissions perfection in which case, use the new cat until it also fails.
If you don't have money right now for the cat, then retard your ignition timing 5 degrees just for the test. That may just do the trick. WBX engines don't have EGR. On engines that do have EGR, the low-load low-rpm spark timing can be advanced quite a bit to give good torque and fuel economy, but this only works if the EGR system is working. The EGR system cools the in-cylinder temps by introducing inert gas which lowers combustion temps. So, on the WBX, since it has no EGR system, a marginal NOx test failure can sometimes be overcome with a bit less spark advance. _________________ '86 Syncro Westy SVX |
desertrefugee Samba Member
Joined: January 22, 2013 Posts: 476 Location: Phoenix, AZ. USA
Posted: Fri Mar 01, 2013 8:44 pm Post subject: |
+1 on backing off on the timing.
My Westy marginally failed the same test in Phoenix. I retarded the timing a few degrees and passed by a wide margin.
Give it a shot - and as already mentioned, don't have the engine too hot, contrary to optimizing for other emissions tests...
Good luck! _________________ - 83.5 Westfalia - 2.2 GoWesty "power"
- a bunch of vintage motorcycles
- Numerous telescopes of various size and function
"For I have loved the stars too fondly to be fearful of the night." - Sarah Williams |
r39o Samba Polizei
Posted: Fri Mar 01, 2013 10:02 pm Post subject: |
The idea of getting it hot before the test is to make sure the cat works well.
If hot and all you do is fail NOX by a little, a new cat has always passed for me. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Sat Mar 02, 2013 6:16 am Post subject: |
r39o wrote: |
If hot and all you do is fail NOX by a little, a new cat has always passed for me. |
I certainly don't doubt this and catalytic converter issues are high on the list of potential contributors to elevated NOx emissions.
But, why advocate splashing the cash if a minor adjustment would do the same thing? Particularly if the cat is flowing well? And, more importantly, if cash is tight? _________________ - 83.5 Westfalia - 2.2 GoWesty "power"
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Sat Mar 02, 2013 7:02 am Post subject: |
desertrefugee wrote: |
r39o wrote: |
But, why advocate splashing the cash if a minor adjustment would do the same thing? Particularly if the cat is flowing well? And, more importantly, if cash is tight? |
He is not advocating splashing cash. It's that your cat is starting
to fail to do its job even though its not clogged.
The adjustments suggested are only temporary to get you
through emissions and must be readjusted after testing.
If money wasn't tight purchasing a California compliant
cat would be the way to go. I installed one on a local
van here in CT and it really made a difference in the
tail pipe readings.
Regardless though Good luck getting it passed. Thankfully
my Westy no longer requires to be smogged in my state. _________________ Bill M
87 Westy |
K58 Samba Member
Posted: Sat Mar 02, 2013 1:24 pm Post subject: |
I ended up spending ~$700 to pass smog on my '84 this year. On the advice of my world renowned mechanic I bought a new CA Cat and it did the trick.
2 years prior he tweaked my timing for nothing because it was borderline.
Bottom line is, do what you have to do. _________________ Westy HID Projector Retrofit |
Umusername Samba Member
Posted: Wed Jul 03, 2013 4:39 pm Post subject: What did you do to get it to pass? |
I am right on the edge as well and am trying to figure out the cheapest way to pass. Here are my readings.
I put a new air filter in and changed the oil along with some general making sure hoses are clamped on well. |
Posted: Wed Jul 03, 2013 10:51 pm Post subject: |
Hi Umusername:
You can pass by adjusting your spark timing. Retard it 5 degrees and you will pass. Then re-adjust to spec after the test. Your CO and HC numbers indicate that your cat is healthy. _________________ '86 Syncro Westy SVX |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3053 Location: Vancouver Island, B.C.
Posted: Tue Jul 09, 2013 10:46 am Post subject: |
I also just failed the NOx test. Vehicle reading 1410, max allowable is 1145. Other tests were fine: HC 53 (143); CO .48 (.71).
I have a brand new cat that came with the RMW SS exhaust. New 02 sensor two years ago.
The van was running fine (and passing AirCare) with the old leaking exhaust. The leak got really bad and the whole thing was rusty so I had it replaced. With the new exhaust there was a rough cold start idle. I replaced the temp II sensor (no change) and adjusted the screw on the AFM to bring the idle up a bit. When warm it idles at just about 1000.
What should I be looking at? _________________ 89 Syncro GL Westfalia 2.1 WBX/WBXaustSS
My Westy Movies:
photogdave On Vimeo
photogdave On YouTube
Posted: Tue Jul 09, 2013 11:30 am Post subject: |
If you are your wits end and have nothing to lose..unplug one fuel injector just prior to and after arriving at the test center..if the engine is healthy it will barely idle..and will pass just fine. Your disconnected cylinder becomes an air pump and really cleans up the exhaust.
After the test..replug and go. |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Tue Jul 09, 2013 8:05 pm Post subject: |
AtlasShrugged wrote: |
I kinda doubt that running it on the dyno on three cylinders will go unnnoticed by the AirCare guy/gal... _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Wed Jul 10, 2013 6:08 am Post subject: |
Jake de Villiers wrote: |
I kinda doubt that running it on the dyno on three cylinders will go unnnoticed by the AirCare guy/gal... |
Unless the Aircare folks in BC are different than their counterparts here..they don't know.. after all the Vanagons are over 23 years old and a loping idle and no power is a WBX trademark. |
tencentlife Samba Member
Posted: Wed Jul 10, 2013 6:55 am Post subject: |
Lambda is going to thwart this fudge, and passing in open loop is quite unlikely. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
bluebus86 Banned
Posted: Wed Jul 10, 2013 7:35 am Post subject: |
Well HC got a lot better by changing the air filter and tightening some things.
you could run the test with a cool engine now, the cool enginewill reduce NOx but increase HC, but since your second HC reading is s much lower now, you might be able to retest with a cold motor and pass both HC and NOx.
My van did simular and that is how I was able to pass once, the catalyst was really on the way out and next time two years later i replaced it and passed hot.
so you might if you have lowHC be able to get away with a cold test and be able to pass NOx. if not maybe time for a new catalyst. I am not a big fan of tweeking the motor wrongly to pass, unless you put it back right away. you dont want to be runing with reduced timing or really rich mixtures other than to pass a test. you dont want ot screw a whole bunch of things up just to pass a test.
if yoru concerend that you van is starting to eat catalysts (ie worn motor burns oil or such) you could place the new catalyst on only for the test, then remove it to save for the next test. |
Posted: Wed Jul 10, 2013 8:01 am Post subject: |
Hey Dave, after re-reading your post, I'm thinking that you should put the AFM screw back where it was prior to your tweaking it. Its best to use that screw in conjunction with a tailpipe sniffer to set the CO at idle.
A lean miss at idle seems to be par for the course with Digifant-equipped WBX engines, anyway. _________________ '84 Vanagon GL 1.9 WBX
Posted: Wed Jul 10, 2013 8:07 am Post subject: |
Yes the O2 sensor will kick the mixture lean..and if the engine will idle..they do pass the dyno emissions tests here in Metro Atlanta. I never had to disconnect to O2 sensor..you could..the clean air techs never have looked under the engine cover, only under the engine to be sure it has a Cat.
Try it if you have a buddy that can run a sample test for you..
..it should work just fine.
It would be a solution of last resort..don't drive around with the engine like that. |
Posted: Wed Jul 10, 2013 8:16 am Post subject: |
Quote: |
Yes the O2 sensor will kick the mixture lean |
No, if it's working all that unused O2 in the exhaust will drop the O2 V and the ECU will enrich. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
